RepRapFirmware 2.03RC4 available
Multi hour print completed without issue on a simple Cartesian printer.
Problem with DWC lost connection is stil there
https://forum.duet3d.com/topic/10164/duet-wifi-lost-web-connection/10 -
Ran several long print job's on both my Delta and Cartesian printer's with no issue's to report
I have tried 2.03RC3 with new PrusaSlicer 2.0. Filament used is not recognized. PrusaSlicer now output:
; filament used [mm] = 3363.4
; filament used [cm3] = 7.9It works if I edit the file before sending it to the printer. I change to :
; filament used = 3363.4mm
; filament used [cm3] = 7.9 -
@bravojul said in RepRapFirmware 2.03RC4 available:
But have you tried 2.03RC4?
I can confirm that PrusaSlicer filament length is recognized by RC4
; filament used [cm3] = 7.9As @Phaedrux says, please test again using 2.03RC4.
yes it works with RC4. Thanks
Print successful but there was something strange when it entered
stop.g
. It seems as if the motors were reduced to idle current. They sounded vastly different and the Y motor even stalled (it needs slightly more than idle current to move properly). Upping the idle current and trying again let the motors move normal. -
RRF sets the motors to idle current when a print from SD card terminates. I don't remember whether it does this before or after stop.g is run. I will check tomorrow.
@dc42 Thanks.
Just to clarify: this behavior is new with RC4 so probably when fixing the issue withM0 H1
something got switched in the order of execution. -
@wilriker said in RepRapFirmware 2.03RC4 available:
@dc42 Thanks.
something got switched in the order of execution.I just checked the code. The motors are set to idle current after stop.g has been run. So no change there.
Of course, if the machine has been idle for more than the idle time when stop.g is run or within stop.g (perhaps because of a command to wait for something to cool down), then ordinary idle current reduction will kick in. But as soon as you move a motor, normal current should be restored.
Edit: I've realised what might be happening, and I will fix it in the 2.03 release. Meanwhile, as a workaround, try adding a M400 command at the end of stop.g.
@dc42 Thanks. I'll try that - and I think I also how have a clue what's happening.
Bed mesh level still the same issue as before. Z0 is all over the place. 2.02 works perfectly???
@caveman said in RepRapFirmware 2.03RC4 available:
Is this with 2.03RC4 ? Are you getting any warning messages on the console?
Please provide a sequence that reproduces this issue for you, along with all the files needed to reproduce this (config,g, homing files, bed.g if used, and a very short GCode file to print if printing a file has to be part of the sequence).
Whenever I have a wrong Z0 I get the message that the map has a substantial Z offset.....
Sometimes I have a proper Z0
@caveman How are you homing Z and how are you establishing Z0 before running the mesh compensation routine?
Had some odd leveling behavior on my delta.
Had a quite hard time getting G32 to converge on a particular height, but finally did. Then noticed several aborted probing points when running G29, followed by reports of 4.x mm max height error. After increasing the force needed by the smart effector from default to 128, got a kinda good height map. Now I have to edit the deflection setting in config.g--I had to add +0.15 mm baby step to get first layer correct. Everything was working quite well prior to upgrade.
@dc42 said in RepRapFirmware 2.03RC4 available:
I can now confirm that this solves the issue.
Homing z happens by pressing home all. Establishing z0 happens by a papercheck.
