    rfm - RepRapFirmware FileManager [duetbackup successor]
    83
    10.3k
    • Nxt-1undefined
      Nxt-1
      I would like the express my interest in this awesome project. The RPi that accompanies my printer is perfect to make scheduled backups.
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • gtj0undefined
        gtj0
        I'm sorry but you don't have enough "R"s or "F"s in there. Should be "rrffm" 🙂
        • wilrikerundefined
          wilriker @Dougal1957
          @dougal1957 No, it's for the same platforms asduetbackup was, i.e. Windows, Linux and Mac amd64 as well as Linux arm (e.g. Raspberry Pi) and arm64 (some other SBC boards).
          Manuel
          My Tool Collection
          • wilrikerundefined
            wilriker @gtj0
            @gtj0 Believe me, you don't want that. 😂 It was the working title while development. It's a PITA to type and typo guarantee. 😁
            P.S.: a friend of mine asked if I can somehow get a "t" in there and some letter swapping to get rtfm. 😂
            Manuel
            My Tool Collection
            • wilrikerundefined
              wilriker @Nxt-1
              @nxt-1 I also use a RPi to perform the backups. In case you have Arch Linux running on your Pi: I plan to make an AUR package as well.
              Manuel
              My Tool Collection
              • gtj0undefined
                gtj0 @wilriker
                @wilriker said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                P.S.: a friend of mine asked if I can someone get a "t" in there and some letter swapping to get rtfm. 😂
                That was going to be my next suggestion.
                • wilrikerundefined
                  wilriker @gtj0
                  @gtj0 said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                  Feel free to fork and rename it. 😂
                  Manuel
                  My Tool Collection
                  • mloidlundefined
                    mloidl
                    Hi @wilriker,
                    Found a small "issue".
                    If rfm is called with no arguments (I know it should not called with no args), the program exit with panic because of an invalid array access (function args). Better would be to show a proper message.
                    Further tests are outstanding. I had not the time to test it yet.
                    Regards,
                    Martin
                    • wilrikerundefined
                      wilriker @mloidl
                      @mloidl Thanks! I fixed it in the source code and it will be in the next release.
                      Probably also in the next release will be a couple of changes
                      • Parameters relevant for connection (i.e. domain, port and password) can be put into a file in the user's home directory so they don't have to be provided on the command line everytime
                      • Some parameters that are currently given as -parametername value will be shortened to just value but then have to follow a strict ordering in case there is more than one (this resembles more common CLI tools)
                      • Adding help pages similar to the main help output for sub-commands
                      Manuel
                      My Tool Collection
                      • mloidlundefined
                        mloidl
                        @wilriker thanks for the quick fix.
                        Regarding config file for connection parameter:
                        For users having multiple duet-based printers it would be cool to to store all these connections settings domain, port and password in a kind of connection group.
                        e.g.
                        [printer1]
                        domain=<printer1-ip>
                        port=<printer1-port>
                        password=<printer1-pw>
                        [printer2]
                        Usage then could be rfm -device printer1 <cmd>
                        I did something similar in a python-based backup script for my daily backups and found this very useful.
                        What's your opinion about this?
                        wilrikerundefined 1 Reply Last reply Reply Quote 1
                        • wilrikerundefined
                          wilriker @mloidl
                          @mloidl I like that and will implement something like this. But even though I listed it first it's currently last in priority. 😉
                          Manuel
                          My Tool Collection
                            T3P3Tony administrators
                            @wilriker My vote goes for RepRapFirmware Total File Manager
                            wilrikerundefined 1 Reply Last reply Reply Quote 2
                            • wilrikerundefined
                              wilriker @T3P3Tony
                              @t3p3tony said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                              Yeah, that's what I thought of, too. 😂
                              Also another good idea might be
                              "[File-]Resource Manager for RepRapFirmware-based Filesystems" -> rm-rf 🤣
                              (Windows user's probably won't get this one)
                              Manuel
                              My Tool Collection
                              deckingmanundefined 1 Reply Last reply Reply Quote 5
                              • OBELIKSundefined
                                OBELIKS
                                You are evil! I wonder if anyone would even dare to use the tool in Linux then.
                                P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                                Original Prusa i3 MK3S
                                  deckingman @wilriker
                                  I "googled" that and came up with "force deletion of everything in the root directory". That's the equivalent of a "nuke" button isn't it?
                                  • wilrikerundefined
                                    wilriker @OBELIKS
                                    @obeliks said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                    I was trying hard to find any reason to also add a / at the end to make it even more evil. 😂 And top class would be to get sudo prepended. sudo-rm-rf/. Perfect name for any tool on Linux. 🤣
                                    Manuel
                                    My Tool Collection
                                    OBELIKSundefined 1 Reply Last reply Reply Quote 0
                                    • wilrikerundefined
                                      wilriker @deckingman
                                      @deckingman said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                      More or less. There are some protections in place but if you run
                                      rm -rf / [note the spaces]
                                      either as root user (admin user with full privileges in Linux) or prepend it with sudo (which will provide a regular user with root-rights) it will do exactly that. It will erase all contents of your hard-drive and depending on the configuration also of all mounted external drives. Not as fast as a giant hammer but fast enough to have made probably unrecoverable damage until you notice.
                                      Manuel
                                      My Tool Collection
                                      1 Reply Last reply Reply Quote -1
                                      • OBELIKSundefined
                                        OBELIKS @wilriker
                                        That is a lot of nonoes in one sentence 🙂
                                        • wilrikerundefined
                                          wilriker
                                          Back to business:
                                          Release v1.0.0-RC2
                                          I have just release v1.0.0-RC2.
                                          Changes
                                          Help
                                          This second release candidate has help texts for every sub-command now that are accessible via
                                          rfm help <command>
                                          Command Structure
                                          The second major change is the structure of the parameters and options. This now resembles better the style of common CLI tools. Please see the appropriate help pages to see the format.
                                          rfm backup Changes
                                          Most notably also the format for rfm backup changed. This now is
                                          rfm backup <common-options> [-removeLocal] [-exclude <excludepattern>]* [<local/path> [<remote/path>]]
                                          where -outDir has been reduced to <local/path> with a default of the current directory if omitted and -dirToBackup is shortened to <remote/path>. The default is still 0:/sys. In case this needs to be changed the local directory also has to be provided.
                                          rfm ls
                                          rfm ls now accepts multiple remote paths to list.
                                          Fixes
                                          • panic when no sub-command is provided is replaced with default help text
                                          • Uploading single files was broken
                                          Manuel
                                          My Tool Collection
                                          • wilrikerundefined
                                            wilriker
                                            Release v1.0.0
                                            And here comes the first official release v1.0.0.
                                            Release Notes
                                            This release implements all functions listed in README.md, i.e. it can
                                            • download files
                                            • upload files and folder
                                            • backup (like duetbackup did before but slightly different and simplified syntax)
                                            • list directory contents
                                            • move or rename files and directories
                                            • create directories
                                            • delete files and directories
                                            This covers all functions of the HTTP interface.
                                            Also it is capable of handling multiple devices via an automatically managed configuration file.
                                            As usual there are releases for Linux x86_64, Windows x86_64, MacOS X x86_64, Linux ARM and Linux ARM64.
                                            Manuel
                                            My Tool Collection
