Extrusion issues
@kmhudgins, when you extrude at 5mm/sec, does the extruder motor skip steps?
Are you certain that your hot end thermistor is set up correctly in the M305 P1 command in config.g? Perhaps the nozzle is not as hot as you need it to be able to extrude at 5mm/sec.
@peter247 I will look in to the stepper moters a am not sure i got the data for the set up form someone else. so i will verify that.
@dc42 yes it does. as fare as my g code goes the heater g code is shown below i am completely new to the working with g code and am not sure if it is correct or not
M305 P0 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C -
those are the default configurator settings and are therefore almost certainly wrong.
what thermistors do you have? -
@veti I am not sure. what ever comes on the ender 3 pro.
@kmhudgins
see
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37?lang=en
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38?lang=en
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39?lang=en
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40?lang=en -
@veti thank you im running through those right now
@kmhudgins If you are using this page to set up :-
https://e3d-online.dozuki.com/Guide/Titan+Aero+RepRap+Firmware+Configuration/41?lang=en
this is o.k for a stepper motor with 400 steps per turn eg 0.8 deg , BUT you may have and most likely have a 200 steps 1.8 deg motor , so for a start half than 840 steps per mm
Thank you i got the extrusion issues fixed i believe thanks for all the help everyone
What did it end up being?
@phaedrux my esteps were way off i used a profile that some one else set up and it did not seem to work very well for me. so I fallowed the configuration guide the duet has and was able to get much closer to the actual number. with a little more tweaking i have gotten the esteps to a acceptable standard
