    topic_solved Can't change current for new stepper
    735
    • PuterPro
      PuterPro last edited by
      OK, I'm puzzled. Just installed new steppers for X, Y, & E (17HS19-2004S1) on my CR-10S / Maestro setup.
      I'm setup with 24v to Maestro from Meanwell P/S (tuned to 27vdc currently, Maestro max is 28, would like to move down to 26.5 just for safety margin). Steppers are 2A, @dc42 suggested I try running detuned to 1A. Here's my config.g drivers section:
      M569 P4 S1 ; Drive 4 goes forwards
      M350 X16 Y16 Z16 E16 U16 I1 ; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E112 U400.00 ; Set steps per mm NOTE - FOR BONDTECH CLONE E418.67
      M566 X1000.00 Y1000.00 Z12.00 E300.00 U12.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000 Y12000 Z600.00 E1200 U600.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y250.00 Z16.60 E166.00 U16.60 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000 Z700 E1000 U700.00 I30 ; Set motor currents (mA) and motor idle factor in %
      M84 S30 ; Set idle timeout
      Note I currently am NOT on the Bondtech.
      I've changed the M906 value for E from 700 on old stepper to 1000. Actually started at 900 since I'd prefer it skip steps on a clog than grind the filament (a suggestion from @dc42 ).
      Problem is, I was calibrating E Steps and I kept getting skipped steps despite only extruding at 5mm/sec!
      PolyLite PLA (Diameter a bit small - 1.738 avg) 180-230° ; I'm set at 210 (up from 200 where it REALLY skipped)
      Here's the macro I setup for E steps calibration:
      M200 D1.738 ;EDIT VALUE FOR FILAMENT DIAMETER
      G0 F300 ;Set the feedrate to 300mm/minute (5MM/SEC)
      G0 E100 ;Extrude 100mm Filament
      Now all that LOOKS OK to me but it was still skipping. Then I saw THIS:
      Under Settings -> Machine Properties it clearly shows the extruder is set to 700ma !
      I've changed the config file several times, warm booting each time, even did a full shutdown cold boot, no change.
      I'm sure this is something as obvious as the nose on my face, but I ain't seeing my nose. Thoughts?
      genghisnico13 dc42 2 Replies Last reply Reply Quote 0
      • bot
        bot last edited by bot
        I don’t see M584 to define the U axis.
        Is that missing? You need to explicitly define the extruders and U.
        • PuterPro
          @bot said in Can't change current for new stepper:
          M584
          You mean this one?
          ; Define Axis ;
          M584 X0 Y1 Z2:4 E3 U4 P3 ; With Second Z motor defined as U axis on E1 driver, P3 to hide it
          1st line of my config.g , left it out since I didn't think it applied ...
          Hey are you stalking me? 😀
          bot Phaedrux 2 Replies Last reply Reply Quote 1
          • bot
            bot @PuterPro last edited by
            @puterpro
            Ahh I figured you may have just left it out. Yes I'm stalking you. Look out your window!
            When I go to look something up on the forum, I always check "recent posts" first to see if there is any answer I can quickly help with. This time it didn't work out and now I've ruined everything!!
            • PuterPro
              Well, it's certainly not the 1st time I've been tracked by a bot. Thanks anyways!
                If you send M906 and M913 in the console, what does it respond with?
                • genghisnico13
                  genghisnico13 @PuterPro last edited by
                  @puterpro said in Can't change current for new stepper:
                  I doubt this would be the problem but is it OK to put non integer numbers here? maybe delete the 2 ".00".
                    Phaedrux Moderator @PuterPro last edited by
                    U axis on E1 driver
                    I'm not 100% sure, but I think this might mean you have to define the axis in the order of the drivers, so U would come before E since U is E0 and E is E1. I could be out to lunch on that though. @dc42 ?
                      dc42 administrators @Phaedrux last edited by
                      @phaedrux said in Can't change current for new stepper:
                      U axis on E1 driver
                      E is not an axis because extruders are treated separately from axes. So the order of defining U and E doesn't matter.
                        dc42 administrators @PuterPro last edited by
                        Your E steps/mm indicate that you have an ungeared extruder. Such extruders need high motor torque. So turn the E motor current up to 1200 or 1300mA and provide fan cooling to the Maestro. You may even need to buy a motor with a lower rated current, so that you can run it closer to max current/max torque.
                        When you install the Bondtech extruder, you won't have this problem because it uses 3:1 gearing.
                        • PuterPro
                          @dc42 said in Can't change current for new stepper:
                          I'm running the Maestro in the cooled case I modded (you saw it) with dual 40x20mm fans and a guided air channel under the drivers. MCU reports 37-39°C.
                          I intend to go back to a Bondtech, but I foolishly bought a clone (I know better) and it's got a problem with the housing.
                          That doesn't explain why the current is staying set at 700ma when M906 in config.g is set to 1000ma,
                          that's my problem - I change it and it's not changing!!
                          • PuterPro
                            @Phaedrux - Just for fun, I tried your suggestion of M906 & M913. Good call (show off, LOL)!
                            I get 1000ma showing for E and all are running 100%, but when I go into the Machine Properties in settings it's still showing 700 as in the picture above!!
                            It's not not changing (love double negatives), it's not being reported by DWC properly!
                            @dc42 - DWC has a bug in the Machine Properties display, it's not updating when current values are changed. BTW - I'll try 1100ma and perhaps 1200 and keep a close eye on the temps. I think I'll attach a K-Type Thermocouple to the top of the E driver while I print and monitor it with a Bench DVM.
                            I'll report back on how it does, lets see how this cooled box performs in the real world, eh?😁
                            @genghisnico13 - Thanks for giving it a shot! I noticed that too, but I seem to recall that was put in by the RRF configurator originally so I never bothered to remove it. I'll take it out because it bothers my mild OCD ... LOL!
                              dc42 administrators @genghisnico13 last edited by
                              @genghisnico13 said in Can't change current for new stepper:
                              Yes non integer numbers are allowed. However, motor currents are rounded to a multiple of 100mA on Duet WiFi/Ethernet and 50mA on the Maestro. It rounds down, unless you are only a little below the next multiple.
                              • PuterPro
                                PuterPro last edited by PuterPro
                                @dc42 - Any idea why the Machine Properties page isn't updating with the newly assigned currents?
                                  I presume it means that page only sends the rr_config command to read the configuration once. If you reload DWC in your browser, it should pick up the new values. You can also send M906 with no parameters from the GCode Console to get a readback of the motor currents.
                                  • PuterPro
                                    Ummmm, nope. That's what I'm reporting. Warm boot or even cold shutdown doesn't change the values.
                                    M906 reports properly.
                                      Strange, it's working for me:
                                      • Load DWC 1.22.6 by entering the IP address in the browser followed by /reprap.htm (because I normally run DWC 2.0, which has no Machine Properties page)
                                      • Check XYZE currents on Machine Properties page
                                      • Go to GCode Console page and use M906 to change the currents
                                      • Go back to Machine Properties page, the new currents are displayed
                                      EDIT: but if I send the M906 command from the box at the top of the browser window when I am on the Machine Properties page, the displayed current doesn't update until I switch away from the Machine Properties page and back. So it looks like DWC only fetches the motor currents each time I switch to the Machine Properties page.
                                      PuterPro 1 Reply Last reply Reply Quote 0
                                      • PuterPro
                                        PuterPro @dc42 last edited by PuterPro
                                        @dc42 - Well, let me check what version of DWC I'm on. If you look up earlier in this thread you'll see a screen grab of what I'm seeing. I just changed the current to E1100 and M906, then rebooted as suggested. I then reloaded the browser page also for fun.
                                        Same problem, M906 displayed correct values, Machine Properties still look like the screenshot above.
                                        EDIT: 0_1555159821794_DWC Info.txt
                                        BTW - You need to fix the title of the RRF 3.0 post. 😇
                                        • PuterPro
                                          Here's my current setup:
                                          Firmware Name: RepRapFirmware for Duet 2 Maestro
                                          Firmware Electronics: Duet Maestro 1.0
                                          Firmware Version: 2.02RC5(RTOS) (2018-11-28b1)
                                          Web Interface Version: 1.22.5
                                          Should I update my Firmware?
                                            Yes. 2.02 release and DWC 1.22.6 are current.
                                            • PuterPro
                                              Thx. Do it later today and report back.
                                              • PuterPro
                                                Updated.
                                                I misread that.
                                                So Machine Properties is depreciated?
                                                (I found it switching to the old interface after upgrade and the current listed was still wrong).
                                                If it's depreciated I wouldn't have made a discussion of it, I'm not much for beating dead horses!!
                                                Thanks! Sorry if it was a time suck I'd never do that to you of all people! Still have a stepper currents Q but I'll separate post it.
                                                  I'm not sure that the Machine Properties page is deprecated, it may just be that chrishamm hasn't implemented it yet in DWC2. In particular, the facility to see the endstop states is useful.
                                                  • Florent
                                                    Florent last edited by
                                                    For my part.
                                                    If I do not display the current values in the web page, there is a problem with the configuration.
                                                    For engines that the value does not change, I redo a configuration in another location (in the config.g), I think there are conflicts following the instructions that are used later.
                                                    In my case, I had a problem with extruders on the DUEX5, which remained at 0mA, while on the DUET the command worked.
                                                    Putting this line further in the code corrected the problem.
                                                    M906 E800:800 ; Set motor currents (mA);pour test>> necessaire sinon pas de courant du tout
