    Support for MKS mini 12864 LCD panel
    328
    • hussainsail2002
      hussainsail2002 last edited by
      Hi all,
      Would like to know if the duet wifi supports the MKS mini LCD panel or any other LCD panel like Full graphics controller, etc.
      Its just a economical option, and has front sd card loading which I find more convenient.
      Thanks
      Hussain.
      • Veti
        Veti last edited by
        no the duet wifi is missing functionality required for the support.
        only the duet maestro has support for a 12864 lcd.
        • hussainsail2002
          Thanks for the reply,
          Does the duet support any other touch screen apart from the panel due.
          Or is the UI on panel due modifiable ?
          Regards,
          Hussain
          • DocTrucker
            DocTrucker last edited by
            The source code for the Panel Due is open source and available on GitHub.
            • DocTrucker
              https://github.com/dc42/PanelDue
              dc42 1 Reply Last reply Reply Quote 1
                There's also this for repurposing a tablet as customizable display.
                https://forum.duet3d.com/topic/9257/dueui-1-1-0-is-released
                • oliof
                  oliof last edited by
                  There also exists (incomplete) firmware so that the MKS tft panel can be used similar to a PanelDue, see https://forum.duet3d.com/topic/2593/mks-tft32-duet for details (the firmware needs some undisclosed fix to work with recent versions of RRF though)
                    dc42 administrators @DocTrucker last edited by
                    @doctrucker said in Support for MKS mini 12864 LCD panel:
                    The current firmware is at https://github.com/dc42/PanelDueFirmware.
                    • hussainsail2002
                      Thank you all for your replies !
                      Will look into these !
