    2.03 + PanelDue 7i
    Firmware installation
    953
    • flingierundefined
      flingier
      Upgraded Duet 2 Ethernet to firmware 2.0.3 and suddenly, the connected PanelDue 7i remains blank. Was working with 2.02 before. Didn't downgrade yet, as I'm still building the printer and have PC closeby with access to the webinterface.
      • A Former User?
        A Former User
        The panel has its own firmware and will display its interface independent of the Duet, so if the panel is blank that would suggest a problem with the firmware on the panel, an issue with the power supply to the panel or possibly damage to the panel i think which is really strange as you say it worked before the update.
        Maybe some else can chime in with more insight.
          If you disconnect the panel from the Duet and connect it to a PC via usb, does it power up?
          • kthoma85undefined
            kthoma85
            Phaedrux, I am working on putting a Duet 2 and a Panel 7 together. White screen when connected to Duet works normal when connected via USB. Any suggestions?
              Phaedrux Moderator @kthoma85
              @kthoma85 how have you got it connected?
              • kthoma85undefined
                kthoma85
                The ribbon cable that is connected to the Panel Due.
                  Can you test with the 4 pin connector instead?
                  • kthoma85undefined
                    kthoma85
                    What is the 4 pin connector? Do I need to make one?
                    • kthoma85undefined
                      kthoma85
                      So that is what the other cable that came with the panel is for? I can try it later.
                        The 4 pin connector is the preferred method of connection. It's far more robust and less prone to connectivity issues. The cable length can be much greater as well.
                        • nhofundefined
                          nhof
                          You will still need the ribbon cable if you are using the SD card slot on the paneldue, but you only need the 4-wire otherwise.
                          You can also plug both in and it should work fine.
                            Check that you have the ribbon cable connected to the right port on the Duet, which is CONN_SD, not CONN_LCD despite the name.
                            • A Former User?
                              A Former User
                              Shouldn't the firmware on the PanelDue show the interface and not a white screen as long as it has sufficient power regardless of communication with the Duet? -
                              • kthoma85undefined
                                kthoma85
                                I connected the 4wire connector and it is working fine. Now do I connect the ribbon cable to the blue circle or the orange circle?0_1567695079482_Panel Due connection.png
                                nhofundefined 1 Reply Last reply Reply Quote 0
                                • PaulHewundefined
                                  PaulHew
                                  Unless you need to use the SD card in the PanelDue, i would not.
                                  As @Phaedrux mentioned, you can have a longer cable with the 4 pin, the ribbon cable has a length limit.
                                  I upload everything from a computer via a network so no need for the PanelDue SD.
                                  RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                                  Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                                  • nhofundefined
                                    nhof @kthoma85
                                    @kthoma85 said in 2.03 + PanelDue 7i:
                                    The blue one marked "External SD Card" will also power the PanelDue.
                                    • kthoma85undefined
                                      kthoma85
                                      Thank you everybody. I am good to go now.
                                        dc42 administrators @A Former User
                                        @bearer said in 2.03 + PanelDue 7i:
                                        Yes, if the ribbon cable is sound and connected to the correct connector on the Duet.
