    Duet "Crashes" on Print
    My Duet controlled machine
    868
    • markundefined
      mark
      As an additional test I have also tried printing direct on the duet screen and that also does not start the print.
        deckingman
        Just to be clear. You can home all the axes, heat the bed, heat the hot end and extrude filament yes?
        markundefined 1 Reply Last reply Reply Quote 0
        • markundefined
          mark @deckingman
          @deckingman Yes, I have full control of the printer and everything works, I just can't start a print
            deckingman @mark
            @mark That's very odd. Does it do it with every gcode file or just one particular file? I wonder if your SD card has become corrupted. Have you tried a different card?
            • markundefined
              mark
              @deckingman
              I have tried a new Benchy and a calibration cube that has been on the card a while and printed previously.
              If I backup all the files on the card and do a factory reset and the issue still persists (once I do a manual setup again), can I just copy the backed up files back on the card to get back to where I am at the moment?
                An easier test would be to use a new sd card. Copy the contents of your current card over and try the new card.
                • markundefined
                  mark
                  @Phaedrux 👍 will try it out tonight
                  Thanks
                    @mark, your M122 report indicates that the last software reset was user-initiated, not a crash. This may have been caused by using the Emergency Stop button, or by sending M999, or by upgrading firmware.
                    • markundefined
                      mark
                      I figured it out, and am very ashamed to say it was user error 😞
                      I accidently uploaded the slt rather than G-code file!
                      @deckingman thanks for your input and keep up the good work on your projects, you have a new follower
                      @Phaedrux thanks for the advice
                      @dc42 Again thanks for responding - should uploading anything else other than a g-code file to print be a valid user story?
                      Again thanks all for you inputs
                      Mark
                        How did you upload an STL? I've just tried and the file selector greys them all out and dragging and dropping won't take it either.
                        • markundefined
                          mark
                          @Phaedrux I can still upload a stl. Maybe I am not using the latest firmware - I need to work out how to update it, but that's a job for another day!
                            Download this zip file https://github.com/dc42/RepRapFirmware/releases/download/2.03/Duet2Firmware-2.03.zip
                            Then upload the whole zip file as is to the Settings page in the DWC. That's all you have to do.
