    Connecting to NAS
    Duet Web Control
    connection
    • RAMundefined
      RAM
      Is it possible to connect to a NAS for the purpose of getting access to stl files ?
      deckingmanundefined dragonnundefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti
        the duet2 does not offer any functionality like that.
        on the upcomming duet3 that should be possible.
        • deckingmanundefined
          deckingman @RAM
          @ram You can upload files using the web interface. So if you have stl files on a NAS then the simplest thing to do would be to create a share on the NAS to those files. Or you could add a network location on a PC which would treat that share as another drive and access the stl files that way.
          • dragonnundefined
            dragonn @RAM
            @ram said in Connecting to NAS:
            What is the purpose of having access to STL files in Duet?
            Duet can't do anything with STL files
              deckingman @dragonn
              @dragonn said in Connecting to NAS:
              Well spotted - I missed that ☺ .
              Let's assume he meant gcode files...........
              RAMundefined 1 Reply Last reply Reply Quote 0
              • RAMundefined
                RAM @deckingman
                @deckingman yes sorry I did mean GCode files and thanks for the answer 😉
                • T3P3Tonyundefined
                  T3P3Tony administrators @RAM
                  @ram yes you can push files to the Duet but it can't go out and "pull" them (at least with Duet 2). Duet 3 OTOH will allow for a plugin to be written on the SBC that does that.
                  www.duet3d.com
