Motor phase disconnected problem?
1.8k
    Veti
    update to the latest 2.03 firmware. DC made a fix for that message i think
      siblues
      I was using 2.03 and he recommended reverting back to 2.02 RC2 and I tried that too with no luck.
        elmoret
        @dc42 - How do you think we should proceed here?
          siblues
          Are you asking me?That is what I am trying to figure out.I was hoping DC42 would chime in since he usually has a quick solution or ways of figuring out if the board is damaged.
            @siblues, please can you do the following:
            1. Make sure you are running either 2.02 stable firmware (not a 2.02beta or 2.02RC version), or 2.03RC2.
            2. Next time this problem occurs, please run M906 without parameters and check that it reports the motor currents are as you set them (1200mA). Also run M913 and check they are at 100%.
            3. Do you have anything connected to the expansion connector?
            4. Do the warning messages mention just phase A and just driver 1? Or more drivers and/or both phases?
              siblues
              6:54:46 PMM906
              Motor current (mA) - X:1500, Y:1500, Z:1500, E:1200:1200, idle factor 30%
              6:54:34 PMError: motor phase A disconnected on drivers 1
              6:57:27 PMM913
              Motor current % of normal - X:100, Y:100, Z:100, E💯100
              6:56:51 PMError: motor phase A disconnected on drivers 1
              I only have the BLTouch connections on the expansion header on heater 3. The X axis motor and extruder motor aren't and haven't given me the error while the Y axis and z axis both have given me the error but I couldn't reproduce the x motor having the issue at the moment.Here is the current software information
              Firmware Version: 2.02RC2(RTOS) (2018-09-07b2)
              WiFi Server Version: 1.22
              Web Interface Version: 1.22.6
              Web Interface by Christian Hammacher
              Licensed under the terms of the GPL v3
              undefined 1 Reply Last reply 24 May 2019, 12:18 Reply Quote 0
                Veti
                so you swapped the wiring. can you swap the motor to make sure its not the motor?
                  siblues
                  It is 3 different motors that are all giving me the message but I can swap the motors if that would make it easier to diagnose?
                    Veti
                    so far you have only shown the error message about phase A on driver 1.
                    does it happen with all phases on all drivers?
                      siblues
                      I was also getting the error message on the Z axis motors but that error message is random and hasn't happened again.The Y axis does it everytime.
                        siblues
                        The motors attempt to move when using DWC but they stutter shaking back and forth. I attempted raising the voltages slightly but it made no difference.
                        undefined 1 Reply Last reply 24 May 2019, 12:56 Reply Quote 0
                          Veti @siblues
                          @siblues said in Motor phase disconnected problem?:
                          6:54:46 PMM906
                          M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          this does not match
                          but you have a M501
                          so please post your overwrite.
                          undefined 1 Reply Last reply 24 May 2019, 22:44 Reply Quote 0
                            dc42 administrators @siblues
                            Common reasons for this:
                            1. Motors not phased correctly. This is serious as it can cause the drivers to be damaged. So check that the motor phases are connected correctly first.
                            2. Bad crimp connection in the motor wires, so that only one phase is being energised.
                            3. Speed and/or acceleration set too high, bearing in mind the steps/mm (higher steps/mm => lower accelerations and speeds possible).
                            4. Weak PSU, so that the voltage drops below 10V when the motors draw current.
                            5. Blown stepper driver.
                            6. Blown motor.
                              siblues @Veti
                              @veti Here is the override and the current was changed to 1500 to test it is set at 1200 usually.
                              @dc42 The motors have been working just fine for a while with that original harness and the harness has since been replaced.The printer has a genuine Meanwell 450watt 12v psu and it only fluctuates .02 volts.Here are the current motor settings for what I have set for speed.
                              M569 P0 S0 ; Drive 0 goes forwards reversed
                              M569 P2 S0 ; Drive 2 goes forwards reversed
                              M92 X80 Y80 Z400 E415 ; Set steps per mm
                              M566 X900 Y900 Z12 E1200 ; Set maximum instantaneous speed changes (mm/min)
                              M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                              M201 X500 Y250 Z250 E2500 ; Set accelerations (mm/s^2)
                              M84 S30 ; Set idle timeout
                              I can check the motor but how would I check for a blown driver and what would cause that to happen all of a sudden?
                              undefined 1 Reply Last reply 25 May 2019, 07:34 Reply Quote 0
                                T3P3Tony administrators @siblues
                                @siblues you can check to see if it's a driver by swapping the motors plugged into a working axis with the not working one. Drivers can get blown when wiring develops intermittent faults in a single phase.
                                  siblues
                                  I had some motors on the way so I tried what Tony mentioned and it was a bad motor.
                                  15 out of 21
