    Extrusion issues
    1.1k
    • kmhudginsundefined
      kmhudgins @peter247
      @peter247 I will look in to the stepper moters a am not sure i got the data for the set up form someone else. so i will verify that.
      peter247undefined 1 Reply Last reply Reply Quote 0
        kmhudgins @dc42
        @dc42 yes it does. as fare as my g code goes the heater g code is shown below i am completely new to the working with g code and am not sure if it is correct or not
        M305 P0 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 0
        M305 P1 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 1
        • Vetiundefined
          Veti
          those are the default configurator settings and are therefore almost certainly wrong.
          what thermistors do you have?
          kmhudginsundefined 1 Reply Last reply Reply Quote 0
            kmhudgins @Veti
            @veti I am not sure. what ever comes on the ender 3 pro.
            • Vetiundefined
              Veti @kmhudgins
              @kmhudgins
              see
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37?lang=en
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38?lang=en
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39?lang=en
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40?lang=en
                kmhudgins @Veti
                @veti thank you im running through those right now
                • peter247undefined
                  peter247 @kmhudgins
                  @kmhudgins If you are using this page to set up :-
                  https://e3d-online.dozuki.com/Guide/Titan+Aero+RepRap+Firmware+Configuration/41?lang=en
                  this is o.k for a stepper motor with 400 steps per turn eg 0.8 deg , BUT you may have and most likely have a 200 steps 1.8 deg motor , so for a start half than 840 steps per mm
                  Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                    kmhudgins
                    Thank you i got the extrusion issues fixed i believe thanks for all the help everyone
                      What did it end up being?
                        kmhudgins @Phaedrux
                        @phaedrux my esteps were way off i used a profile that some one else set up and it did not seem to work very well for me. so I fallowed the configuration guide the duet has and was able to get much closer to the actual number. with a little more tweaking i have gotten the esteps to a acceptable standard
