    Very strange behavior, CoreXY with external drivers
    2.8k
      That looks OK too. So I think it's either very obscure firmware error or a short-circuit between those two signals (see my earlier message).
      Capricornundefined 1 Reply Last reply Reply Quote 0
      • Capricornundefined
        Capricorn @dc42
        to clarify how my extern drivers are connected:
        all Step+/Dir+ from the ext. drivers go to +5V.
        all Step-/Dir- from the ext. drivers go to the corresponding pins on the breakout board
        dc42undefined jhonf441undefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @Capricorn
          @capricorn said in Very strange behavior, CoreXY with external drivers:
          That sounds good.
          Are you using G1 S2 moves (after sending G91 to select relative axis coordinates) to test the motors individually?
            Capricorn @dc42
            yes, i did, x and z go together and i can´t find a shortcut...
            i also tried to redirect z to drive 8 or 9. Same behavior...
              1. Do any other motors move when you command the Y motor?
              2. Please check that you really do have +5V on the common 5V feed to the + inputs of the stepper drivers.
              Capricornundefined 2 Replies Last reply Reply Quote 0
                Capricorn @dc42
                no other motors affected by moving Y.
                the Voltage at the + inputs of the drivers is 4.56 V
                  Capricorn @dc42
                  meanwhile i tested another driver for z-motor (have more of them as spare) and also testet to set the
                  config to cartesian kinematiks. No luck, always x/z move together.... I´m frustrated....
                    Capricorn @Veti
                    @veti
                    thank you, for your help, i´m just about cabling the printer. i can test it, when everything else is running.
                      Are you sure that the power to your external stepper drivers is stable? I am wondering whether when they are driving the motors, the voltage could be dropping.
                        Capricorn @dc42
                        i test that... but i think so, cause i serve 5V to the board with a extern 50W power supply
                          Capricorn @dc42
                          testet, konstant 4.45V. I take the 5V from the breakout board. Should i take it from the main board?
                          Or direct of the power supply?
                            @capricorn, I mean the main power to your external stepper drivers - 12V, 24V, 36V or whatever you are using.
                            • Vetiundefined
                              Veti
                              how do you wire the two power supplies? i think the negative needs to be connected between the two, but i am not 100% sure.
                                Capricorn @dc42
                                konstant 41V motors driving , i´m using a 600W power supply
                                • Vetiundefined
                                  Veti
                                  i dont think 41v is supported
                                  https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
                                  The Duet 2 (Wifi and Ethernet) work with a VIN supply of between 11V and 25V
                                    Capricorn @Veti
                                    @veti
                                    i don´t think so....
                                      Capricorn @Veti
                                      @veti
                                      this is the power for the external motor drivers, not to the duet2
                                      • Vetiundefined
                                        Veti @Capricorn
                                        @capricorn
                                        please draw a diagram. this is getting confusing.
                                        including all power supplies and the wires between them.
                                          Capricorn @Veti
                                          @veti
                                          that´s easy.
                                          12V and 5V go to the duet2
                                          41V go to the external motor drivers
                                          • Vetiundefined
                                            Veti
                                            and how are the power supplies connected to each other?
