    Extrusion issues
    1.1k
    • peter247undefined
      peter247
      What extruder do you have and stepper motor do you have ?
      I would say that printing slow you are just over extruding because your steps per mm are too high or low ( I will have to think about that one), have you set it up for the wrong stepper motor ? eg 0.9deg motor when it`s a 1.8deg motor so if you extruded very slow you would get 200mm.
      AND when you try to print too fast your extruder rips into the filament and slips, too much pressure at the nozzle with twice the correct amount.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      kmhudginsundefined 1 Reply Last reply Reply Quote 0
        dc42 administrators @kmhudgins
        @kmhudgins, when you extrude at 5mm/sec, does the extruder motor skip steps?
        Are you certain that your hot end thermistor is set up correctly in the M305 P1 command in config.g? Perhaps the nozzle is not as hot as you need it to be able to extrude at 5mm/sec.
        • kmhudginsundefined
          kmhudgins @peter247
          @peter247 I will look in to the stepper moters a am not sure i got the data for the set up form someone else. so i will verify that.
          peter247undefined 1 Reply Last reply Reply Quote 0
            kmhudgins @dc42
            @dc42 yes it does. as fare as my g code goes the heater g code is shown below i am completely new to the working with g code and am not sure if it is correct or not
            M305 P0 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 0
            M305 P1 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 1
            • Vetiundefined
              Veti
              those are the default configurator settings and are therefore almost certainly wrong.
              what thermistors do you have?
                kmhudgins @Veti
                @veti I am not sure. what ever comes on the ender 3 pro.
                • Vetiundefined
                  Veti @kmhudgins
                  @kmhudgins
                  see
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37?lang=en
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38?lang=en
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39?lang=en
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40?lang=en
                    kmhudgins @Veti
                    @veti thank you im running through those right now
                    • peter247undefined
                      peter247 @kmhudgins
                      @kmhudgins If you are using this page to set up :-
                      https://e3d-online.dozuki.com/Guide/Titan+Aero+RepRap+Firmware+Configuration/41?lang=en
                      this is o.k for a stepper motor with 400 steps per turn eg 0.8 deg , BUT you may have and most likely have a 200 steps 1.8 deg motor , so for a start half than 840 steps per mm
                        kmhudgins
                        Thank you i got the extrusion issues fixed i believe thanks for all the help everyone
                          What did it end up being?
                            kmhudgins @Phaedrux
                            @phaedrux my esteps were way off i used a profile that some one else set up and it did not seem to work very well for me. so I fallowed the configuration guide the duet has and was able to get much closer to the actual number. with a little more tweaking i have gotten the esteps to a acceptable standard
