    cr-10s upgrade to duet 2 wifi motors and ac 750w bed problems
    906
    • DocTrucker
      DocTrucker @jobesynoob1234 last edited by
      @jobesynoob1234 it's easy enough to miss the piece of documentation that has the right information for you when new. My posts were intended to help, but their brief nature probably came over as being snappy. Not intended.
      Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
      • jobesynoob1234
        hi again well re-did my reprap and heres the new config.g
        ; generated by RepRapFirmware Configuration Tool v2 on Mon May 13 2019 10:59:27 GMT+0100 (British Summer Time)
        M550 P"CREALITY CR-10S" ; Set machine name
        M552 S1 ; Enable network
        M586 P0 S1 ; Enable HTTP
        M586 P1 S1 ; Enable FTP
        M586 P2 S0 ; Disable Telnet
        M569 P0 S0 ; Physical drive 0 goes forwards
        M569 P1 S0 ; Physical drive 1 goes forwards
        M569 P2 S1 ; Physical drive 2 goes forwards
        M569 P3 S1 ; Physical drive 3 goes backwards
        M92 X80.00 Y80.00 Z400.00 E842.00 ; Set steps per mm
        M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min)
        M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
        M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X285 Y285 Z385 S0 ; Set axis maxima
        M574 X1 Y1 Z1 S1 ; Set active low and disabled endstops
        M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
        G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
        M557 X15:195 Y15:195 S20 ; Define mesh grid
        M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
        M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
        M143 H1 S285 ; Set temperature limit for heater 1 to 285C
        M563 P0 D0 H1 ; Define tool 0
        ; Automatic power saving
        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        all motors home but my z still sounds energized and doesnt back off the endstop switch 😕
        • Veti
          Veti last edited by
          have a look at you homeall.g
          it explains it
          ;G91 ; relative positioning
          ;G1 S2 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          • jobesynoob1234
            like this
            //;G91 ; relative positioning
            //;G1 S2 Z5 F100 ; lift Z relative to current position
            //;G90 ; absolute positioning
            Veti 1 Reply Last reply Reply Quote 0
            • Veti
              Veti @jobesynoob1234 last edited by
              @jobesynoob1234
              no // is c/java (and other programming languages)
              uncomment mean removing comments not adding them.
              so remove the ;
              • jobesynoob1234
                yip thats one of them confusing parts 🙂 with me using marlin
                i did that and it now lifts but i can still hear power going through it 😕 is that normal
                • Veti
                  Veti last edited by
                  see
                  https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise
                  • jobesynoob1234
                    Ok i would like to say a massive thank you veti and doctrucker for steering me in the right direction you have saved me a lot of stress 🙂 all motors home heatbed works now i just need to level the bed and try a print 🙂 i still need to look into that "reducing stand still noise" but the important parts are sorted now so im a very happy bunny thank you again for your time
                      dc42 administrators @jobesynoob1234 last edited by dc42
                      @jobesynoob1234 said in cr-10s upgrade to duet 2 wifi motors and ac 750w bed problems:
                      i did that and it now lifts but i can still hear power going through it is that normal
                      That's not uncommon. The current will be reduced automatically by a specified amount (default is to 30% of normal) after a specified idle time (default is 30 seconds), so it should get quieter after that. You can adjust that 30% and 30 seconds, they are controlled by the M906 command in config.g. If you find the standstill noise loud enough to be annoying, see the link posted by @Veti.
                      jobesynoob1234 1 Reply Last reply Reply Quote 0
                        The Creality motors seem to have a rather unpleasant whine at low power for some reason. It's not so much loud as it is piercing. 😫
                        • jobesynoob1234
                          jobesynoob1234 @dc42 last edited by
                          @dc42 hello yip thats what i also did i knocked it down to 10seconds 🙂
                          • jobesynoob1234
                            jobesynoob1234 @Phaedrux last edited by
                            @phaedrux so will it help if i shove the current up to 1000ma 😕 i did first put them to 750ma!
                            • Veti
                              @jobesynoob1234
                              changing the current will not change the noise.
                              • jobesynoob1234
                                jobesynoob1234 @Veti last edited by
                                @veti ah right well they can stay where they are then 🙂
