    Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
    30
    3.8k
    • A Former User?
      A Former User @Richygoat
      @Richygoat said in Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?:
      What does the PS_ON pin on the Duet exactly?
      https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
      • Richygoatundefined
        Richygoat
        Here is no answer to this question. I want to turn the PSU off with this modul. When it get 5v continuously from the Duet it stays always on. When there is 5v, GND an PS_ON on that connector how does it exactly work. I know this is 5v in. Does the PS_ON switch the 5V to PS_ON?
          Richygoat
          Ok the PS_ON pin will be connected to Ground when the PSU have to be enabled. Is there a way to get a 5v Signal to shut the Relay down? See the picture attached.dr6X10S.png
            Richygoat
            Is something like this possible?
              Richygoat
              This is how it works perfekt. Big thanks to Eryion from Rics 3D Discord.dr6X10S.png
              CrazyCreatorundefined Ugurundefined 2 Replies Last reply Reply Quote 0
              • CrazyCreatorundefined
                CrazyCreator @Richygoat
                @Richygoat
                I edited your sketch and "connected" the switch button. Is that right, did you mean it?1587974008507-dr6x10s.png
                And a other, next question ...
                Can you turn off the printer when it is connected via web interface???
                http://www.crazycreatorcube.com
                Del87undefined 1 Reply Last reply Reply Quote 0
                  Richygoat
                  Yes that is correct. The 12V/24V is only for the Button LED. Yes i can turn the Printer via Web Interface off.
                    CrazyCreator
                    thanks for the info
                    • Del87undefined
                      Del87 @CrazyCreator
                      @CrazyCreator Hello! Tell me please: what is the white line at the bottom? It is pin connection
                      between top left on black port and top one on the white? And the black line
                      between ps_on and module connects central pins?
                      Thank you in advance for the answer.
                      Dmitry
                      • Ugurundefined
                        Ugur @Richygoat
                        @Richygoat hi, I have panel due with sd card. How i will connect this module?
