    BLTouch Self-Triggering during multipoint probing
    19
    2.5k
    • kat-pwrundefined
      kat-pwr
      BL touch self triggering. When performing probing that involves moving sometimes it will trigger immediately once it moves to the next point.
      Can not get it to stop. I have played with delay, travel speed, probing speed, trigger value, can't get it to stop self triggering when performing g32 or g29. I can run g30 s-1 and individual trigger points ALL DAY, but when i perform any kind of dynamic multi point probing it will self trigger, sometimes it won't. Any help?
      Hypercube running triple Z. G30 s-1 reports dead nuts values when test-restesting during calibration.
      Here is my curren't config. Running duet + duex
      M574 Z1 S2 ; Set Z endstops controlled by probe
      M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel 5 for BLTouch
      M558 P9 H15 F400 T5000 A5 B1 ; BLtouch probe, 10mm dive height, probe speed, point delay, travel speed, probe parameters
      G31 P500 X0 Y67 Z4.23 ; Set Z probe trigger value, offset and trigger height
      M557 X25:475 Y100:450 S50 ; Define mesh grid
      Have played with P value at 25, R value from .25 to 1, Probe speed from 100-400, Travel from 4000,5000, 10000, 12000. Cut and re-crimped/pinned connectors, tests good on the DMM, nothing unusual.
      • As far as the large trigger value, I have played with the probe spacing, it was doing this same thing when the probe had 1mm spacing...
      • It does not self trigger on every point
      • Belts are tight, machine is aligned, running linear rails.
        Can you upload a video of it happening?
        Here is what I would consider ideal settings for the BLTouch.
        M558 P9 H5 F100 T4000 A5 S0.003 R0.5 B1
        G31 P25 Z~2
        Your dive height is quite high. Any particular reason?
        Your Z trigger height is also very high. This usually indicates that the probe isn't installed at the correct height. The base of the probe body should be 8mm above the tip of the nozzle, and this should lead to a trigger height of very close to 2mm.
        It would help to see the config.g. I'd like to see the rest of the speed settings.
        kat-pwrundefined 1 Reply Last reply Reply Quote 0
        • kat-pwrundefined
          kat-pwr
          I had the dive height from 5, 7, 10, and now 15mm. The hotend is not currently mounted 100%, I have to wire up the re-designed carriage I made. Here is the probe in action.
          (wont let me post youtube link)
          I have it working enough with the following config that it allows me to perform the mesh bed compensation but still has some false probes.
          M558 P9 H15 R0.2 F400 T5000 A5 B1
          ; Self Leveling configuration
          ; -Drive Selection
          ; -Leadscrews position
          M584 X0 Y1 Z5:6:7 E3:4 ; X is drive 0, Y is drive 1, Three Z motors connected to driver outputs 5, 6 and 7, E0 is drive 3, E1 is drive 4
          M671 X-24:254.5:524 Y524:-10:524 S15 ; Leadscrews at Left-Rear, Front-Middle, and Right-Rear
          M569 P0 S0 ; Drive 0 goes backwards (X Axis Stepper)
          M569 P1 S0 ; Drive 1 goes backwards (Y Axis Stepper)
          M569 P2 S0 ; Drive 2 goes backwards (Dual Z Axis Steppers not used)
          M569 P3 S1 ; Drive 3 goes forwards (E0 Stepper)
          M569 P4 S1 ; Drive 4 goes forwards (E1 Stepper)
          M569 P5 S0 ; Drive 5 goes backwards (Left Rear Z Stepper, Duex 1)
          M569 P6 S0 ; Drive 6 goes backwards (Front Center Z Stepper, Duex 2)
          M569 P7 S0 ; Drive 7 goes backwards (Right Rear Z Stepper, Duex 3)
          M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
          M92 X80.00 Y80.00 Z402.00 E424.50:424.50 ; Set steps per mm
          M566 X1200.00 Y1200.00 Z240.00 E720.00:720.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z2400.00 E3600.00:3600.00 ; Set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z600.00 E2000.00:2000.00 ; Set accelerations (mm/s^2)
          M906 X1700.00 Y1700.00 Z1000.00 E1700.00:1700.00 I30 ; Set motor currents, set idle current percentage to 30
          M84 S20 ; Set idle timeout to 20 seconds
          M208 X508 Y515 Z550 S0 ; Set axis maxima
          M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
          M558 P9 H15 R0.2 F400 T5000 A5 B1 ; BLtouch probe, 10mm dive height, probe speed, point delay, travel speed, probe parameters
          G31 P25 X0 Y67 Z4.23 ; Set Z probe trigger value, offset and trigger height
          M307 H0 A177.2 C321.8 D2.5 S1.00 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
          M307 H1 A608.6 C200.1 D7.6 S1.00 ; Set Heater 1 PID values
          M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
          M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
          M143 H2 S280 ; Set temperature limit for heater 2 to 280C
          M106 P1 S1 I0 H-1 C"LED Lighting" ; Set fan 1 value
          M563 P0 S"Hot End 0" D0 H1 ; Define tool 0
          M563 P1 S"Hot End 1" D1 H2 ; Define tool 1
          G10 P1 X9.5 Y0 Z0 ; Set tool 1 axis offsets
          G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
          ; Automatic power saving
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z10 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          ; Custom settings
          M501 ; Read Stored Parameters
          M564 H0 ; Allow movement before homing
          M280 P7 S90 ; Retract Z-Probe out of the way
          T0 ; Select first tool
          • Vetiundefined
            Veti
            @kat-pwr said in BLTouch Self-Triggering during multipoint probing:
            BL touch
            is it an original?
            • kat-pwrundefined
              kat-pwr @Phaedrux
              @phaedrux How can I post a video? I uploaded it to youtube but when I try to post the link the it won't allow me as it "detects spam". The video is 30 seconds long and is too large to upload directly via the post tools. I will try to trim it.
              EDIT: This current config works well enough that it allows it to complete compensation, but still has some false triggers.
              M558 P9 H15 R0.5 F400 T5000 A5 B1 ; BLtouch probe, 10mm dive height, probe speed, point delay, travel speed, probe parameters
              G31 P25 X0 Y67 Z4.345 ; Set Z probe trigger value, offset and trigger height
                The link posting may be limited due to you being a new member. It'll probably allow you to once you've made a few more posts.
                • Andy Cohenundefined
                  Andy Cohen
                  I had the same problem. Turned out it was EMI. or RF noise. I switched from a T/c to a thermistor and the problem never reoccured.
                  Too bad the mesh compensation turned out to be such a total waste of time. It works better just to tweak the leveling knobs and just chuck the unnecessary complexity.
                  kat-pwrundefined PaulHewundefined zaptaundefined 3 Replies Last reply Reply Quote 1
                  • kat-pwrundefined
                    kat-pwr @Andy Cohen
                    @andy-cohen That's odd, even with my probe issues I'm having FANTASTIC results with triple Z mesh compensation. I did design my Z positions so they intersect exactly at the corners of the bed though, not sure how much of a difference that makes.
                    • PaulHewundefined
                      PaulHew @Andy Cohen
                      @andy-cohen said in BLTouch Self-Triggering during multipoint probing:
                      Have to agree, I am thinking of getting rid of the BL Touch and going back to Mesh Bed Levelling and tweaking on the skirt.
                      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                      • Nightreaverundefined
                        Nightreaver
                        I wonder if i'm having the same issue or not.
                        From the beginning the probe triggers immediately after releasing, its like the pin is "jumping".
                        So it's released.. going down.. immediately triggered... going up again... getting released again without any delay (doesnt matter how you set R).
                        This happens few times, is accepted from the duet and then probing goes on with the next point.
                        The result looks like
                        means that I have to retry until its finally working on all points.
                          If you are probing with the bed heater on, try it with the bed heater off, or add the B1 parameter to the M558 command in config.g. The BlTouch is sensitive to magnetic fields and some DC bed heaters in particular generate them. Also check the crimp connection on the white wire from BLTouch where it connects to the Duet.
                            Nightreaver
                            Im proding without heater amd with B1 from the start.
                            From some further testing I can say that the "M280 P7 S10 I1" is already triggering that effect... sometimes filing that command is causing it to jumpo couple of times.
                            Maybe its possible to add a "max value" to the M558 similar to the S on M671.
                            As the wrong triggering values are usually waaay up like 8+mm compared to correct values which might be < 2mm.
                            It would help sent an upper max limit on the M558.
                            Besides that, it feels like the A on M558 has an upper limit? Can this be increased as well? cause that seem to help with that issue. Seems like A50 doesnt work ... A10/15 do but depending on self-triggering 10 is easily reached sometimes.
                              dc42 administrators @Nightreaver
                              When it triggers prematurely, does the pin definitely extend all the way first? If it doesn't, perhaps the pin is sticking.
                              Are you using the M558 R parameter to insert a small delay before probing?
                                Nightreaver
                                The Pin is going fully down and then up again.
                                I tried with different R values, from 0 to 1 without any effect.
                                I also tried a G4 P500 in retract and deploy .g files before and after the M280 without any effect either - besides the sensing failing completely.
                                Im using these two
                                retractprobe.g
                                M280 P7 S90 I1 ; Send PWM channel 7 the S90 (angle) command
                                deployprobe.g
                                M280 P7 S10 I1 ; Send PWM channel 7 the S10 (angle) command
                                The "jumping" occurs simply with just the "M280 P7 S10 I1" command. Its more bother me that the firmware is accepting these off value as valid.
                                Thats the issue:
                                https://youtu.be/nKLlnVU03I4
                                Im only doing pin down and pin up, over and over again, jumping happens all alone...
                                dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  @nightreaver said in BLTouch Self-Triggering during multipoint probing:
                                  I'm not a bltouch expert, but to me that suggests a problem with the bltouch.
                                    Phaedrux Moderator @Nightreaver
                                    @nightreaver Replace the knockoff clone with an actual BLTouch. You'll have much better luck.
                                    • zaptaundefined
                                      zapta @Andy Cohen
                                      It works very well for me and allows me to easily print a perfect first layer on my entire 300x300mm bed. I wonder what problems you encounter.
                                        Nightreaver
                                        @dc42 Can you confirm that M558 A has upper limit? When I set it to 15 with works okay, when I set it to 50 it seems like the limit goes down to A2 or something. Is this right?
                                          From the Bug Fixes section of the firmware 2.03 release notes at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md:
                                          Setting M558 A parameter to anything >31 set it to 0 instead of to 31
