    problem with the Mesh?second print start in the air
    49
    2.6k
    • lui2004undefined
      lui2004
      I dont have touch The homeall.g
      Do i need to change something in homeall.g ?
      this is my homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2 on Thu Apr 11 2019 17:51:12 GMT+0200 (Mitteleuropäische Sommerzeit)
      G91 ; relative positioning
      G1 S1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 S1 X-258 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X10 Y10 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
        What firmware version are you using?
        What do you have in your slicer start and end gcode?
        • Vetiundefined
          Veti
          running a G28 will clear your bed mesh.
          if you want to use the stored heightmap you will need to run G29 S1 after every G28
            Does g28 clear the mesh? I didn't think it does. But I'm really not sure come to think of it.
            • Vetiundefined
              Veti
              @phaedrux said in problem with the Mesh?second print start in the air:
              You are right it does not. i just checked.
              I must have confused it with marlin where it does.
              • Vetiundefined
                Veti @lui2004
                @lui2004
                nevertheless you need a G29 S1 somewhere to load the mesh after powering up your printer.
                • lui2004undefined
                  lui2004
                  Hi
                  The heightmap ist Stored i can open it in my sd-card.
                  Do i need do load G29 S1 every Print i started?if yes i dont have do it
                  • Vetiundefined
                    Veti @lui2004
                    @lui2004
                    no but it is a good idea to do so.
                    it is just a command and does not take up time.
                    • lui2004undefined
                      lui2004
                      Ok i will give it a try
                      Or i insert the gcode in my bed.g to load automatic
                      • PaulHewundefined
                        PaulHew
                        Or put it in your Slicer 'Start GCode', easiest way I find.
                          T3P3Tony administrators
                          I have G29 S1 at the end of my config.g that way it's loaded every time on startup.
                          • lui2004undefined
                            lui2004
                            so the first print after mesh works perfectly but when i start the second the nozzle is to high
                            i have try to send beofor i start the second print G29 S1 but always the nozzle to high
                            Firmwarename: RepRapFirmware for Duet 2 WiFi/Ethernet
                            Firmware Elektronik: Duet WiFi 1.02 or later
                            Firmware Version: 2.02(RTOS) (2018-12-24b1)
                            WiFi Server Version: 1.22
                            Web Interface Version: 1.22.6
                            i hope you can help to solve it
                            • Vetiundefined
                              Veti
                              you do home before each print?
                              • lui2004undefined
                                lui2004
                                yes in my slicer is this starting code
                                G28 ; home all axes
                                  T3P3Tony administrators @lui2004
                                  @lui2004 what is at the end of your files that the slicer is putting in there?
                                  • lui2004undefined
                                    lui2004
                                    I have only G28 i my starting code nothing else
                                    • Vetiundefined
                                      Veti
                                      do check with m122 that mesh bed leveling is still active.
                                      • lui2004undefined
                                        lui2004
                                        @veti said in problem with the Mesh?second print start in the air:
                                        m122
                                        seems active
                                        Bed compensation in use: mesh
                                        Bed probe heights: -0.052 -0.028 0.000 0.000 0.000
                                          Are you able to reproduce this problem without doing an actual print? Or with a "print" comprising just a few lines of GCode taken from a real print?
                                          • lui2004undefined
                                            lui2004
                                            do i need to post gcode from a print ?
