    Very strange behavior, CoreXY with external drivers
    2.8k
    • Capricornundefined
      Capricorn @dc42
      to clarify how my extern drivers are connected:
      all Step+/Dir+ from the ext. drivers go to +5V.
      all Step-/Dir- from the ext. drivers go to the corresponding pins on the breakout board
      dc42undefined jhonf441undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Capricorn
        @capricorn said in Very strange behavior, CoreXY with external drivers:
        That sounds good.
        Are you using G1 S2 moves (after sending G91 to select relative axis coordinates) to test the motors individually?
        Capricornundefined 1 Reply Last reply Reply Quote 0
          Capricorn @dc42
          yes, i did, x and z go together and i can´t find a shortcut...
          i also tried to redirect z to drive 8 or 9. Same behavior...
            1. Do any other motors move when you command the Y motor?
            2. Please check that you really do have +5V on the common 5V feed to the + inputs of the stepper drivers.
            Capricornundefined 2 Replies Last reply Reply Quote 0
              Capricorn @dc42
              no other motors affected by moving Y.
              the Voltage at the + inputs of the drivers is 4.56 V
                Capricorn @dc42
                meanwhile i tested another driver for z-motor (have more of them as spare) and also testet to set the
                config to cartesian kinematiks. No luck, always x/z move together.... I´m frustrated....
                  Capricorn @Veti
                  @veti
                  thank you, for your help, i´m just about cabling the printer. i can test it, when everything else is running.
                    Are you sure that the power to your external stepper drivers is stable? I am wondering whether when they are driving the motors, the voltage could be dropping.
                      Capricorn @dc42
                      i test that... but i think so, cause i serve 5V to the board with a extern 50W power supply
                        Capricorn @dc42
                        testet, konstant 4.45V. I take the 5V from the breakout board. Should i take it from the main board?
                        Or direct of the power supply?
                          @capricorn, I mean the main power to your external stepper drivers - 12V, 24V, 36V or whatever you are using.
                          • Vetiundefined
                            Veti
                            how do you wire the two power supplies? i think the negative needs to be connected between the two, but i am not 100% sure.
                              Capricorn @dc42
                              konstant 41V motors driving , i´m using a 600W power supply
                              • Vetiundefined
                                Veti
                                i dont think 41v is supported
                                https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
                                The Duet 2 (Wifi and Ethernet) work with a VIN supply of between 11V and 25V
                                  Capricorn @Veti
                                  @veti
                                  i don´t think so....
                                    Capricorn @Veti
                                    @veti
                                    this is the power for the external motor drivers, not to the duet2
                                    • Vetiundefined
                                      Veti @Capricorn
                                      @capricorn
                                      please draw a diagram. this is getting confusing.
                                      including all power supplies and the wires between them.
                                        Capricorn @Veti
                                        @veti
                                        that´s easy.
                                        12V and 5V go to the duet2
                                        41V go to the external motor drivers
                                        • Vetiundefined
                                          Veti
                                          and how are the power supplies connected to each other?
                                            Capricorn @Veti
                                            @veti
                                            this are 3 different power supplies. one end each to 220V the other end to the 5v/12v input duet2 and 41v to the motor drivers. No direct connection (except 220V) between them.
