problem with the Mesh?second print start in the air
running a G28 will clear your bed mesh.
if you want to use the stored heightmap you will need to run G29 S1 after every G28 -
Does g28 clear the mesh? I didn't think it does. But I'm really not sure come to think of it.
@phaedrux said in problem with the Mesh?second print start in the air:
You are right it does not. i just checked.
I must have confused it with marlin where it does. -
@lui2004
nevertheless you need a G29 S1 somewhere to load the mesh after powering up your printer. -
Hi
The heightmap ist Stored i can open it in my sd-card.
Do i need do load G29 S1 every Print i started?if yes i dont have do it
@lui2004
no but it is a good idea to do so.
it is just a command and does not take up time. -
Ok i will give it a try
Or i insert the gcode in my bed.g to load automatic
Or put it in your Slicer 'Start GCode', easiest way I find.
I have G29 S1 at the end of my config.g that way it's loaded every time on startup.
so the first print after mesh works perfectly but when i start the second the nozzle is to high
i have try to send beofor i start the second print G29 S1 but always the nozzle to high
Firmwarename: RepRapFirmware for Duet 2 WiFi/Ethernet
Firmware Elektronik: Duet WiFi 1.02 or later
Firmware Version: 2.02(RTOS) (2018-12-24b1)
WiFi Server Version: 1.22
Web Interface Version: 1.22.6i hope you can help to solve it
you do home before each print?
yes in my slicer is this starting code
G28 ; home all axes
@lui2004 what is at the end of your files that the slicer is putting in there?
I have only G28 i my starting code nothing else
do check with m122 that mesh bed leveling is still active.
@veti said in problem with the Mesh?second print start in the air:
m122
seems active
Bed compensation in use: mesh
Bed probe heights: -0.052 -0.028 0.000 0.000 0.000 -
Are you able to reproduce this problem without doing an actual print? Or with a "print" comprising just a few lines of GCode taken from a real print?
do i need to post gcode from a print ?
What I would like a the GCode for a simple sequence that replicates the problem - not a full GCode file that takes a long time to print, but a very simple one that takes only a few seconds.
if you explane me how to do this i will post it
because now i finisched my first print after mesh and the second print is to heigh from the bed
