    Motor phase disconnected problem?
    989
    • siblues
      siblues last edited by
      I just finished rewiring my machine and it has been printing fine for a day or two and it started displaying this message
      Warning: motor phase A may be disconnected reported by driver(s) 1
      This is my config file
      ; generated by RepRapFirmware Configuration Tool on Mon Nov 05 2018 12:42:23 GMT-0500 (Eastern Standard Time)
      ; Set machine name
      ; Set password
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes forwards reversed
      M569 P2 S0 ; Drive 2 goes forwards reversed
      M92 X80 Y80 Z400 E415 ; Set steps per mm
      M566 X900 Y900 Z12 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y250 Z250 E2500 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-25 Y0 Z0 S1 ; Set axis minima
      M208 X220 Y320 Z200 S0 ; Set axis maxima
      M574 Y1 S0 ; Set active low endstops
      M574 X1 S1 ; Set active high endstops
      M574 Z1 S2 ; Use zprobe for zmin
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H3 F200 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X24 Y0 Z3.385 ; Set Z probe trigger value, offset and trigger height
      M557 X25:200 Y30:300 S40 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S110 ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4725 C7.06e-8 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S290 ; Set temperature limit for heater 1 to 290C
      M106 P1 S1 I0 F500 H0:1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H0:1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      M501 ; Override
      This is the software information
      Firmware Version: 2.03beta2 (2019-02-16b1)
      WiFi Server Version: 1.22
      Web Interface Version: 1.22.5
      • siblues
        The wiring and connectors seem fine and the connectors are firmly seated onto the board.
        • siblues
          siblues last edited by siblues
          I rewired the motor and endstop with a new harness to make sure it wasn't a wire that may have gotten loose or a terminal that wasn't crimped tightly but no luck with the new harness.
          • siblues
            I contacted Filastruder to see if this is a warranty repair or if I need to pay for the repair myself.I really would like to know what is going on.I can't seem to find much information on what may be causing this.
            I hve also tried this version of firmware with no change
            2.02RC2(RTOS) (2018-09-07b2)
            • siblues
              I had the fault happen again and ran M122 afterwards to see if tht would clear anything up and here are the results
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC2(RTOS) running on Duet WiFi 1.02 or later
              Board ID: 08DGM-9T6BU-FG3SN-6JKD6-3S06P-KAYBD
              Used output buffers: 3 of 20 (12 max)
              Static ram: 28460
              Dynamic ram: 98312 of which 0 recycled
              Exception stack ram used: 356
              Never used ram: 3944
              Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,3540)
              Owned mutexes:
              Last reset 02:00:41 ago, cause: software
              Last software reset at 2019-05-20 22:28, reason: User, spinning module GCodes, available RAM 4016 bytes (slot 0)
              Error status: 0
              Free file entries: 10
              MCU temperature: min 35.3, current 35.9, max 36.7
              Supply voltage: min 12.6, current 12.8, max 12.9, under voltage events: 0, over voltage events: 0
              Driver 0: standstill, SG min/max 0/73
              Driver 1: standstill, SG min/max 0/221
              Date/time: 2019-05-21 00:29:29
              Slowest loop: 5.22ms; fastest: 0.06ms
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 234, MaxWait: 6955014ms, Underruns: 0, 0
              Scheduled moves: 45, completed moves: 45
              Bed compensation in use: mesh
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 22.84ms; fastest: 0.01ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is running
                WiFi firmware version 1.22
                WiFi MAC address 84:f3:eb:42:a9:91
                WiFi Vcc 3.45, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25504
                WiFi IP address 192.168.1.6
                WiFi signal strength -37dBm, reconnections 0, sleep mode modem
                === Expansion ===
              • Veti
                Veti last edited by
                update to the latest 2.03 firmware. DC made a fix for that message i think
                • siblues
                  I was using 2.03 and he recommended reverting back to 2.02 RC2 and I tried that too with no luck.
                  • elmoret
                    elmoret last edited by
                    @dc42 - How do you think we should proceed here?
                    • siblues
                      Are you asking me?That is what I am trying to figure out.I was hoping DC42 would chime in since he usually has a quick solution or ways of figuring out if the board is damaged.
                        @siblues, please can you do the following:
                        1. Make sure you are running either 2.02 stable firmware (not a 2.02beta or 2.02RC version), or 2.03RC2.
                        2. Next time this problem occurs, please run M906 without parameters and check that it reports the motor currents are as you set them (1200mA). Also run M913 and check they are at 100%.
                        3. Do you have anything connected to the expansion connector?
                        4. Do the warning messages mention just phase A and just driver 1? Or more drivers and/or both phases?
                        • siblues
                          6:54:46 PMM906
                          Motor current (mA) - X:1500, Y:1500, Z:1500, E:1200:1200, idle factor 30%
                          6:54:34 PMError: motor phase A disconnected on drivers 1
                          6:57:27 PMM913
                          Motor current % of normal - X:100, Y:100, Z:100, E💯100
                          6:56:51 PMError: motor phase A disconnected on drivers 1
                          I only have the BLTouch connections on the expansion header on heater 3. The X axis motor and extruder motor aren't and haven't given me the error while the Y axis and z axis both have given me the error but I couldn't reproduce the x motor having the issue at the moment.Here is the current software information
                          Firmware Version: 2.02RC2(RTOS) (2018-09-07b2)
                          Web Interface Version: 1.22.6
                          Web Interface by Christian Hammacher
                          Licensed under the terms of the GPL v3
                          Veti 1 Reply Last reply Reply Quote 0
                          • Veti
                            Veti last edited by
                            so you swapped the wiring. can you swap the motor to make sure its not the motor?
                            • siblues
                              It is 3 different motors that are all giving me the message but I can swap the motors if that would make it easier to diagnose?
                              • Veti
                                Veti last edited by
                                so far you have only shown the error message about phase A on driver 1.
                                does it happen with all phases on all drivers?
                                • siblues
                                  I was also getting the error message on the Z axis motors but that error message is random and hasn't happened again.The Y axis does it everytime.
                                  • siblues
                                    The motors attempt to move when using DWC but they stutter shaking back and forth. I attempted raising the voltages slightly but it made no difference.
                                    • Veti
                                      Veti @siblues last edited by
                                      @siblues said in Motor phase disconnected problem?:
                                      6:54:46 PMM906
                                      this does not match
                                      but you have a M501
                                      so please post your overwrite.
                                      siblues 1 Reply Last reply Reply Quote 0
                                        dc42 administrators @siblues last edited by
                                        Common reasons for this:
                                        1. Motors not phased correctly. This is serious as it can cause the drivers to be damaged. So check that the motor phases are connected correctly first.
                                        2. Bad crimp connection in the motor wires, so that only one phase is being energised.
                                        3. Speed and/or acceleration set too high, bearing in mind the steps/mm (higher steps/mm => lower accelerations and speeds possible).
                                        4. Weak PSU, so that the voltage drops below 10V when the motors draw current.
                                        5. Blown stepper driver.
                                        6. Blown motor.
                                        • siblues
                                          siblues @Veti last edited by
                                          @veti Here is the override and the current was changed to 1500 to test it is set at 1200 usually.
                                          @dc42 The motors have been working just fine for a while with that original harness and the harness has since been replaced.The printer has a genuine Meanwell 450watt 12v psu and it only fluctuates .02 volts.Here are the current motor settings for what I have set for speed.
                                          I can check the motor but how would I check for a blown driver and what would cause that to happen all of a sudden?
                                          • T3P3Tony
                                            T3P3Tony administrators @siblues last edited by T3P3Tony
                                            @siblues you can check to see if it's a driver by swapping the motors plugged into a working axis with the not working one. Drivers can get blown when wiring develops intermittent faults in a single phase.
                                            Duet Hardware Designer
                                            www.duet3d.com
                                            • siblues
                                              I had some motors on the way so I tried what Tony mentioned and it was a bad motor.
