    Silicone Heater
    24
    2.2k
      dc42 administrators @jhonf441
      @jhonf441 said in Silicone Heater:
      Hello, i have looked for a 110V fuse but I can not find it, my question is if I use a 1800W heater at 110V I could use a 250V to 10A fuse ...
      1800W at 110V is 1800/110 amps, which is a lot more than 10A. So no.
      Do you really need 1800W? How large is the bed?
      jhonf441undefined 1 Reply Last reply Reply Quote 0
      • gorf26undefined
        gorf26
        On mine the heat pad is 330 x 330 110volt
        haven't hooked it up yet but working on it now want to be safe...
        Thanks gary
        • mrehorstdmdundefined
          mrehorstdmd @jhonf441
          @jhonf441 fuses are selected based on current, TCOs based on current and temperature.
          An 1800W heater is going to take 16A, so you'd need a fuse rated for at least 20A.
          A TCO has to be rated to handle the current you'll be pulling through it, so again at least 20A. They usually self-heat, too, so if you want the bed to operate at 100C you have to get a TCO that's rated for a temperature higher than 100C. Check the data sheet of the TCO for the formula to calculate the TCO operating temperature based on current draw (16A) and your bed's operating temperature.
          1800W is a lot of power to pull from a 117VAC outlet. Are you going to blow a circuit breaker?
          Surgikillundefined 1 Reply Last reply Reply Quote 0
          • gorf26undefined
            gorf26
            Would this one be OK?
            https://www.digikey.com/product-detail/en/SDF+DF152S/317-1136-ND/1014765/?itemSeq=294889851
            Thanks gary
              Phaedrux Moderator @gorf26
              @gorf26 said in Silicone Heater:
              Thanks gary
              That looks ok provided you won't be using bed temps of 120c on a regular basis.
              Holding Temperature 128°C (262°F)
              Rated Functioning Temperature 152°C (306°F)
              gorf26undefined 1 Reply Last reply Reply Quote 0
              • jhonf441undefined
                jhonf441 @dc42
                Hello, they are actually 1800/110 amps, but I had calculated 1800 / 250A and approached the commercial value available at 10A so the fuse I find is at 250v, the bed is 600mmx570mm I had already read about 0.4W per square cm but that was according to what I read for beds 4mm thick and aluminum, I have 8mm thick stainless steel, and the reason is that I had enough problems with aluminum, I did not get it was completely flat or curved when heate.
                The size of the silicone heater is made to the same extent as the bed.
                • gorf26undefined
                  gorf26 @Phaedrux
                  No I use 60°C so should be good then
                  thanks gary
                  • Surgikillundefined
                    Surgikill @mrehorstdmd
                    @mrehorstdmd I just put an AC heater on my printer. I'm looking for fuses and a TCO. Can you point me to any? It's a 110V/1100 watt heater, so I'm thinking 12a fuse.
                    I'm looking at this for a TCO. A little pricey but seems like it would fit the bill.
                    https://www.digikey.com/product-detail/en/cantherm/L5015224DELB0XE/317-1557-ND/3135080
                      Phaedrux Moderator @Surgikill
                      @surgikill said in Silicone Heater:
                      A little pricey
                      You might be able to find the same part at a different reseller. Digikey encourages selling in bulk. Check for any regional electronics outfits that may carry them or something similar.
                      If you're in Canada, check https://www.be-electronics.com/searchresults.asp?Search=thermal+cut+off&Submit=
                      • gtj0undefined
                        gtj0
                        These are the ones I use...
                        99C : https://smile.amazon.com/gp/product/B07K358CKK/
                        or
                        128C : https://smile.amazon.com/gp/product/B0195UX2KA/
                        • sinned6915undefined
                          sinned6915
                          Deler-
                          I have Ali Rubber heater, 800W, 350x350. I know, crazy stupid big, I ordered from the printer BOM before I understand what I do now. Its been great. I honestly don't go over 100C. I know a bunch of people who swear by them and their service.
                          I dont understand how the Keenvo are better other than their marketing- its a resistance heater with nichrome wires.
                          suggestions- get it made with a couple of holes for post install thermistor or thermal fuse additions later.
                          you CAN fix a nicked heater wire by carefully excavating and wire wrapping the ends and covering in RTV.
                          and dont forget supplemental ground to the bed.
                          Delerundefined 1 Reply Last reply Reply Quote 0
                          • Delerundefined
                            Deler @sinned6915
                            thanks @sinned6915 I will definitely check Ali Rubber heater
