    External Triggers
    28
    3.5k
    • Ringo1508undefined
      Ringo1508
      @hayseed_byte, is there a new URL to your write up? I'm looking to use external push button switches to help with common tasks.
      Thanks!
      • oliofundefined
        oliof
        The text can be salvaged from the Wayback Machine -- maybe it's worth adding an equivalent as a guide to the official wiki?
        • chas2706undefined
          chas2706
          @hayseed_byte
          Your link does not work, it says "404 page not found".
            I have extracted the text from the Wayback Machine. Here is it is.
            External Control Panel for Duet Wifi
            Clinton Thomas November 13, 2018 Blog
            Control Panel
            The DuetWifi is hands down the best controller on the market. The only downside is that it doesn’t come with a display/control panel and it’s only compatible with the PanelDue displays. I’ve recently purchased a 5″ PanelDue but for a long time adjusting the Wildbot was troublesome. It involved a lot of walking from my computer to my printer and back. I used triggers and external buttons to solve this problem.
            The wiring looks complicated but it’s not so bad. On each switch, one terminal is wired to common (gnd) and the other is wired to a certain pin on the expansion header. My board is mounted upside-down just to make it super confusing for everyone.
            Here are the pins I used.
            Pin 4 = E2_STOP
            Pin 9 = E3_STOP
            Pin 14 = E4_STOP
            Pin 19 = E5_STOP
            Pin 26 = E6_STOP
            Pin 44 = RESET
            Expansion Header
            Pin 44 forces a reset when shorted to ground so that button was easy enough. For the rest, I had to make changes to the config file. I found the following digging around RepRap.org:
            M581: Configure external trigger
            Parameters
            Tnn Logical trigger number to associate the endstop input(s) with, from zero up to a firmware-specific maximum (e.g. 9 for RepRapFirmware)
            X, Y, Z, E Selects endstop input(s) to monitor
            P Reserved, may be used in future to allow general I/O pins to cause triggers
            S Whether trigger occurs on a rising edge of that input (S1, default), falling edge (S0), or ignores that input (S-1). By default, all triggers ignore all inputs.
            C Condition: whether to trigger at any time (C0, default) or only when printing a file from SD card (C1)
            In RepRapFirmware, trigger number 0 causes an emergency stop as if
            M112 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater then 1 causes the macro file sys/trigger#.g to be executed.
            So, in order to get buttons for pause, home, ATX on, and disable steppers, I had to add the following to my config file:
            ; Input/Output
            M581 E2 S1 T1 C1 ; Pause - PIN4
            M581 E5 S1 T3 C0 ; Disable Steppers - PIN19 - trigger3.g
            M581 E4 S1 T4 C0 ; Home All - PIN14 - trigger4.g
            M581 E3 S1 T2 C0 ; ATX On - PIN9 - trigger2.g
            Originally, I planned to have a button for HALT (RRF calls it “Emergency Stop” but that’s not what it does, in my opinion) and ATX Off. Duet Web Control asks for confirmation when those commands are sent. As a result, it’s not currently possible to execute them via external triggers.
            For the rest, I had to add macro trigger files. Which are just text files containing the respective commands saved as trigger#.gcode.
            ;tigger2.g
            M80 ; ATX ON
            ;trigger3.g
            M400 ; Finish Current Moves
            M18 ; Disable Steppers
            M300 S300 P1000 ; Play a beep sound at 300Hz for 1000milliseconds
            ;trigger4.g
            M400 ; Finish current moves
            G28 ; Home all axes
              Ringo1508
              @dc42 is there a way to do conditional logic in macros? Something like this sudocode:
              resume.g
              // resume method after filament runout
              // maintain sub state for what action to perform next on same macro call
              int globalSubState;
              // initial state after runout detected
              if (state == "paused" && globalSubState < 1 && e0_temp > 210)
                  // execute whatever macro sets tool to active temperature
                  execcmd "G1 E-100 F1800";  // retract all filament left from runout
                  globalSubState = 1;  // set flag for next execution of macro
              // remaining filament has been removed and new filament has been hand loaded
              // go to just above where the last print position was and extrude 10mm to prime, but do not start printing yet
              else if (globalSubState == 1)
                  execcmd "G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move";
                  execcmd "G1 R1 X0 Y0          ; go back to the last print move";
                  execcmd "M83                  ; relative extruder moves";
                  execcmd "G1 E10 F3600         ; extrude 10mm of filament";
                  globalSubState = 2;  // set flag for next execution of macro
              // resume print
              else
                  state == "printing";  // unpause the print and resume printing
                  continueprint;
              Or is there another way to do this with multiple macros that you can call, but all off the same trigger? I doubt it, but it doesn't hurt to ask 🙂 i hope lol
              TCundefined 1 Reply Last reply Reply Quote 0
              • oliofundefined
                oliof
                Conditionals and variables have been announced for RRF 3
                  dc42 administrators @oliof
                  @oliof said in External Triggers:
                  And partly implemented already; but not really usable before the object model had been completed so that you can access the variables to need.
                  • hayseed_byteundefined
                    hayseed_byte
                    Woah...Didn't realize this was getting any attention. I've been playing around with my website since it wasn't getting any traffic and managed to break it. I'll get it back up as soon as I can.
                    Here are some pictures of my control panel if anyone is interested.
                    https://wildbot.me/wildbot
                    Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
                      hayseed_byte
                      I fixed the link, though now the url is https://www.wildbot3d.xyz/contol-panel/. So the article is back up if anyone wants to check it out in the future.
                        Phaedrux Moderator @hayseed_byte
                        @hayseed_byte would you consider adding the gist of it to the wiki for posterity?
                        hayseed_byteundefined 1 Reply Last reply Reply Quote 1
                          hayseed_byte
                          @phaedrux said in External Triggers:
                          I'd be happy to.
                            hayseed_byte
                            One thing I'd like to link to an external button is the "Print Another" thing but I'm guessing that's a function of the DWC and not the firmware? Print Another is amazingly useful. I have a few printers that don't have Duet controllers (yet) and I really miss that feature.
                              Remind me to add the name of the last file printed to the RRF3 object model. Then it will be possible to write a macro that reprints the last file printed.
                              Edumaundefined 1 Reply Last reply Reply Quote 0
                                hayseed_byte
                                @dc42 said in External Triggers:
                                Wow..that would be great. Thank you! I might go ahead and order a fourth duet.
                                  hayseed_byte @Phaedrux
                                  @phaedrux I added it to the wiki. I'm not much of a writer but all the information is there, I think.
                                  https://duet3d.dozuki.com/Wiki/Using_M581_-_External_Triggers_and_Building_a_Control_Panel
                                  • CJ.BRAVOundefined
                                    CJ.BRAVO
                                    @hayseed_byte
                                    Hey there,
                                    trying to connect some external triggers like in the guide mentioned above.
                                    I had the emergency trigger working (T0) but it seems to cause some weird behavior after resetting...
                                    seems kinda "stuck" - screen freezes and no control with buttons. it comes back to normal after unplugging the external triggers. am I missing something with the way its connected? some resistors maybe?
                                    Also, after T0 is engaged I get a "firmware restart" option - a 2nd reset basically, why is that ? a bit redundant, no? anyway to avoid that and have the system restart only once after hitting the emergency button ?
                                    thanks a bunch !
                                    hayseed_byteundefined 1 Reply Last reply Reply Quote 0
                                    • TCundefined
                                      TC @Ringo1508
                                      @Ringo1508 I thought about that too and I am trying to store the information that the axes have been homed by disabling a trigger in the homing macro. The trigger pin is allways low. When the print starts it checks for the trigger and is supposed to execute the homing macro if it is still active. The problem now is that the homing sequence is not run properly. It seams called from the gcode file it interferes with the code generated by the slicer. I still do not really understand what priority the trigger code has.
                                      @dc42 Could you explain how a trigger behaves during a running print and how I could achieve what I am trying to do?
                                        hayseed_byte @CJ.BRAVO
                                        @CJ-BRAVO I was never able to get an emergency stop button to work. The Duets ask for confirmation for emergency stop which sort of defeats the purpose. If I understand you correctly, your 2nd reset might have something to do with switch bounce so you might look into delay/debounce settings.
                                        dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          dc42 administrators @hayseed_byte
                                          @hayseed_byte said in External Triggers:
                                          I assure you, they don't! They stop immediately, then if the stop wasn't followed by a reset, Duet Web Control asks you if you want to reset.
                                            It asks for confirmation of a cancel, but not the stop.
