    RepRapFirmware 2.03RC4 available
    Firmware installation
    10
    25
    2.9k
      Get it at https://github.com/dc42/RepRapFirmware/releases/tag/2.03RC4. This will be the last RC before the 2.03 release unless significant new bugs are reported. Please give your feedback on it in this thread.
      • oliofundefined
        oliof
        Applied cleanly on the CR-20 (cartesian). Starting a test print right now. Compared to 2.03RC2, filament length from gcode generated with PrusaSlicer is shown again (as was discussed elsewhere).
        • oliofundefined
          oliof
          Multi hour print completed without issue on a simple Cartesian printer.
          • avaradusundefined
            avaradus
            Problem with DWC lost connection is stil there
            https://forum.duet3d.com/topic/10164/duet-wifi-lost-web-connection/10
            • boldnutsundefined
              boldnuts
              Ran several long print job's on both my Delta and Cartesian printer's with no issue's to report
              • Bravojulundefined
                Bravojul
                I have tried 2.03RC3 with new PrusaSlicer 2.0. Filament used is not recognized. PrusaSlicer now output:
                ; filament used [mm] = 3363.4
                ; filament used [cm3] = 7.9
                It works if I edit the file before sending it to the printer. I change to :
                ; filament used = 3363.4mm
                Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @Bravojul
                  @bravojul said in RepRapFirmware 2.03RC4 available:
                  But have you tried 2.03RC4?
                  • oliofundefined
                    oliof
                    I can confirm that PrusaSlicer filament length is recognized by RC4
                      dc42 administrators @Bravojul
                      As @Phaedrux says, please test again using 2.03RC4.
                      • Bravojulundefined
                        Bravojul
                        yes it works with RC4. Thanks
                        • wilrikerundefined
                          wilriker
                          Print successful but there was something strange when it entered stop.g. It seems as if the motors were reduced to idle current. They sounded vastly different and the Y motor even stalled (it needs slightly more than idle current to move properly). Upping the idle current and trying again let the motors move normal.
                          Manuel
                          My Tool Collection
                            RRF sets the motors to idle current when a print from SD card terminates. I don't remember whether it does this before or after stop.g is run. I will check tomorrow.
                            • wilrikerundefined
                              wilriker @dc42
                              @dc42 Thanks.
                              Just to clarify: this behavior is new with RC4 so probably when fixing the issue with M0 H1 something got switched in the order of execution.
                              Manuel
                              My Tool Collection
                                dc42 administrators @wilriker
                                @wilriker said in RepRapFirmware 2.03RC4 available:
                                @dc42 Thanks.
                                I just checked the code. The motors are set to idle current after stop.g has been run. So no change there.
                                Of course, if the machine has been idle for more than the idle time when stop.g is run or within stop.g (perhaps because of a command to wait for something to cool down), then ordinary idle current reduction will kick in. But as soon as you move a motor, normal current should be restored.
                                Edit: I've realised what might be happening, and I will fix it in the 2.03 release. Meanwhile, as a workaround, try adding a M400 command at the end of stop.g.
                                wilrikerundefined 2 Replies Last reply Reply Quote 0
                                • wilrikerundefined
                                  wilriker @dc42
                                  @dc42 Thanks. I'll try that - and I think I also how have a clue what's happening. 🙂
                                  Manuel
                                  My Tool Collection
                                  • Cavemanundefined
                                    Caveman
                                    Bed mesh level still the same issue as before. Z0 is all over the place. 2.02 works perfectly???
                                      dc42 administrators @Caveman
                                      @caveman said in RepRapFirmware 2.03RC4 available:
                                      Is this with 2.03RC4 ? Are you getting any warning messages on the console?
                                      Please provide a sequence that reproduces this issue for you, along with all the files needed to reproduce this (config,g, homing files, bed.g if used, and a very short GCode file to print if printing a file has to be part of the sequence).
                                      • Cavemanundefined
                                        Caveman
                                        Whenever I have a wrong Z0 I get the message that the map has a substantial Z offset.....
                                        Sometimes I have a proper Z0
                                        0_1559504666357_2.03RC4meshleveltry_1.jpg 0_1559504682780_Error message_2.03RC4 meshbedlevel.jpg 0_1559504698147_@.03RC4meshbedleveltry_2.jpg
                                          Phaedrux Moderator @Caveman
                                          @caveman How are you homing Z and how are you establishing Z0 before running the mesh compensation routine?
                                          • Gone2Farundefined
                                            Gone2Far
                                            Had some odd leveling behavior on my delta.
                                            Had a quite hard time getting G32 to converge on a particular height, but finally did. Then noticed several aborted probing points when running G29, followed by reports of 4.x mm max height error. After increasing the force needed by the smart effector from default to 128, got a kinda good height map. Now I have to edit the deflection setting in config.g--I had to add +0.15 mm baby step to get first layer correct. Everything was working quite well prior to upgrade.
                                            Original Prusa i3 MK2S
                                            Large Kossel Homebrew
