    Attempting to extrude with no tool selected - During Print
    44
    3.1k
    • jaurandundefined
      jaurand @dc42
      @dc42 said in Attempting to extrude with no tool selected - During Print:
      M575 P1
      Yep requires check sum
      M575 P1
      Channel 1: baud rate 57600, requires checksum
        We had situations a few years ago in which commands from PanelDue were getting corrupted and causing printing to stop. That's why we set the port to require a valid checksum. Unfortunately it's only and 8-bit checksum, so errors can still get through. In case this is causing the problem, I suggest you test whether the problem goes away if you disconnect the PanelDue. If it does, then check the PanelDue cable for a bad connection. The resistance of the cable must be not more than 0.1 ohm per conductor.
        jaurandundefined 1 Reply Last reply Reply Quote 1
        • jaurandundefined
          jaurand @dc42
          @dc42 i was wondering to myself if it could be the paneldue. I do get some checksum errors still passed on. I'll try out next week a few more prints to see if that it and test the resistance.
            dc42 administrators @jaurand
            @jaurand said in Attempting to extrude with no tool selected - During Print:
            Checksum errors suggest that there is a problem with the PanelDue to Duet link. For every 255 checksum errors reported, there is probably 1 case of data corruption that isn't detected and may cause problems.
            What microstepping settings are you using? It's possible the use of high microstepping could increase interrupt latency and give rise to data reception errors. the 2.03 firmware series has some changes to help avoid this happening. So you could upgrade your firmware to 2.03RC4 and see whether the checksum errors reduce or go away.
            jaurandundefined 2 Replies Last reply Reply Quote 0
            • jaurandundefined
              jaurand @dc42
              @dc42 Tested connectors on paneldue and all are below 0.1 ohms. Currently unplugged paneldue and printing will see if any issues arise.
              I am only running X16 microstepping with interpolation at the moment as my motors are stock with the printer and I did not have very detailed information regarding the specs.
              • jaurandundefined
                jaurand @dc42
                @dc42 No issues with the print from tool selection with paneldue unplugged. I'll look into updating the firmware next and determine if this reduces the checksum errors
                • jaurandundefined
                  jaurand
                  upgraded to 2.03RC5 and still getting checksum errors
                    What sort of cable do you have between the PanelDue and the Duet? Is it running close to stepper motor wires for any appreciable distance?
                    • jaurandundefined
                      jaurand
                      I'm running the 4 pin wire. The cable is not close to any stepper motor wires
                        It sounds to me like a signal quality issue, but it could possibly be caused by an overloaded MCU. Are you using unusually high microstepping?
                        jaurandundefined 1 Reply Last reply Reply Quote 0
                        • jaurandundefined
                          jaurand @dc42
                          @dc42 just x16 with interpolation
                            I am surprised you are getting checksum errors. I don't recall seeing see any reported on my delta for over a year, and the PanelDue cable is about 1.3m long.
                            You could try reducing the baud rate to 38400 or 19200 at both ends, to see if the checksum errors go away.
                            • jaurandundefined
                              jaurand @dc42
                              @dc42 dropped the baud rate and still had check sum errors. also to note I had lost the ability to baby step with upgrading firmware to 2.03RC5 so i have gone back to 2.02 and able to baby step there
                              Scachiundefined 1 Reply Last reply Reply Quote 0
                              • Scachiundefined
                                Scachi @jaurand
                                @jaurand I had a lot of checksum errors too. I tried to get rid of this by mounting the duet wifi board to a different location on my printer, changing the baud rate, using different cables for the paneldue, mounting the paneldue to a different location.
                                Searching the forum/wiki I found that twisting the wires of the endstop cables can fix it and It looks like this did the trick. No more checksum errors here.
                                My x&y endstop cables are very close to (directly above of) one of my stepper motors: https://www.thingiverse.com/thing:3667947
                                • THaalaundefined
                                  THaala
                                  same problems on my printer.
                                  After Update to 2.03 and Panelue 1.23 i got a lot of checksum errors. I didnt have seen this before (2.0 beta) with 115200 Baud.
                                  Reducing raudrate to 9600 reduces the amout of errors a bit but not much.
                                  Software <= 2.0 beta have never shown such checksum errors.
                                  The problem with "attemepting to extrude with no tool selected" during print i have seen on time destroying a 13 hours print.
                                  BR,
                                  Thilo
                                    You should not have such a high error rate. One cause could be that the PanelDue cables are running along the printer frame, and you haven't grounded both the printer frame and the negative output form the power supply. That causes the printer frame to carry noise from stepper motors and heater switching, which is coupled into the cable.
                                    I have a 1.5m cable between the Duet and PanelDue on my delta, and I get zero error reports.
                                    bernie-mixundefined 1 Reply Last reply Reply Quote 0
                                      With PanelDue firmware 1.23 I started to get some checksum errors as well. I had previously noticed some screen flicker. So I decided to replace the cable with a new recrimped one and now everything is fine again. No screen flicker, no checksum errors. My frame is grounded as well as the DC- of the PSU.
                                      Perhaps some of the newer features in 1.23 are exacerbating existing poor cabling.
                                      • bernie-mixundefined
                                        bernie-mix @dc42
                                        I have grounded my printer frame with the ground of 220V power outlet. Should I disconnect this grounding and instead connect the frame to the negative of the power supply output? Or must this connection persist and additionally the negative output connect to the frame?
                                          dc42 administrators @bernie-mix
                                          @bernie-mix said in Attempting to extrude with no tool selected - During Print:
                                          Unless you use the USB connection regularly, it's best to connect the frame to mains ground and also connect the negative PSU output to mains ground. But if/when you use the USB connection, see https://duet3d.dozuki.com/Wiki/USB_ground_loops.
                                          • jaurandundefined
                                            jaurand @Scachi
                                            @scachi I finally got around to checking the stepper motor cables. I recrimped my second z motor and bam no more check sum errors. Thank you!
