    Presentation of the CR-3D C1 with Duet Electronics
    My Duet controlled machine
    1.6k
    • CR3Dundefined
      CR3D
      Hello dear community,
      I am Christian from CR-3D, a german 3d printer manufacturer.
      I just wanted to introduce you to my new CoreXY printer, the C1, with a print volume of 320x250x350mm.
      In C1 a Duet Wifi is installed. As an Auto BedLeveling sensor I use the IR Probe. As a user interface I use a 7 inch Raspberry Touch with Repetier Server.
      The 230V AC heatbed can be heated up to 120°C and has a magnetic exchange system of the printplates.
      The CoreXY Motionsystem will soon also be extended by a ToolChanger and there are different printheads.
      Here is a picture ...
      Greetings your Christian (CR-3D)
      www.cr-3d.de
      https://www.facebook.com/CR.3DPrinting
      https://www.instagram.com/cr.3d_official
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      • oliofundefined
        oliof
        Looks nice! What led you to choose repetier server over DWC?
        CR3Dundefined 1 Reply Last reply Reply Quote 2
        • Danalundefined
          Danal
          Christian, that looks great! Nicely enclosed, good build volume. And, it is great to have a printer that is pre-built and just "comes with" a Duet to recommend to people who ask.
          However... same question as above: Why not either a PanelDue or the Pi running a web browser and DWC? Running anything else would seem to undo quite a bit of the advantages of a Duet board.
          • A Former User?
            A Former User
            I can only concur with what has already been said, to use repetier server is in my humble opinion a major faux pas, verging on stupidity..... akin to buying a lamborghini and pulling four plugs out of one bank of cylinders....
            Other than that the mechanics and aesthetics look nice.
            But seriously Ditch repetier server otherwise I dont think you will sell too many units.
            • oliofundefined
              oliof
              I have no experience with Repetier host, so my question was completely in good faith by the way. I think whatever moved Christian to choose Repetier host is likely interesting to Chris Hamm as a differential to current DWC ...
              • taconiteundefined
                taconite
                Maybe cause you cant't have a custom UI on the PanelDue (or ist that possible)?
                Custom ANET A8
                Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                All I do here is under this license: CC BY-NC-SA
                Danalundefined 1 Reply Last reply Reply Quote 0
                • Vetiundefined
                  Veti
                  @taconite said in Presentation of the CR-3D C1 with Duet Electronics:
                  the source code is available and can be customised.
                  taconiteundefined 1 Reply Last reply Reply Quote 0
                  • taconiteundefined
                    taconite @Veti
                    @veti yeah sure it is but it is not that easy (or is it)?🙈
                    Custom ANET A8
                    Vetiundefined 1 Reply Last reply Reply Quote 0
                    • Vetiundefined
                      Veti @taconite
                      @taconite
                      you asked if its possible, not if its easy. ☺
                      • taconiteundefined
                        taconite
                        true.
                        @CR3D what magnetic build plattform are you using that it can stand 120°C. Is it a magnetic flex plate or spring steel?
                        Custom ANET A8
                        CR3Dundefined 1 Reply Last reply Reply Quote 0
                        • A Former User?
                          A Former User
                          I think the lack of ease to modify the PanelDue interface is one of the reasons for the next generation Duet using a Raspberry Pi as well. Wide range of touch screens and simpler to adapt DWC. Not sure why OP went with Repeteir instead of DWC, maybe prior experience? Maybe he felt offering integrated slicing was a added value?
                          • oliofundefined
                            oliof
                            @bearer Repetier host has an integrated slicer? That would indeed be an up-side I would immediately understand to motivate this decision.
                            A Former User? 1 Reply Last reply Reply Quote 1
                            • A Former User?
                              A Former User @oliof
                              @oliof said in Presentation of the CR-3D C1 with Duet Electronics:
                              seems its a feature of the pro version of repetier server (never tried it, went with octoprint instead at the time)
                              https://www.repetier-server.com/version-comparison/
                              • Danalundefined
                                Danal @taconite
                                A tablet (or similar) with DWC was also suggested. Or almost anything but a USB interfaced, last millenium, legacy, hamstrung... you get the drift...
                                • CR3Dundefined
                                  CR3D @oliof
                                  Sorry Guys... I was not available for a few days!
                                  @oliof
                                  I use the raspberry pi with repetier server, because the touch and web interface is really clean and easy!
                                  It is simply very clear and now in the near future there will be a program to manage all the printers in one interface. and that makes a lot of sense in printing-farms!
                                  And it is not Repetier-Host... it is repetier-Server! But it´s quite the same, both with usb connection!
                                  -> Question: Is it possible to bring the DWC to the raspberry pi?
                                  @CaLviNx
                                  Thank you for your honest opinion! and I can understand it very well, because I often ask the same question! yes it is actually stupid if you throttled down the performance of duet! But unfortunately it really is the case that the companies prefer this surface and thus accept the performance restrictions.
                                  @bearer
                                  Yes in the next time there will be an integrated slicer from repetier!
                                  Homepage:
                                  www.cr-3d.de
                                  Facebook:
                                  Our Discord Server
                                  • CR3Dundefined
                                    CR3D @taconite
                                    @taconite
                                    Yes the build plattform can stand 120°C. There is a magnetic sheet and then a spring steel with the print surface on it... 😉
                                    Homepage:
                                    www.cr-3d.de
                                    Facebook:
                                    Our Discord Server
                                    • A Former User?
                                      A Former User @A Former User
                                      @cr3d said in Presentation of the CR-3D C1 with Duet Electronics:
                                      see https://forum.duet3d.com/topic/11540/duet-3-mainboard-6hc-initial-production-run/85
                                      (i.e. dwc is already on the pi, but 2nd gen duet support is more of a maybe. 3rd gen is ready to rumble)
