    RepRapFirmware 3.0
    176
    30.6k
      dc42 administrators @mudcruzr
      @mudcruzr said in RepRapFirmware 3.0:
      Is there any chance of a new build with these changes in (for those of us without the wherewithall to compile) please?
      New binaries here https://www.dropbox.com/s/fyvibzm0zl92hiy/Duet2CombinedFirmware.bin?dl=0 and here https://www.dropbox.com/s/m0r3ldy424mxf4v/DuetMaestroFirmware.bin?dl=0.
      • mudcruzrundefined
        mudcruzr
        @dc42 Many thanks David
        • oliofundefined
          oliof
          That last build does not move the extruder for me on a CR-20. I checked by moving the extruder motor to X and was able to move it. Downgrading to 2.03RC2 (what I ran previously) fixed the extruder.
          I am pretty sure that nothing in my config.g needs changing, but maybe I overlooked something in the wiki. See attached file.
          • 0_1558265361187_config.g
          • Dougal1957undefined
            Dougal1957 @oliof
            @oliof you did have the nozzle heated didn't you?
            • oliofundefined
              oliof
              Yes, this was with a heated nozzle -- DWC showed extruder moves in the UI, but the motor was not moving and there was no error regarding attempting to extrude with a cold nozzle. And even enabling cool extrusion (with filament removed) with M302 P1 did not allow the extruder motor to move.
                Dougal1957 @oliof
                @oliof just checking as it is a common mistake but not valid in this case
                • oliofundefined
                  oliof @Dougal1957
                  @dougal1957 it's absolutely fair to ask (-:
                    Was the extruder motor connected directly to an output on the Duet?
                    • oliofundefined
                      oliof
                      Yes, to output "E0" on the duet wifi board.
                      • 4latheundefined
                        4lathe
                        Sane for me. Just loaded latest 3.0 and modified my m558 as I use fsr’s on endstop e0. Motion control all fine as is bed and nozzle heat bur the extruder E0 will not extrude or retract. Its at temperature.
                        • carlossprundefined
                          carlosspr
                          Same here using RepRapFirmware 3.0beta3 (2019-05-16b1) . In my case I have two tools (two extruders and one heater). The following is the configuration of my TOOLS section:
                          ;_____ TOOLS
                          M563 P0 D0 H1                       ; Define tool 0 to use extruder drive 0 and heater 1
                          G10 P0 S0 R0 X0 Y0                  ; set tool 0 temperatures and offsets
                          M572 D0 S0.1			    ; Pressure advance enable for extruder 0
                          M563 P1 D1 H1                       ; Define tool 1 to use extruder drive 1 and heater 1
                          G10 P1 S0 R0 X0 Y0                  ; set tool 1 temperatures and offsets
                          M572 D1 S0.1			    ; Pressure advance enable for extruder 1
                          None of the tools would move, neither with temp nor forcing cold extrusion with M302
                            Run M584 and check whether the extruders are mapped to drivers 3 and 4.
                            carlossprundefined 1 Reply Last reply Reply Quote 0
                              carlosspr @dc42
                              @dc42 Yes they are mapped to drivers 3 and 4. The result of M584 is : Driver Assignments X0 Y1 Z2 E3:4, 3 axes visible.
                                dc42 administrators @carlosspr
                                Thanks, I will look into it.
                                • Sytac072undefined
                                  Sytac072
                                  Hello, I have a single extruder configuration. I just tried to install the RepRap firmware 3 and I had had the same problem, no way to move the extruder motor.
                                    dc42 administrators @Sytac072
                                    I will do a new RRF3 beta release next week. I need to do another 2.03RC release first.
                                      I am planning a new build of RRF 3 later this week, incorporating the recent improvements in RRF 2.03RC3. Meanwhile, I think you can probably get extrusion working if you use M584 to assign extruder drives explicitly. Although M584 appears to shows the correct extruder drive mapping by default, in reality the extruder data has not been set up fully.
                                      • MoczikGaborundefined
                                        MoczikGabor @Veti
                                        @veti said in RepRapFirmware 3.0:
                                        @dc42 said in RepRapFirmware 3.0:
                                        The current plan is 30V or perhaps 36V. It's difficult to find 5V buck regulator chips that accept higher than 40V input.
                                        why not says that for input above 30V the 5V line has to be supplied via the ext 5V?
                                        I think that the board could have separate V_MOT and V_IN terminals.
                                        The V_MOT could accept higher voltage which would go solely to the motor drivers.
                                        The V_IN could accept 25-30V max as you will probably need 12/24V for the hotends or fans anyway, or for other automation purposes in CNC. This is how I usually do in custom machines I design.
                                        Those who don't need higher voltage or anything special just have to connect the V_MOT and V_IN parallel, those who need it could use two power supplies.
                                        • Alexander Mundyundefined
                                          Alexander Mundy
                                          @dc42 Sorry for my confusion but if you (or anyone) could help me I would appreciate it. I just got the delta endstops and homing working but I do have 2 things remapped. My bed heat SSR's are connected to E1 and my part fan is connected to H0.
                                          I managed to get the part fan working with:
                                          M950 F0 C"bedheat" Q25500
                                          Autotuned the hotend but the bed is the problem.
                                          For the bed I am trying:
                                          M140 H2 (without this the thermistor shows 2000 in web)
                                          M950 H0 C"e1heat" Q10
                                          And when I try autotune I get:
                                          M303 H0 S110
                                          Error: heater 0 reported error 'unknown temperature sensor channel' at start of auto tuning
                                          The web interface shows the bed temp
                                          What am I doing wrong?
                                            Alexander Mundy
                                            A little further testing.
                                            M950 H2 C"nil"
                                            Sending "M950 H0"
                                            I receive "Heater 0 pin e1heat, frequency 10Hz"
                                            However the bed temp in the web interface shows 2000 with the thermistor plugged into either the board bed heat or E1 spots.
