Heater Fault
heater fault
1.5k
    justinds89
    Hello everyone!
    I just built a HyperCube Evolution with DuetWifi.
    I noticed that the hotend heater will steadily climb to about 200-210 and then start fluctuating before showing a heater fault.
    Could anyone please hello me figure out what could cause this or how to resolve this so I can print?
    Thanks!
    ? 1 Reply Last reply 20 May 2019, 20:28 Reply Quote 0
      Veti
      have you done a pid tune?
      https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        justinds89
        I have not. I will checkout the link you sent and see if I can't figure out how to do that.
        Hopefully that will solve the problem.
          A Former User @justinds89
          @justinds89
          Can you add a screenshot of the "graph" on the Duet-Web-Conrol? Can you give some more info on type of heater & temperature-sensor (also it is a "heater-fault" usually the problem is either PID-tuning or the temperature-sensor...)
            justinds89
            I will post a screenshot later when I can.
            I am using a 24v 40w heat cartridge and a E3D thermistor cartridge.
            Temp sensor is new and I have not done any PID tuning.
            I saw the wiki entry, but can anyone tell me how to properly PID tune the hotend?
            Not sure how to store the value or what to do with it.
            ? 1 Reply Last reply 20 May 2019, 20:45 Reply Quote 0
              @justinds89
              Well, basically you just copy and past those lines into the "g-code-console" if you think all your wiring is good and your heater/temp-sensor is in a state where you can "fire it up":
              https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control#Section_Setting_the_model_parameters_by_auto_tuning
              e.g. for firmware 1.18beta1 and later, it seems it states:
              M303 H1 S240 ; auto tune heater 1, default PWM, 240C target or maximum temperature
              M303 ; report the auto-tune status or last result
              M500 ; save results in config-override.g
              undefined 1 Reply Last reply 20 May 2019, 20:47 Reply Quote 0
                justinds89 @A Former User
                @lb Ah okay, so after running those commands there isn't anything I need to set in config.g or anything?
                ? 1 Reply Last reply 21 May 2019, 16:34 Reply Quote 0
                  justinds89
                  Here's a current screenshot after PID tuning. I almost think it's worse...
                  Not really sure what could be causing this.
                  ? 1 Reply Last reply 22 May 2019, 11:19 Reply Quote 0
                    justinds89
                    It's kind of going steady right now, so maybe it's okay.
                    I will run a print and see what happens.
                      justinds89
                      Spoke too soon.
                      undefined 1 Reply Last reply 22 May 2019, 15:32 Reply Quote 0
                        siblues
                        I had similar issues with mine and it ended up being the wiring.The extruder movement was causing the connection to be lost for fractions of a second causing the dips in the graph.
                          JamesM
                          The wiring on the E3D thermistor cartridges are delicate. I went through a few before I realized I had to constrain the wires once installed so they wouldn't move\shake during printing. Once I did that I've been on the same one for about 2 months now without issue.
                            justinds89
                            I've tried moving the wires all over and no blips in the graph, but once I start a print out may do it in just a few minutes or may take an hour. I don't get what it could be. Everything looks good.
                            I may just try swapping the thermistor out.
                              siblues
                              Have you checked the plug that plugs into the Duet itself it may have a bad crimp on the terminal?
                              undefined 1 Reply Last reply 21 May 2019, 02:32 Reply Quote 0
                                justinds89 @siblues
                                @siblues
                                Yes I did. I may just reterminate it again to role it out.
                                  siblues
                                  Yeah if that doesn't rule out a bad connection then I would try another thermistor and see what happens.The thermistor is a cartridge type right?
                                  undefined 1 Reply Last reply 21 May 2019, 02:51 Reply Quote 0
                                    justinds89 @siblues
                                    @siblues yes it is, I actually just swapped it out so we will see.
                                      jay_s_uk
                                      Does it happen when your part cooling fan turns on? If so, run the PID tuning with the fan on 100%
                                      undefined 1 Reply Last reply 21 May 2019, 12:59 Reply Quote 0
                                        justinds89 @jay_s_uk
                                        @jay_s_uk It does it regardless if the fan is off or on and it does not change when I manually turn the cooling fan on.
                                        I plan on trying it out tonight with the new thermistor.
                                          @justinds89 said in Heater Fault:
                                          I think you just have to check if you have a config-override.g in your /sys/
                                          You can also update by hand the vals thrown back in the console into your config.g (I would refer to it as "old style") but you can get tired of it over time, and I guess that is why you can automate all that by M500 that saves everything into the config-override.g...
                                          7 out of 23
