    Duet 3 Mainboard 6HC - initial production run.
    243
    34.1k
    • T3P3Tonyundefined
      T3P3Tony administrators
      We have completed our prototyping phase of the Duet 3 Mainboard and will be starting a limited initial production run shortly.
      render of the Duet 3 Mainboard 6HC
      Headlines:
      • 6 Stepper channels, at least 4A per channel.
      • High speed dedicated bus to a single board computer.
      • 2 CAN-FD buses for expansion.
      • 10 PWM outputs for Bed heater, extruders, fans (example configuration is 3 extruders with 2 fans per extruder).
      • 9 IO headers for Endstops, probes, filament sensors and other low bandwidth sensors.
      • 4 Thermistor/PT1000 inputs and support for 2 temperature daughterboards (4 PT100s or Thermocouples).
      Boards from this run are available for pre-order here:
      https://www.duet3d.com/Duet3Mainboard6HC
      This is on a first come first served basis.
      We will begin delivery the first week of September, in the order we receive your purchases.
      Initial documentation is available:
      Duet 3 Mainboard 6HC Hardware Overview
      Duet 3 Mainboard 6HC Wiring Diagram
      We are also busy testing the second set of 3 channel expansion board prototypes, there is some more information on these here: Duet 3 Expansion Hardware Overview
      www.duet3d.com
      deckingmanundefined 1 Reply Last reply Reply Quote 8
      • DocTruckerundefined
        DocTrucker
        Great news. I'll be watching this as closely, and plan upgrades as soon as business income allows.
        Meanwhile I will be watching ebay like a Hawk for retired and unloved Duet 2 boards! 😄
        • Immutefundefined
          Immutef
          Any plans for the 3 stepper driver expansion board to be available for pre-order, too?
          • T3P3Tonyundefined
            T3P3Tony administrators @Immutef
            @immutef It will be, but not on the same timelines at this point. We are evaluating the prototypes now.
            www.duet3d.com
            • Immutefundefined
              Immutef
              All right. Unfortunately I'd need 7 stepper drivers for proper testing, so i'll sit back and wait 😉
              • NitroFreakundefined
                NitroFreak
                is the expansion breakout board compatible with this? alternatively, does this natively support the 5v step/dir logic output?
                IMHO stepper drivers are a relic of the past and this next gen board should natively be compatible with at least the low end servos that use the 5v logic. If not the high end servos that use CAN bus.
                T3P3Tonyundefined Maboverundefined 2 Replies Last reply Reply Quote 0
                • T3P3Tonyundefined
                  T3P3Tony administrators @NitroFreak
                  @nitrofreak we are designing a series of CAN connected expansion boards (and tool boards :D)
                  https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_Hardware_Overview
                  Thats just the first one that we have in test.
                  To use external drivers we will be making another expansion board dedicated to that. If in the future there is demand we might also make a mainboard designed specifically for external drivers.
                  Stepper drivers definitely have their place, as do servos, the long term goal for the Duet 3 family is to support a wide range of motor options from steppers, servos, BLDCs etc. Clearly it will take time to develop the expansion modules!
                  www.duet3d.com
                  Maboverundefined Aurimasundefined 2 Replies Last reply Reply Quote 0
                  • denkeundefined
                    denke
                    Damn, cool board! Also you solved all the limitations of duet2 which I came across, very nice work, congrats!
                    • Maboverundefined
                      Mabover @NitroFreak
                      @T3P3Tony
                      CanOpen support would be great as that is what the industrial servo and stepper drives normally support
                      See https://www.can-cia.org/canopen/ for more info
                      • Maboverundefined
                        Mabover @T3P3Tony
                        @t3p3tony
                        I also see mention on the about wiki page that the ethernet port may possibly support EtherCAT in the future, is that EtherCAT slave or master function. Master support would be totally amazing to have as you could integrate EtherCAT servo/stepper drives (depending on what protocol is used, CanOpen over EtherCAT is the most common). Slave support would also be very interesting as it would allow for a low cost EtherCAT multichannel stepper drive with I/O which could easily be used with Linuxcnc.
                          CanOpen and EtherCat are both possibilities for the future.
                          CanOpen has far too little bandwidth to use for 3D printing, so we are not using it for communication between the main board and the expansion board. Instead we are using the faster Can-FD hardware specification and a protocol loosely based on UAVCan. But the main board supports a second CAN bus that could be used to control slower devices using CanOpen.
                          We hope to provide EtherCat master support sometime in the future. EtherCat slave devices require a royalty payment, but master devices do not.
                          Maboverundefined stefmaundefined 2 Replies Last reply Reply Quote 1
                          • gtj0undefined
                            gtj0
                            Damn. I just bought groceries. I guess I'll have to wait until next month to order. 😞
                            • gtj0undefined
                              gtj0
                              @dc42 Is the DSF tied to Rpi implementations or can we use any SBC that has an SPI bus interface? For instance, I have a half dozen quad core Wandboards with SPI interfaces.
                              Oh and maybe this is a question for @chrishamm but what made you guys go with C# and .NET for the DSF?
                              A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                              • A Former User?
                                A Former User @gtj0
                                Its no longer tied to wiringpi library for SPI at least. I suspect official support will be limited, initially at least, but you'll have a fighting chance at least
                                gtj0undefined 1 Reply Last reply Reply Quote 0
                                • gtj0undefined
                                  gtj0 @A Former User
                                  @bearer said in Duet 3 Mainboard 6HC - initial production run.:
                                  Not having official support doesn't worry me 🙂
                                  • A Former User?
                                    A Former User
                                    @T3P3Tony
                                    Purchased, im happy to be an early adopter to support the amazing work you guys do.
                                    looking forward to getting this thing in my hands.
                                    Regards
                                      dc42 administrators @gtj0
                                      @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
                                      It's not tied to RPi, but if you use a different SBC then you will need to port Duet Software Framework to it, and that SBC has better have a good SPI and GPIO driver unless you can write them yourself.
                                      If the SD card socket is fitted to the Duet 3 then it will be possible to run it in standalone mode (i.e. without the RPi or other SBC) by using the Ethernet interface; but if you do that, you will miss out on a lot of features.
                                      Using C# and .NET was chrishamm's choice. But in my experience, it is way more productive than programming in C++, when you have the computing power to absorb the additional overhead. Having memory management makes coding much simpler, and the run-time checking of pointers, array bounds etc. speed up fault detection hugely. A few days ago I spent three hours tracking down a null pointer dereference in RRF3 on Duet 3. That would have been pinpointed instantly had I been able to use .NET instead of C++.
                                      gtj0undefined 1 Reply Last reply Reply Quote 1
                                      • gtj0undefined
                                        gtj0 @dc42
                                        The Freescale iMX6 platform is well supported in Linux. I wrote some of the device tree and driver stuff for it. 🙂
                                        Not criticizing the choice of C#, just curious. I haven't done any C# development in about 10 years so I'll have to see what .NET dev tools are like for Linux these days. Hopefully there's an Eclipse plugin. 🙂
                                        Phaedruxundefined 1 Reply Last reply Reply Quote 1
                                        • A Former User?
                                          A Former User
                                          Hi Guys
                                          Brain is wandering here. With this new equipment and its expansion capabilities.
                                          Do you think one Duet-3 with expansion boards could be configured to control for example three identical printers, X3 Y axis drivers, X3 Y axis drivers X3 Z axis drivers and X3 extruder drivers all running at the same time (properly calibrated of course) im thinking print farm applications where numerous printers of the exact same make, model etc are all printing the same g-code at the same time.
                                          Thoughts.
                                          JoergS5undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                          • JoergS5undefined
                                            JoergS5 @A Former User
                                            @calvinx IMHO it should be possible to augment IDEX printers to have three extruders.
