Duet "Crashes" on Print
@deckingman Yes, I have full control of the printer and everything works, I just can't start a print
@mark That's very odd. Does it do it with every gcode file or just one particular file? I wonder if your SD card has become corrupted. Have you tried a different card?
I have tried a new Benchy and a calibration cube that has been on the card a while and printed previously.
If I backup all the files on the card and do a factory reset and the issue still persists (once I do a manual setup again), can I just copy the backed up files back on the card to get back to where I am at the moment?
An easier test would be to use a new sd card. Copy the contents of your current card over and try the new card.
@Phaedrux
will try it out tonight
Thanks
@mark, your M122 report indicates that the last software reset was user-initiated, not a crash. This may have been caused by using the Emergency Stop button, or by sending M999, or by upgrading firmware.
I figured it out, and am very ashamed to say it was user error
I accidently uploaded the slt rather than G-code file!
@deckingman thanks for your input and keep up the good work on your projects, you have a new follower
@Phaedrux thanks for the advice
@dc42 Again thanks for responding - should uploading anything else other than a g-code file to print be a valid user story?Again thanks all for you inputs
Mark
How did you upload an STL? I've just tried and the file selector greys them all out and dragging and dropping won't take it either.
@Phaedrux I can still upload a stl. Maybe I am not using the latest firmware - I need to work out how to update it, but that's a job for another day!
Download this zip file https://github.com/dc42/RepRapFirmware/releases/download/2.03/Duet2Firmware-2.03.zip
Then upload the whole zip file as is to the Settings page in the DWC. That's all you have to do.
