    Very strange behavior, CoreXY with external drivers
    2.8k
      1. Do any other motors move when you command the Y motor?
      2. Please check that you really do have +5V on the common 5V feed to the + inputs of the stepper drivers.
      Capricornundefined 2 Replies Last reply Reply Quote 0
      • Capricornundefined
        Capricorn @dc42
        no other motors affected by moving Y.
        the Voltage at the + inputs of the drivers is 4.56 V
          Capricorn @dc42
          meanwhile i tested another driver for z-motor (have more of them as spare) and also testet to set the
          config to cartesian kinematiks. No luck, always x/z move together.... I´m frustrated....
            Capricorn @Veti
            @veti
            thank you, for your help, i´m just about cabling the printer. i can test it, when everything else is running.
              Are you sure that the power to your external stepper drivers is stable? I am wondering whether when they are driving the motors, the voltage could be dropping.
                Capricorn @dc42
                i test that... but i think so, cause i serve 5V to the board with a extern 50W power supply
                  Capricorn @dc42
                  testet, konstant 4.45V. I take the 5V from the breakout board. Should i take it from the main board?
                  Or direct of the power supply?
                    dc42 administrators @Capricorn
                    @capricorn, I mean the main power to your external stepper drivers - 12V, 24V, 36V or whatever you are using.
                    • Vetiundefined
                      Veti
                      @capricorn said in Very strange behavior, CoreXY with external drivers:
                      how do you wire the two power supplies? i think the negative needs to be connected between the two, but i am not 100% sure.
                      Capricornundefined 1 Reply Last reply Reply Quote 0
                        Capricorn @dc42
                        konstant 41V motors driving , i´m using a 600W power supply
                        • Vetiundefined
                          Veti
                          i dont think 41v is supported
                          https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
                          The Duet 2 (Wifi and Ethernet) work with a VIN supply of between 11V and 25V
                            Capricorn @Veti
                            @veti
                            i don´t think so....
                              Capricorn @Veti
                              @veti
                              this is the power for the external motor drivers, not to the duet2
                              • Vetiundefined
                                Veti @Capricorn
                                @capricorn
                                please draw a diagram. this is getting confusing.
                                including all power supplies and the wires between them.
                                  Capricorn @Veti
                                  @veti
                                  that´s easy.
                                  12V and 5V go to the duet2
                                  41V go to the external motor drivers
                                  • Vetiundefined
                                    Veti
                                    and how are the power supplies connected to each other?
                                      Capricorn @Veti
                                      @veti
                                      this are 3 different power supplies. one end each to 220V the other end to the 5v/12v input duet2 and 41v to the motor drivers. No direct connection (except 220V) between them.
                                      • Vetiundefined
                                        Veti
                                        see this for the wiring of the duex
                                        https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                                        the entire wiring is about avoiding current flow between gnd connections.
                                        and in your case you have several non connected gnd connections.
                                          Capricorn @Veti
                                          @veti
                                          not suitable for me, because i have no duex2 oder duex5 board. i have the duet2 ethernet and the expansion breakout bord. the breakout board is only connected by the 50Pin connector
                                          • Vetiundefined
                                            Veti
                                            it would still cause a grounding loop.
                                            https://en.wikipedia.org/wiki/Ground_loop_(electricity)
                                            there is also a very specific warning for the duet where you have a separate 5v supply via usb.
                                            see
                                            https://duet3d.dozuki.com/Wiki/USB_ground_loops
