problem with the Mesh?second print start in the air
Hi
when i made the Mesh Compensation alls works fine the first print after Mesh is perfect but the second print start to print in the air,why ?
i hope you can help me
thats my config.g
; generated by RepRapFirmware Configuration Tool v2 on Thu Apr 11 2019 17:51:12 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"AM8" ; Set machine name
M552 S1 ; Enable network
M587 S"WLAN-110ff5" P"395fff710671ffff90" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes forwards X
M569 P1 S0 ; Drive 1 goes forwards Y
M569 P2 S1 ; Drive 2 goes backwards Z
M569 P3 S0 ; Drive 3 goes forwards Extruder
M569 P4 S1 ; Drive 4 2nd Z-motor - Normally used as Extruder 1; Motor Remapping
M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation
M92 X100.00 Y100.00 Z400.00 E107.16 ; Set steps per mm
M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
M906 X1400.00 Y1400.00 Z1400.00 E1600.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
;M671 X-15:205:205 Y105:205:15 P0.5 ; für manual bed levelling
M671 X-33:220 Y0:0 S0.5 ; leadscrews at left and right of X axis für 2 motoren
M208 X-33 Y-10 Z0 S1 ; Set axis minima
M208 X220 Y210 Z200 S0 ; Set axis maxima
;M208 X-33:210 Y-10:210 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200; Endstops
M574 X1 Y1 S0 ; Set active low and disabled endstops; Z-Probe
M558 P5 I1 R0.4 F350 X0 Y0 Z0 ; Set Z probe type to effector and the dive height + speeds
G31 X0 Y0 Z0.320 P100 ; Set Z probe trigger value, offset and trigger height
M557 X10:210 Y10:210 S40 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 to 130C
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S275 ; Set temperature limit for heater 1 to 275C; Fans
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
T0 ; Select first toolbed.g
; bed.g
; generated by RepRapFirmware Configuration Tool v2 on Mon Apr 29 2019 10:01:00 GMT+0200 (Mitteleuropäische Sommerzeit)
;G29 ; probe the bed and enable compensationG28 ; home
M401 ; deploy Z probe (omit if using bltouch)
G30 P0 X10 Y110 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X210 Y110 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
M402 ; retract probe (omit if using bltouch)
G1 X110 Y110 ; Go to Bed Center
G30 ; Probe Center
are you loading the mesh file in your homeall.g?
I dont have touch The homeall.g
Do i need to change something in homeall.g ?
this is my homeall.g
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 S1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-258 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X10 Y10 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
What firmware version are you using?
What do you have in your slicer start and end gcode?
running a G28 will clear your bed mesh.
if you want to use the stored heightmap you will need to run G29 S1 after every G28
Does g28 clear the mesh? I didn't think it does. But I'm really not sure come to think of it.
@phaedrux said in problem with the Mesh?second print start in the air:
You are right it does not. i just checked.
I must have confused it with marlin where it does.
@lui2004
nevertheless you need a G29 S1 somewhere to load the mesh after powering up your printer.
Hi
The heightmap ist Stored i can open it in my sd-card.
Do i need do load G29 S1 every Print i started?if yes i dont have do it
@lui2004
no but it is a good idea to do so.
it is just a command and does not take up time.
Ok i will give it a try
Or i insert the gcode in my bed.g to load automatic
Or put it in your Slicer 'Start GCode', easiest way I find.
I have G29 S1 at the end of my config.g that way it's loaded every time on startup.
so the first print after mesh works perfectly but when i start the second the nozzle is to high
i have try to send beofor i start the second print G29 S1 but always the nozzle to high
Firmwarename: RepRapFirmware for Duet 2 WiFi/Ethernet
Firmware Elektronik: Duet WiFi 1.02 or later
WiFi Server Version: 1.22
Web Interface Version: 1.22.6i hope you can help to solve it
you do home before each print?
yes in my slicer is this starting code
G28 ; home all axes
@lui2004 what is at the end of your files that the slicer is putting in there?
I have only G28 i my starting code nothing else
do check with m122 that mesh bed leveling is still active.
@veti said in problem with the Mesh?second print start in the air:
m122
seems active
Bed compensation in use: mesh
Bed probe heights: -0.052 -0.028 0.000 0.000 0.000
Are you able to reproduce this problem without doing an actual print? Or with a "print" comprising just a few lines of GCode taken from a real print?
do i need to post gcode from a print ?
What I would like a the GCode for a simple sequence that replicates the problem - not a full GCode file that takes a long time to print, but a very simple one that takes only a few seconds.
if you explane me how to do this i will post it
because now i finisched my first print after mesh and the second print is to heigh from the bed
@lui2004 Please share a small gcode file from your slicer that causes this issue.
