Duet Maestro skipping layers while printing
  • Hi, my Promega has the Duet Maestro. It just started to randomly change layers while printing. It often skips several layers at a time. Such as layer one skipping to layer 10. After that about 100 error codes show up letting me know the machine is out of bounds. I then have to turn the printer off since the buttons are unresponsive. Please help. I'm trying to point some business parts and it is somewhat urgent! Thanks
  • Please share your config.g, a config-override.g if you have one and an example gcode file
  • Thank you. I'll do that in just a few.
    I also just recieved a new error code after homing the printer.
    The error code reads that there is a java script error and that it disconnected the duet board. I will send a screenshot with my next message that includes the g.codes
  • Alright, here's the gcodes , except the backup gcode, and the picture of the new javascript error. Thanks so much for you help.
    0_1563647079305_config.g
    0_1563647122748_CFFFP_f094a0f4-815f-4efa-8e16-e975c668113f.gcode
  • The JavaScript error code showed up again, but this time it showed up right after I tried to disable the mesh bed leveling.
  • Also try running M122 and copy the output here. If the web interface doesn't run reliably, try connecting with YAT or pronterface.
  • M122
    RepRapFirmware for Duet 2 Maestro version 2.02RC5(RTOS) running on Duet Maestro 1.0
    Board ID: 08D8M-9T8A2-MQNSS-6J9D2-3SD6R-967GY
    Used output buffers: 3 of 20 (18 max)
    Static ram: 21236
    Dynamic ram: 96988 of which 0 recycled
    Exception stack ram used: 420
    Never used ram: 12428
    Tasks: NETWORK(ready,456) HEAT(blocked,1300) MAIN(running,3672) IDLE(ready,200)
    Owned mutexes:
    Last reset 00:47:24 ago, cause: power up
    Last software reset at 2019-07-16 13:02, reason: User, spinning module GCodes, available RAM 12468 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    SD card 0 detected, interface speed: 15.0MBytes/sec
    MCU temperature: min 34.6, current 34.7, max 35.1
    Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, read errors 0, write errors 0, ifcount 15, reads 871, timeouts 0
    Driver 1: standstill, read errors 0, write errors 0, ifcount 15, reads 871, timeouts 0
    Driver 2: standstill, read errors 0, write errors 0, ifcount 15, reads 871, timeouts 0
    Driver 3: standstill, read errors 0, write errors 0, ifcount 11, reads 871, timeouts 0
    Driver 4: standstill, read errors 0, write errors 0, ifcount 8, reads 871, timeouts 0
    Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 871
    Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 871
    Date/time: 2019-07-20 11:48:46
    Slowest loop: 3.82ms; fastest: 0.07ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 7, completed moves: 7
    Bed compensation in use: mesh
    Bed heaters = 0, chamberHeaters = -1 -1
    Heater 0 is on, I-accum = 1.0
    Segments left: 0
    Stack records: 3 allocated, 0 in use
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    lcd is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 69.93ms; fastest: 0.02ms
    HTTP sessions: 1 of 8
    Interface state 5, link 100Mbps full duplex
  • Can you run M122 directly after the layer skips happen, before you got emergency stop?
  • Also, you're running an unsupported 2.02 rc release,ake sure you update to 2.03
  • Moderator
    It looks like your firmware and DWC are a bit out of date or mismatched. Please try updating everything to the 2.03 release.
    https://github.com/dc42/RepRapFirmware/releases/tag/2.03
    You should be able to simply upload this zip file as is to the settings page: https://github.com/dc42/RepRapFirmware/releases/download/2.03/Duet2Firmware-2.03.zip
  • Thanks. I'll update a little later today and give that a shot.
    Here is the M122 code that appeared after the same issue.
    M122
    Used output buffers: 3 of 20 (20 max)
    Static ram: 21236
    Exception stack ram used: 380
    Never used ram: 12468
    Owned mutexes:
    Last reset 00:19:20 ago, cause: power up
    Error status: 4
    Free file entries: 9
    SD card longest block write time: 63.0ms, max retries 0
    MCU temperature: min 24.0, current 38.2, max 38.3
    Supply voltage: min 23.0, current 23.2, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, read errors 0, write errors 0, ifcount 12, reads 46375, timeouts 0
    Driver 1: standstill, read errors 0, write errors 0, ifcount 12, reads 46375, timeouts 0
    Driver 2: standstill, read errors 0, write errors 0, ifcount 12, reads 46375, timeouts 0
    Driver 3: standstill, read errors 0, write errors 0, ifcount 10, reads 46376, timeouts 1
    Driver 4: standstill, read errors 0, write errors 0, ifcount 8, reads 46379, timeouts 0
    Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 46386
    Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 46386
    Date/time: 2019-07-20 14:55:27
    Slowest loop: 4581228.50ms; fastest: 0.06ms
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 130, MaxWait: 737781ms, Underruns: 0, 0
    Scheduled moves: 594, completed moves: 594
    Heater 0 is on, I-accum = 0.9
    Heater 1 is on, I-accum = 0.2
    Segments left: 0
    === Network ===
    Slowest loop: 4581228.50ms; fastest: 0.02ms
  • there was a problem in the 2.02 firmware with time keeping that caused layer shifts.
    @veti said in Duet Maestro skipping layers while printing:
    That issue was in some 2.02RC and earlier releases. I fixed it before the 2.02 stable release.
  • @dc42 said in Duet Maestro skipping layers while printing:
    yes. he is using 2.02RC5, which was affected.
  • Awesome. You guys have been a great help. I'll respond today or tomorrow after I've updated it. Thank you again.
  • It's working better than ever. Guess it just needed a firmware update.
    Thanks a bunch for your fast and professional help. Even though the solution was simple, i likely wouldn't have ever fixed the issue since I was at the end of my rope. So, thanks again.
