    Inverting PS_ON levels
    pson inverting
    16
    47
    4.8k
    • devleonundefined
      devleon @insertnamehere
      @insertnamehere are the 5V @ 500mA (says 300mA in the datasheet) enough to power the Duet reliably?
      insertnamehereundefined 1 Reply Last reply Reply Quote 0
      • insertnamehereundefined
        insertnamehere @devleon
        @devleon In the OPs case possibly not. I'm using a Meanwell HFG600 which is 5V @ 500mA in the spec.
        I don't have a panelDue attached and fans all run off the 24V.
        I've seen no problems using a 500mA supply over 100s of hours printing.
        • Nxt-1undefined
          Nxt-1 @insertnamehere
          @insertnamehere said in Inverting PS_ON levels:
          @nxt-1 +5V is from the Meanwell aux supply.
          I'm sorry to dig up this old thread, but I finally can to actually using this schematic. According to the datasheet, the 24V PSU needs: "RC+/RC- : 4 ~10V or open = power on ; 0 ~ 0.8V or short = power off" as a remote control signal. I soldered the little circuit together, but when I connect +5V and GND to the two terminals of my 5V PSU and measure the RC+ output of this diagram, I measure just 3.3V to GND. Also did you leave RC- floating or tied to GND in your printer?
          While thinkering with the optocouper, I came to think if there is any good reason to not connect the transistor straight across the RC+ and RC- terminals? As I see it, this would create a short or open based on PS_ON controlling the PSU just as well as a voltage applied. If I am mistaken, please correct me 🙂
          Duet3D and delta printer enthousiast. Buildlog
          Looking for Duet3D configuration support, check out Nxt-3D
          • fmaundefined
            fma
            @nxt-1 said in Inverting PS_ON levels:
            Yes, I think this is the way to go.
            Nxt-1undefined insertnamehereundefined 2 Replies Last reply Reply Quote 0
            • fmaundefined
              fma
              Could someone check if RC- is the same as GND of the output?
              Nxt-1undefined 1 Reply Last reply Reply Quote 0
              • Nxt-1undefined
                Nxt-1 @fma
                @fma said in Inverting PS_ON levels:
                I measure 193mV between RC- and V- of my HPRG200-24.
                • tomasfundefined
                  tomasf
                  I had the same problem and solved it with a simple 7400 NAND gate chip: https://forum.duet3d.com/topic/412/inverting-ps_on
                  Nxt-1undefined 2 Replies Last reply Reply Quote 0
                  • fmaundefined
                    fma
                    So, you wired RC- to GROUND?
                    • Nxt-1undefined
                      Nxt-1 @tomasf
                      @tomasf said in Inverting PS_ON levels:
                      Mind sketching up a quick diagram?
                      • Nxt-1undefined
                        Nxt-1 @fma
                        I tried it, but I forgot the signal needed to be inverted. As a result, this way it is functional but reversed. I not proficient enough with electronics to know if there is anything I can do to fix this, with the stuff I got laying around.
                        • fmaundefined
                          fma
                          This post is deleted!
                            insertnamehere @Nxt-1
                            @nxt-1
                            Sorry, I've not been online to answer earlier.
                            I leave RC- open and just connect to the RC+ input.
                            Are you using the 5V aux from the Meanwell or a separate 5V supply?
                              insertnamehere @fma
                              Hmmm.... let me check.
                              TO TURN ON SUPPLY.
                              Duet PS_ON goes to ground to turn on power. PS_ON ground will turn on the opto diode.
                              Opto diode on will cause the transistor to go ~ short. Short on Meanwell RC+ to RC- will turn OFF the Meanwell supply.
                              If you connect emitter/collector of the opto across the RC+ and RC- of the supply this will not invert the PS_ON signal. That is why the emitter resistor is needed.
                                This will not invert the PS_ON signal. The PS_ON signal from the Duet is a "Ground = On" and the Meanwell is "Open = On". The Emitter resistor inverts the signal.
                                • fmaundefined
                                  fma
                                  Yes, you're right. You need to use @jv43 config, using 5V from Meanwell. So this only works for this power supply. If the 5V is from another source, and this source turns off, the Meanwell remains ON 😞
                                  • Nxt-1undefined
                                    @nxt-1
                                    I am using a separate 5V Meanwell supply.
                                    The other 5V supply is permanently on.
                                    • Nxt-1undefined
                                      TO TURN ON SUPPLY.
                                      I tried the schematic you posted for your HFG600, that supply needs 2 ~ 5V or Open circuit to power on. In this case the ~3.3V I measured from your circuit is perfect. The HPRG I use needs 4 ~ 10V, to turn on, making the 3.3V insufficient. That is why my earlier test failed I believe.
                                      • fmaundefined
                                        fma
                                        Did you connect GND of both power supplies?
                                        • Nxt-1undefined
                                          Nxt-1 @fma
                                          I did not wire a connection from 5V- to 24V- terminals, however in both supplies the negative rail is connected to ground (mains ground that is) and those are of course wired up. So in a way there is a GND path between both PSU.
                                          https://www.meanwell.com/webapp/product/search.aspx?prod=HRPG-200
                                          https://www.meanwell.com/webapp/product/search.aspx?prod=RS-25
                                          • Nxt-1undefined
                                            Nxt-1 @tomasf
                                            I got myself a couple of 74HC00's to plat with. I assume you you wired your system like this? What value did you use for the pull up?
