Ender 3 Pro and Duet Maestro Guide
Example setups and prints
2.1k
    I've been working on a 4 part step by step guide to upgrading an Ender 3 Pro with the Duet 2 Maestro board, covering wiring, generating a config file set, commissioning the hardware, and doing some basic calibration to get started with good prints.
    Hopefully this will be helpful to anyone doing a similar upgrade. Even if it's a different printer than the Ender 3, it's generally applicable to adapting any printer to use a Duet.
    Future guides will go over adding a BLTouch, replacing 24v fans with 12v fans, adding LED strip, using mesh bed compensation, adding a PanelDue, etc. So stay tuned for that.
    Thanks to everyone who's already provided feedback.
    Check it out here:
    Ender 3 Pro and Duet Maestro Guide Part 1: Wiring
    Ender 3 Pro and Duet Maestro Guide Part 2: Configuration
    Ender 3 Pro and Duet Maestro Guide Part 3: Commissioning
    Ender 3 Pro and Duet Maestro Guide Part 4: Calibration
    Ender 3 Pro and Duet Maestro Guide Part 5: Upgrades
    Config file examples available here: https://github.com/x0rtrunks/Ender3DuetMaestroConfigs
    undefined 1 Reply Last reply 11 Jun 2019, 21:46 Reply Quote 7
      oliof
      I'll compare with my CR-20 conversion (basically an Ender 3 with a nicer control box) and see if I can expand (-:
        T3P3Tony administrators @Phaedrux
        @phaedrux looking great!
          kmhudgins
          this was very help full to my set up thank you
            PaulHew
            Really good guide, wish it was around when I did my conversion.
            I still refer to it now if I am unsure and want to double check a setting.
            Would it be worth putting a bit in about configuring Cura and adding the Duet RepRapFirmware plugin?
              PaulHew
              Just been going through it and found that a link was wrong.
              In the section 'Bed Level Verification Print', the link is the same as the one in 'Extrusion Factor Test Print (Method 1) '
              There is this one..... https://www.thingiverse.com/thing:3235018 which is CHEP's bed levelling routine.
              undefined 1 Reply Last reply 12 Jun 2019, 16:09 Reply Quote 0
                Phaedrux Moderator @PaulHew
                @paulhew said in Ender 3 Pro and Duet Maestro Guide:
                The link in the guide is correct, there are two STL files included, a cube and the bed level pattern. https://www.thingiverse.com/thing:3670991
                undefined 1 Reply Last reply 12 Jun 2019, 18:36 Reply Quote 0
                  PaulHew @Phaedrux
                  @phaedrux Apologies, I did not realise there were 2 files in the download, I was going by the pictures.
                  Paul.
                  undefined 1 Reply Last reply 12 Jun 2019, 19:13 Reply Quote 0
                    Paul.
                    I've updated the description and title of the thingiverse page to more clearly indicate there are 2 files.
                    At the end of the calibration guide there are links to complete Cura and PrusaSlicer profiles.
                    I didn't want to get too in depth with software specifics since things change very rapidly and it would become hard to maintain. The profiles include the printer setup and the print settings. So it's a pretty good starting point.
                      oliof
                      I had hoped to use your mount in the CR20 but it looks like there is not enough clearance to plug the cables in if I do due to the flat profile of the underbed enclosure )-;
                      I will need to find the time to redesign it -- it's probably enough to increase the diameter of the mount holes so they fit around the metal standoffs integrated into the enclosure.
                      I will most certainly also move diet board back a centimeter or two for clearance from the front plate as I don't plan to expose the micro SD or USB ports directly.
                        PaulHew
                        @Phaedrux Looking forward to the BL Touch setup .... as there is definately a P.I.C.N.I.C issue with my printer!!!
                        (Problem In Chair Not In Computer)!
                        undefined 1 Reply Last reply 16 Jun 2019, 21:35 Reply Quote 0
                          lodger @PaulHew
                          @paulhew and @Phaedrux I will upgrade my second ender to a Bl Touch next week i can send ? take picture if you need any.
                          undefined 1 Reply Last reply 17 Jun 2019, 02:19 Reply Quote 0
                            Phaedrux Moderator @lodger
                            @lodger I'd certainly like to hear your impressions.
                            undefined 1 Reply Last reply 17 Jun 2019, 05:32 Reply Quote 0
                              lodger @Phaedrux
                              @phaedrux I swapped the first ender last week from a probe, Was so easy . Hardest part is making the extention cable up. And we can all do them tiny crimps now lol. the Maestro and a version 3 just work so well.
                              • CADZundefined
                                CADZ
                                Helped me a lot in replacing controlboard. Thanks a lot for all your effort
                                  Part 5 is now available and covers some upgrade options, including swapping the lead screw, adding a BLTouch, adding a buck converter for 12v accessories, adding LED lighting, swapping out the fans, etc.
                                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54
