    RepRapFirmware 3.0
    176
    30.6k
    • smoki3undefined
      smoki3
      Today I switched to the 3.0.
      @dc42 So I got everything to work besides the Z-Probe.
      I use a normal mircoswitch connected to zstop pin on the duet2wifi.
      But it tells me that it it always triggered.
      I used this according to the documentation:
      M574 Z0 C"nil" 				       ; no Z endstop switch, free up Z endstop input
      M558 P5 C"zstop" H3 F180 T25000 I1 	       ; Z probe connected to Z endstop input
      I also tried to remove the inversion "I1" and put an "!zstop" in the C command. But it doesnt help.
      In DWC I see the probe value changes from 0 to 1000 if I press the switch. But the background of the value is always read
      I played alot now with all the parameters. Looks like the probe is always trigged no matter which pin is selected. But I can not test an older build because the files in dropbox is replaced.
      Here are some console outputs:
      M119
      Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
      M574
      Endstop configuration: X: low end motor stall (any motor), Y: low end motor stall (any motor), Z: none
      M558
      Z Probe 0: type 5, input pin zstop, output pin nil, invert yes, dive height 3.0mm, probe speed 180mm/min, travel speed 25000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
        @smoki3 said in RepRapFirmware 3.0:
        What does - the M119 report, or something else? Are you saying that DWC shows the correct Z probe status, but M119 does not?
        • smoki3undefined
          smoki3
          for the outputs see my post above.
          M119 shows always " Z probe: at min stop "
          In the status windows i can see that the Z-probe value switches between 0 and 1000. But its always in read color
            I found the problem. The threshold is not being initialised. A workaround is to put command G31 P500 (or whatever threshold you want to use) after the M558 command.
            smoki3undefined 1 Reply Last reply Reply Quote 0
            • smoki3undefined
              smoki3 @dc42
              @dc42 said in RepRapFirmware 3.0:
              G31 P500
              Thanks this works fine
                jay_s_uk
                @dc42 I've also upgraded to RRF 3.0 to try it out.
                Previously, in RRF 2, when setting up a Z Probe, I used to have M558 H4. This H4 was added to the z probe offset so it would look for the bed, in my case, 31.66mm above z, as my probe offset is 27.66.
                Now I'm having to use H30 as RRF 3 seems to be ignoring the z probe offset. Is this correct?
                  dc42 administrators @jay_s_uk
                  @jay_s_uk said in RepRapFirmware 3.0:
                  No, that's not correct. RRF 3 should not ignore the Z probe offset, and I am fairly sure it doesn't on my printers.
                  The default M558 H value is 5. It's normally only necessary to increase it when aut-calibrating a delta printer for the first time, when the homed height and delta radius enters in the M665 command are likely to be inaccurate.
                  How come your Z probe trigger height (which is what I presume you mean by "offset") is as high as 31mm?
                    jay_s_uk @dc42
                    I have a linear plus with an E3D hot end. So I use the probe that came with is as well as little block to allow me to miss the heat block on the hot end. This has increased the z probe offset somewhat from 16.8ish that comes as standard to 27.6ish.
                    Its works fine with RRF 2 without issue.
                    But switching over to RRF 3, the z probe was coming into contact with the bed way before it was actually triggering.
                    I increased the H from 4 to 30 and this allowed me to run G32 and the M500. But I've had to leave H as 30 otherwise the z probe comes into contact with the bed. And the gap it maintains between the probe and the bed is only around 3mm, hence why I think it is ignoring the z probe offset.
                      You are right, it's not adding the trigger height to the dive height. I will fix this in the next build. Thanks for reporting it.
                        jay_s_uk
                        At least I'm not going mad. Thanks
                          @jay_s_uk, please try the new binary at https://www.dropbox.com/s/zfv4p7dr2ycmjzd/Duet2CombinedFirmware.bin?dl=0.
                            jay_s_uk
                            @dc42 thats spot on
                              @dc42 thats spot on
                              Thanks for confirming!
                              • wilrikerundefined
                                wilriker
                                I also now tried out RRF3 and first very obvious observation: Fan PWM inversion does not work. I do have
                                M950 F0 P"fan0" Q10                               ; Fan 0 has a low PWM frequency of only 10Hz
                                M950 F1 P"!fan1" Q25000                           ; Fan 1 has a high PWM frequency of 25kHz and is inverted
                                M950 F2 P"!fan2" Q25000                           ; Fan 2 has a high PWM frequency of 25kHz and is inverted
                                M106 P0 S0 H-1 C"Part Cooling Fan"                 ; Set fan 0 value. Thermostatic control is turned off
                                M106 P1 S1 L0.7 H1 T45:220 C"Hotend Fan"           ; Set fan 1 value. Thermostatic control is turned on
                                M106 P2 S0 H-1 C"Hardware Fan"                     ; Set fan 2 value. Thermostatic control is turned off
                                where the first fan is a regular 3-wire fan but the other two are 4-wire PWM controlled fans and both spin at 100% speed after startup (I know fan 1 is thermostatic but the hotend is at room temp). Unless I make fan 1 non-thermostatic I have no way of stopping it (I stopped fan 2 by issuing M106 P2 S1).
                                EDIT: Second observation:
                                I have two independent Z steppers. Also each stepper has a separate endstop switch. Homing Z works fine with both steppers running until their appropriate switch is triggered. After that I un-hide W axis (right of the two Z steppers) and apply a correction since the switches are not perfectly aligned. So far this works. What does not work is M119 for W axis. It will always show that the endstop is not triggered even though at the same time it shows triggered for Z.
                                M584 X0 Y1 Z2:3 W3 E4                              ; Assign one driver X, Y and E and two to Z
                                M574 Z1 S1 P"zstop+e0stop"                         ; Set active high endstop at low end on Z with two separate endstops
                                M574 W1 S1 P"e0stop"                               ; Set active high endstop at low end on W
                                Since I never use W axis outside of homez.g and don't even have a homew.g for me this is purely cosmetical - but their are probably other users that depend on this working correctly.
                                Manuel
                                My Tool Collection
                                  dc42 administrators @wilriker
                                  @wilriker said in RepRapFirmware 3.0:
                                  The pin name parameter in the M950 command (and most other commands that don't take axis parameters) is C not P.
                                  You can't currently assign the same endstop input to more than one axis. So the M574 command to assign e0stop to W is failing. If you run that command from the console you will get an error message.
                                  • wilrikerundefined
                                    wilriker @dc42
                                    In that case the example code for M106 in the RRF3 wiki is wrong (I checked M950 has it right).
                                    As I said no real problem for me but thanks for clarifying.
                                    Manuel
                                    My Tool Collection
                                      I have corrected the example.
                                      • wilrikerundefined
                                        wilriker @dc42
                                        @dc42 Thanks. Just wanted to do it myself only to find it's been done already. 🙂
                                        Manuel
                                        My Tool Collection
                                        • wilrikerundefined
                                          wilriker
                                          Found another discrepancy in the wiki. In the description for M950 C it says to enable pull-up resistor ^ has to be trailing. In Pin Name Format section below it says the ^ should appear in front of the pin name.
                                          Again not relevant for me but others might stumble across that one.
                                          Manuel
                                          My Tool Collection
                                            Thanks, I've corrected that.
