    Inverting PS_ON levels
    pson inverting
    16
    47
    4.8k
    • Nxt-1undefined
      Nxt-1 @fma
      @fma said in Inverting PS_ON levels:
      Could someone check if RC- is the same as GND of the output?
      I measure 193mV between RC- and V- of my HPRG200-24.
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • tomasfundefined
        tomasf
        I had the same problem and solved it with a simple 7400 NAND gate chip: https://forum.duet3d.com/topic/412/inverting-ps_on
        Nxt-1undefined 2 Replies Last reply Reply Quote 0
        • fmaundefined
          fma
          So, you wired RC- to GROUND?
          • Nxt-1undefined
            Nxt-1 @tomasf
            @tomasf said in Inverting PS_ON levels:
            Mind sketching up a quick diagram?
            • Nxt-1undefined
              Nxt-1 @fma
              @nxt-1 said in Inverting PS_ON levels:
              While thinkering with the optocouper, I came to think if there is any good reason to not connect the transistor straight across the RC+ and RC- terminals? As I see it, this would create a short or open based on PS_ON controlling the PSU just as well as a voltage applied. If I am mistaken, please correct me
              Yes, I think this is the way to go.
              I tried it, but I forgot the signal needed to be inverted. As a result, this way it is functional but reversed. I not proficient enough with electronics to know if there is anything I can do to fix this, with the stuff I got laying around.
              insertnamehereundefined 1 Reply Last reply Reply Quote 0
              • fmaundefined
                fma
                This post is deleted!
                • insertnamehereundefined
                  insertnamehere @Nxt-1
                  @nxt-1
                  Sorry, I've not been online to answer earlier.
                  I leave RC- open and just connect to the RC+ input.
                  Are you using the 5V aux from the Meanwell or a separate 5V supply?
                  Nxt-1undefined 1 Reply Last reply Reply Quote 0
                    insertnamehere @fma
                    Hmmm.... let me check.
                    TO TURN ON SUPPLY.
                    Duet PS_ON goes to ground to turn on power. PS_ON ground will turn on the opto diode.
                    Opto diode on will cause the transistor to go ~ short. Short on Meanwell RC+ to RC- will turn OFF the Meanwell supply.
                    If you connect emitter/collector of the opto across the RC+ and RC- of the supply this will not invert the PS_ON signal. That is why the emitter resistor is needed.
                      This will not invert the PS_ON signal. The PS_ON signal from the Duet is a "Ground = On" and the Meanwell is "Open = On". The Emitter resistor inverts the signal.
                      • fmaundefined
                        fma
                        Yes, you're right. You need to use @jv43 config, using 5V from Meanwell. So this only works for this power supply. If the 5V is from another source, and this source turns off, the Meanwell remains ON 😞
                        • Nxt-1undefined
                          Nxt-1 @insertnamehere
                          @insertnamehere said in Inverting PS_ON levels:
                          @nxt-1
                          I am using a separate 5V Meanwell supply.
                          The other 5V supply is permanently on.
                          • Nxt-1undefined
                            TO TURN ON SUPPLY.
                            I tried the schematic you posted for your HFG600, that supply needs 2 ~ 5V or Open circuit to power on. In this case the ~3.3V I measured from your circuit is perfect. The HPRG I use needs 4 ~ 10V, to turn on, making the 3.3V insufficient. That is why my earlier test failed I believe.
                            • fmaundefined
                              fma
                              Did you connect GND of both power supplies?
                              • Nxt-1undefined
                                Nxt-1 @fma
                                I did not wire a connection from 5V- to 24V- terminals, however in both supplies the negative rail is connected to ground (mains ground that is) and those are of course wired up. So in a way there is a GND path between both PSU.
                                https://www.meanwell.com/webapp/product/search.aspx?prod=HRPG-200
                                https://www.meanwell.com/webapp/product/search.aspx?prod=RS-25
                                • Nxt-1undefined
                                  Nxt-1 @tomasf
                                  I got myself a couple of 74HC00's to plat with. I assume you you wired your system like this? What value did you use for the pull up?
                                  • SWundefined
                                    SW
                                    Hy, I have an Meanwell PSPA-1000-24 and removed the bridge from the power supply. Then I connected the contacts "Ground" and "PS_on" to the power supply and connect an small 5V power supply (Jumper 5V ext!). If you switch the ATX-Power on (M80) the "PS_on" is connected to the "Ground".
                                    It works fine!
                                    • Nxt-1undefined
                                      Nxt-1 @SW
                                      @sw said in Inverting PS_ON levels:
                                      PSPA-1000-24
                                      A quick glance at your PSU's datasheet shows that it's RC logic is inverted compared to most Meanwell's, thus making it directly compatible with the Duet.
                                      • Nxt-1undefined
                                        Nxt-1 @Nxt-1
                                        I eventually decided to go with a 10K resistor and all seems to work as expected. I will have to get myself a small proto-board and wire things up neatly.
                                        • Nxt-1undefined
                                          Nxt-1
                                          I got wired soldered up the proto-board and decided to use the auxilary 5V from the 24V PSU as I was already using the relevant connector. This results in a layout like below (unused gate input are tied to ground).
                                          The solution is neat and compact, yet as I test it on my machine I find out that the AUXG terminal is not connected to the other grounds (not 240V L-, nor 24V V-). As a result there is to connection between the ground this circuit uses and the ground the duet used for the PS_ON pin. Back to the drawing board I go!
                                          • Nxt-1undefined
                                            Nxt-1
                                            Since the AUXG and RC- terminals are already internally connected according to the datasheet, I decided to add a ring terminal to one of the ground wires I had. That connecting was then connected to V- and now all grounds are connected.
                                            The system works fine now 🙂
