    RepRapFirmware 3.0
    176
    30.6k
      @smoki3 said in RepRapFirmware 3.0:
      I use a normal mircoswitch connected to zstop pin on the duet2wifi.
      But it tells me that it it always triggered.
      What does - the M119 report, or something else? Are you saying that DWC shows the correct Z probe status, but M119 does not?
      • smoki3undefined
        smoki3
        for the outputs see my post above.
        M119 shows always " Z probe: at min stop "
        In the status windows i can see that the Z-probe value switches between 0 and 1000. But its always in read color
          I found the problem. The threshold is not being initialised. A workaround is to put command G31 P500 (or whatever threshold you want to use) after the M558 command.
          smoki3undefined 1 Reply Last reply Reply Quote 0
          • smoki3undefined
            smoki3 @dc42
            @dc42 said in RepRapFirmware 3.0:
            G31 P500
            Thanks this works fine
              jay_s_uk
              @dc42 I've also upgraded to RRF 3.0 to try it out.
              Previously, in RRF 2, when setting up a Z Probe, I used to have M558 H4. This H4 was added to the z probe offset so it would look for the bed, in my case, 31.66mm above z, as my probe offset is 27.66.
              Now I'm having to use H30 as RRF 3 seems to be ignoring the z probe offset. Is this correct?
                dc42 administrators @jay_s_uk
                @jay_s_uk said in RepRapFirmware 3.0:
                No, that's not correct. RRF 3 should not ignore the Z probe offset, and I am fairly sure it doesn't on my printers.
                The default M558 H value is 5. It's normally only necessary to increase it when aut-calibrating a delta printer for the first time, when the homed height and delta radius enters in the M665 command are likely to be inaccurate.
                How come your Z probe trigger height (which is what I presume you mean by "offset") is as high as 31mm?
                  jay_s_uk @dc42
                  I have a linear plus with an E3D hot end. So I use the probe that came with is as well as little block to allow me to miss the heat block on the hot end. This has increased the z probe offset somewhat from 16.8ish that comes as standard to 27.6ish.
                  Its works fine with RRF 2 without issue.
                  But switching over to RRF 3, the z probe was coming into contact with the bed way before it was actually triggering.
                  I increased the H from 4 to 30 and this allowed me to run G32 and the M500. But I've had to leave H as 30 otherwise the z probe comes into contact with the bed. And the gap it maintains between the probe and the bed is only around 3mm, hence why I think it is ignoring the z probe offset.
                    You are right, it's not adding the trigger height to the dive height. I will fix this in the next build. Thanks for reporting it.
                      jay_s_uk
                      At least I'm not going mad. Thanks
                        @jay_s_uk, please try the new binary at https://www.dropbox.com/s/zfv4p7dr2ycmjzd/Duet2CombinedFirmware.bin?dl=0.
                          jay_s_uk
                          @dc42 thats spot on
                            @dc42 thats spot on
                            Thanks for confirming!
                            • wilrikerundefined
                              wilriker
                              I also now tried out RRF3 and first very obvious observation: Fan PWM inversion does not work. I do have
                              M950 F0 P"fan0" Q10                               ; Fan 0 has a low PWM frequency of only 10Hz
                              M950 F1 P"!fan1" Q25000                           ; Fan 1 has a high PWM frequency of 25kHz and is inverted
                              M950 F2 P"!fan2" Q25000                           ; Fan 2 has a high PWM frequency of 25kHz and is inverted
                              M106 P0 S0 H-1 C"Part Cooling Fan"                 ; Set fan 0 value. Thermostatic control is turned off
                              M106 P1 S1 L0.7 H1 T45:220 C"Hotend Fan"           ; Set fan 1 value. Thermostatic control is turned on
                              M106 P2 S0 H-1 C"Hardware Fan"                     ; Set fan 2 value. Thermostatic control is turned off
                              where the first fan is a regular 3-wire fan but the other two are 4-wire PWM controlled fans and both spin at 100% speed after startup (I know fan 1 is thermostatic but the hotend is at room temp). Unless I make fan 1 non-thermostatic I have no way of stopping it (I stopped fan 2 by issuing M106 P2 S1).
                              EDIT: Second observation:
                              I have two independent Z steppers. Also each stepper has a separate endstop switch. Homing Z works fine with both steppers running until their appropriate switch is triggered. After that I un-hide W axis (right of the two Z steppers) and apply a correction since the switches are not perfectly aligned. So far this works. What does not work is M119 for W axis. It will always show that the endstop is not triggered even though at the same time it shows triggered for Z.
                              M584 X0 Y1 Z2:3 W3 E4                              ; Assign one driver X, Y and E and two to Z
                              M574 Z1 S1 P"zstop+e0stop"                         ; Set active high endstop at low end on Z with two separate endstops
                              M574 W1 S1 P"e0stop"                               ; Set active high endstop at low end on W
                              Since I never use W axis outside of homez.g and don't even have a homew.g for me this is purely cosmetical - but their are probably other users that depend on this working correctly.
                              Manuel
                              My Tool Collection
                                dc42 administrators @wilriker
                                @wilriker said in RepRapFirmware 3.0:
                                The pin name parameter in the M950 command (and most other commands that don't take axis parameters) is C not P.
                                You can't currently assign the same endstop input to more than one axis. So the M574 command to assign e0stop to W is failing. If you run that command from the console you will get an error message.
                                • wilrikerundefined
                                  wilriker @dc42
                                  In that case the example code for M106 in the RRF3 wiki is wrong (I checked M950 has it right).
                                  As I said no real problem for me but thanks for clarifying.
                                  Manuel
                                  My Tool Collection
                                    I have corrected the example.
                                    • wilrikerundefined
                                      wilriker @dc42
                                      @dc42 Thanks. Just wanted to do it myself only to find it's been done already. 🙂
                                      Manuel
                                      My Tool Collection
                                      • wilrikerundefined
                                        wilriker
                                        Found another discrepancy in the wiki. In the description for M950 C it says to enable pull-up resistor ^ has to be trailing. In Pin Name Format section below it says the ^ should appear in front of the pin name.
                                        Again not relevant for me but others might stumble across that one.
                                        Manuel
                                        My Tool Collection
                                          Thanks, I've corrected that.
                                          • t9undefined
                                            t9
                                            I am testing the newly added function M581.
                                            How would you ignore output, in Reprap 2.03 this was done with S-1, but there is no S parameter available.
                                            Thanks
