rfm - RepRapFirmware FileManager [duetbackup successor]
83
10.3k
    wilriker
    I have already mentioned it in the duetbackup thread that I am working on a largely extended version of it and here it is. I call it
    It can be used to perform all file and directory actions available via RepRapFirmware's HTTP interface.
    Usage
    $ ./rfm help
    rfm provides a command-line interface to perform file actions
    against the HTTP interface of a device running RepRapFirmware.
    Usage:
    rfm <command> [arguments]
    Each command will at least expect the argument -domain which
    specifies where on the network the device is located. This can
    either be a resolvable hostname or an IPv4 address.
    The commands are:
    backup Backup a given directory on the device
    upload Upload local files/directories to the device
    mkdir Create a new directory on the device
    mv Rename/move a file/directory on the device
    rm Remove a file/directory on the device
    download Download a single file from the device
    fileinfo Get information on a file
    ls Show the file tree of a given path
    Use "rfm <command> -help" for more information about a command's
    arguments.
    Notes
    • With the release of this tool duetbackup will be deprecated and discontinued
    • Watch this thread for announcements of new releases
    • Give any feedback here - whether bugs you found or possible changes
    Source
    As usual this is open source and (as usual for me) it is implemented in Go. Sources as well as releases can be found at GitHub and the Releases page respectively.
    Manuel
    My Tool Collection
    undefined 1 Reply Last reply 12 Jun 2019, 17:43 Reply Quote 7
      Danal
      Yay! Keep these things going...
        wilriker
        Release v1.0.0-RC1
        I have released v1.0.0-RC1 that implements all of the above commands but might still contain some (hopefully) minor issues.
        For those coming from duetbackup the sub-command rfm backup will do what duetbackup did before.
        Please let me know about all issues you find. These also might include where the output is confusing/insufficient.
        Manuel
        My Tool Collection
          Dougal1957 @wilriker
          @wilriker is this release just for windows at the moment?
          undefined 1 Reply Last reply 12 Jun 2019, 18:40 Reply Quote 0
            Nxt-1
            I would like the express my interest in this awesome project. The RPi that accompanies my printer is perfect to make scheduled backups.
            Duet3D and delta printer enthousiast. Buildlog
            Looking for Duet3D configuration support, check out Nxt-3D
            undefined 1 Reply Last reply 12 Jun 2019, 18:44 Reply Quote 0
              gtj0
              I'm sorry but you don't have enough "R"s or "F"s in there. Should be "rrffm" 🙂
              undefined 1 Reply Last reply 12 Jun 2019, 18:41 Reply Quote 0
                wilriker @Dougal1957
                @dougal1957 No, it's for the same platforms asduetbackup was, i.e. Windows, Linux and Mac amd64 as well as Linux arm (e.g. Raspberry Pi) and arm64 (some other SBC boards).
                Manuel
                My Tool Collection
                  wilriker @gtj0
                  @gtj0 Believe me, you don't want that. 😂 It was the working title while development. It's a PITA to type and typo guarantee. 😁
                  P.S.: a friend of mine asked if I can somehow get a "t" in there and some letter swapping to get rtfm. 😂
                  Manuel
                  My Tool Collection
                  undefined 1 Reply Last reply 12 Jun 2019, 18:45 Reply Quote 0
                    wilriker @Nxt-1
                    @nxt-1 I also use a RPi to perform the backups. In case you have Arch Linux running on your Pi: I plan to make an AUR package as well.
                    Manuel
                    My Tool Collection
                      gtj0 @wilriker
                      @wilriker said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                      P.S.: a friend of mine asked if I can someone get a "t" in there and some letter swapping to get rtfm. 😂
                      That was going to be my next suggestion.
                      undefined 1 Reply Last reply 12 Jun 2019, 19:06 Reply Quote 0
                        wilriker @gtj0
                        @gtj0 said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                        Feel free to fork and rename it. 😂
                        Manuel
                        My Tool Collection
                          mloidl
                          Hi @wilriker,
                          Found a small "issue".
                          If rfm is called with no arguments (I know it should not called with no args), the program exit with panic because of an invalid array access (function args). Better would be to show a proper message.
                          Further tests are outstanding. I had not the time to test it yet.
                          Regards,
                          Martin
                          undefined 1 Reply Last reply 13 Jun 2019, 08:01 Reply Quote 0
                            wilriker @mloidl
                            @mloidl Thanks! I fixed it in the source code and it will be in the next release.
                            Probably also in the next release will be a couple of changes
                            • Parameters relevant for connection (i.e. domain, port and password) can be put into a file in the user's home directory so they don't have to be provided on the command line everytime
                            • Some parameters that are currently given as -parametername value will be shortened to just value but then have to follow a strict ordering in case there is more than one (this resembles more common CLI tools)
                            • Adding help pages similar to the main help output for sub-commands
                            Manuel
                            My Tool Collection
                              mloidl
                              @wilriker thanks for the quick fix.
                              Regarding config file for connection parameter:
                              For users having multiple duet-based printers it would be cool to to store all these connections settings domain, port and password in a kind of connection group.
                              e.g.
                              [printer1]
                              domain=<printer1-ip>
                              port=<printer1-port>
                              password=<printer1-pw>
                              [printer2]
                              Usage then could be rfm -device printer1 <cmd>
                              I did something similar in a python-based backup script for my daily backups and found this very useful.
                              What's your opinion about this?
                              undefined 1 Reply Last reply 13 Jun 2019, 08:30 Reply Quote 1
                                wilriker @mloidl
                                @mloidl I like that and will implement something like this. But even though I listed it first it's currently last in priority. 😉
                                Manuel
                                My Tool Collection
                                  T3P3Tony administrators
                                  @wilriker My vote goes for RepRapFirmware Total File Manager
                                  undefined 1 Reply Last reply 13 Jun 2019, 09:39 Reply Quote 2
                                    wilriker @T3P3Tony
                                    @t3p3tony said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                    Yeah, that's what I thought of, too. 😂
                                    Also another good idea might be
                                    "[File-]Resource Manager for RepRapFirmware-based Filesystems" -> rm-rf 🤣
                                    (Windows user's probably won't get this one)
                                    Manuel
                                    My Tool Collection
                                    deckingmanundefined 1 Reply Last reply 13 Jun 2019, 11:10 Reply Quote 5
                                    • OBELIKSundefined
                                      OBELIKS
                                      You are evil! I wonder if anyone would even dare to use the tool in Linux then.
                                      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                                      Original Prusa i3 MK3S
                                      undefined 1 Reply Last reply 13 Jun 2019, 11:10 Reply Quote 0
                                        deckingman @wilriker
                                        I "googled" that and came up with "force deletion of everything in the root directory". That's the equivalent of a "nuke" button isn't it?
                                        undefined 1 Reply Last reply 13 Jun 2019, 11:13 Reply Quote 1
                                          wilriker @OBELIKS
                                          @obeliks said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                          I was trying hard to find any reason to also add a / at the end to make it even more evil. 😂 And top class would be to get sudo prepended. sudo-rm-rf/. Perfect name for any tool on Linux. 🤣
                                          Manuel
                                          My Tool Collection
                                          OBELIKSundefined 1 Reply Last reply 13 Jun 2019, 11:34 Reply Quote 0
                                          2 out of 83
