Duet 3 and jetson Nano?
@gtj0 thx for your efforts, I couldn’t have come this far without you.
@hanshogeland I updated my github repo with files that enable spi1 only. It may help.
Another thing you can try is to reduce the SPI bus speed as a test.
In config.json, change
"SpiFrequency": 1000000,
to
"SpiFrequency": 500000,
That's 500KHz instead of 1MHz.
You'll have to restart duetcontrolserver after making the change.
https://github.com/gtjoseph/jetson-nano-support/tree/l4t_32.2.1
@gtj0 hi, I have flashed with only the spi1 support and tested again with the duetcontrolserver - it gives a similar error again.
hans@hans-desktop:~$ sudo /opt/dsf/bin/DuetControlServer
Duet Control Server v1.0.3.3
Written by Christian Hammacher for Duet3D
Licensed under the terms of the GNU Public License Version 3Loading settings... Done!
Initialising object model... Done!
Connecting to RepRapFirmware... [warn] Bad header checksum (expected 0xffff, got 0x3b01)
[warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000005)
Error: Duet is not available
hans@hans-desktop:~$ ls -al /dev/spi*
crw-rw---- 1 root gpio 153, 0 sep 21 01:18 /dev/spidev0.0
crw-rw---- 1 root gpio 153, 1 sep 21 01:18 /dev/spidev0.1 -
Did you try lowering the spi frequency?
@gtj0 yes, I did that - this is the config, thx again for your help - I might have to wait until you have tested it yourself and that is fine also cause I am still building on my printer. Also I am thinking on getting a Rasberry to verify the card and cable, but I would say that should not be an issue at all.
"SpiFrequency": 500000, "SocketPath": "/var/run/duet.sock", "Backlog": 4, "BaseDirectory": "/opt/dsf/sd", "HostUpdateInterval": 4000, "MaxMessageAge": 60.0, "SpiBusID": 0, "SpiChipSelectLine": 0, "SpiTransferTimeout": 500, "MaxSpiRetries": 3, "SpiPollDelay": 25, "TransferReadyPin": 13, "MaxUpdateDelay": 250.0, "FileInfoReadLimit": 32768, "MaxLayerHeight": 0.9,
@hanshogeland I just uploaded DSF builds for 1.0.4.0. Suggest you give those a try.
I'm seeing the same checksum issues. I think I have to tweak the drive strength and the timing a bit.
Working on it! -
@gtj0 great!
I figured it out. I stupidly forgot to set the MISO pins to TRISTATE so the data was getting corrupted.
Tested and things now seem fully operational.
Grab the new u-boot and dtb files from:
https://github.com/gtjoseph/jetson-nano-support/tree/l4t_32.2.1 -
@gtj0 Success!! Thank you fior your hard work of making it work Iḿ truly grateful
Just a quick update...
There are official 64 bit builds of Duet Software Framework available from Duet3D. All you have to do is create a file named /etc/apt/sources.list.d/duet3d.list with one line in it...
deb https://pkg.duet3d.com/ stable armv7
Even though armv7 is mentioned, you'll get the arm64 packages.
Then copy the attached gpg key to /etc/apt/trusted.gpg.d/duet3d.gpg.
duet3d.gpg.txt
The.txt
suffix was added just to satisfy the forum's upload restrictions so you need to remove it.Finally, do an
apt-get update
andapt-get install duetsoftwareframework
@gtj0 said in Duet 3 and jetson Nano?:
Yes, I´ve been thinking about this for a while and just like that the update I was waiting for :)!
Followed your instructions and it worked like a charm, thank you so much. -
Those packages have been up there for a while now but both @chrishamm and I forgot to tell anyone.
I did a fresh install (both L4T & DSF) and I'm running into an issue:
Monitoring DCS shows "Kernel SPI buffer" warning & "Duet is not available"
jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer Duet Control Server v1.2.3.0 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [info] Environment initialized **[warn] Kernel SPI buffer size is smaller than RepRapFirmware buffer size (4096 configured vs 8192 required) [error] Duet is not available**
Here are my config files -
http.json:
{ "Logging": { "LogLevel": { "Default": "Information" } }, "Kestrel": { "Endpoints": { "Http": { "Url": "http://127.0.0.1" } } }, "KeepAliveInterval": 30, "ModelRetryDelay": 5000, "UseCors": true, "UseStaticFiles": true, "SocketPath": "/var/run/dsf/dcs.sock", "WebSocketBufferSize": 8192 }
config.json
"LogLevel": "info", "SocketDirectory": "/var/run/dsf", "SocketFile": "dcs.sock", "Backlog": 4, "SocketPollInterval": 2000, "BaseDirectory": "/opt/dsf/sd", "HostUpdateInterval": 4000, "ConfigUpdateInterval": 5000, "MaxMessageAge": 60.0, "SpiDevice": "/dev/spidev0.0", "SpiFrequency": 1000000, "SpiTransferTimeout": 500, "MaxSpiRetries": 3, "SpiPollDelay": 25, "GpioChipDevice": "/dev/gpiochip0", "TransferReadyPin": 13, "BufferedPrintCodes": 32, "BufferedMacroCodes": 16, "MaxBufferSpacePerChannel": 1536, "ModelUpdateInterval": 125, "MaxMachineModelLockTime": -1, "FileInfoReadLimitHeader": 12288, "FileInfoReadLimitFooter": 262144, "MaxLayerHeight": 0.9,
Additonally,
sudo systemctl status duetcontrolserver:
jpomo@jpomo-desktop:~$ sudo systemctl status duetcontrolserver ● duetcontrolserver.service - Duet Control Server Loaded: loaded (/usr/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: ena Active: active (running) since Mon 2020-01-13 13:09:55 MST; 589ms ago Main PID: 17421 (DuetControlServ) Tasks: 9 (limit: 4182) CGroup: /system.slice/duetcontrolserver.service └─17421 /opt/dsf/bin/DuetControlServer Jan 13 13:09:55 jpomo-desktop systemd[1]: Started Duet Control Server. Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Duet Control Server v1.2.3.0 Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Written by Christian Hammacher for Duet3D Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Licensed under the terms of the GNU Publi
sudo systemctl status duetwebserver:
● duetwebserver.service - Duet Web Server Loaded: loaded (/usr/lib/systemd/system/duetwebserver.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-01-13 12:52:11 MST; 18min ago Main PID: 4592 (DuetWebServer) Tasks: 19 (limit: 4182) CGroup: /system.slice/duetwebserver.service └─4592 /opt/dsf/bin/DuetWebServer Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]: at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]: at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]: at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: warn: DuetWebServer.Services.ModelObserver[0] Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: Failed to synchronize machine model Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
As far as I know, I have set the correct GPIO pin and SPI frequency.
Any advice is appreciated!
Have a look at the note in https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Enabling_SPI I haven't tested this on a Jetson Nano, though.
@jpomo10 It's an easy fix...
Create a file named /etc/modprobe.d/spidev.conf and put 1 line in it...
options spidev bufsiz=8192
Then reboot. You should be good to go after that.
Thank you for your help on this.
This fixed the buffersize problem, but still getting Duet is not available:
jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer Duet Control Server v1.2.3.0 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [info] Environment initialized [error] Duet is not available
Any other ideas of what might be causing it?
Thanks!
What's the contents of /opt/dsf/conf/config.json ?
Also start duetcontrolserver with
-l debug
My best guess is that you don't have the GPIO pin for the transfer ready line configured yet. Unfortunately this part is a bit counter-intuitive because the pin index in the gpiochip device likely varies from the sysfs index but with the right tool you can dump the indices and figure out what device/index you need to use.
{ "LogLevel": "info", "SocketDirectory": "/var/run/dsf", "SocketFile": "dcs.sock", "Backlog": 4, "SocketPollInterval": 2000, "BaseDirectory": "/opt/dsf/sd", "HostUpdateInterval": 4000, "ConfigUpdateInterval": 5000, "MaxMessageAge": 60.0, "SpiDevice": "/dev/spidev0.0", "SpiFrequency": 500000, "SpiTransferTimeout": 500, "MaxSpiRetries": 3, "SpiPollDelay": 25, "GpioChipDevice": "/dev/gpiochip0", "TransferReadyPin": 13, "BufferedPrintCodes": 32, "BufferedMacroCodes": 16, "MaxBufferSpacePerChannel": 1536, "ModelUpdateInterval": 125, "MaxMachineModelLockTime": -1, "FileInfoReadLimitHeader": 12288, "FileInfoReadLimitFooter": 262144, "MaxLayerHeight": 0.9, "LayerHeightFilters": [ { "Pattern": "layer_height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "Layer height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "layerHeight\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "layer_thickness_mm\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "layerThickness\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))", "Options": 17 } ], "FilamentFilters": [ { "Pattern": "filament used\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)mm)(\\D\u002B)?)\u002B", "Options": 17 }, { "Pattern": "filament used\\D\u002B(((?\u003Cm\u003E\\d\u002B\\.?\\d*)m([^m]|$))(\\D\u002B)?)\u002B", "Options": 17 }, { "Pattern": "material\\#\\d\u002B\\D\u002B(?\u003Cmm\u003E\\d\u002B\\.?\\d*)", "Options": 17 }, { "Pattern": "filament length\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)\\s*mm)(\\D\u002B)?)\u002B", "Options": 17 }, { "Pattern": "Filament used per extruder:\\r\\n;\\s*(?\u003Cname\u003E.\u002B)\\s\u002B=\\s*(?\u003Cmm\u003E[0-9.]\u002B)", "Options": 17 } ], "GeneratedByFilters": [ { "Pattern": "generated by\\s\u002B(.\u002B)", "Options": 17 }, { "Pattern": ";\\s*Sliced by\\s\u002B(.\u002B)", "Options": 17 }, { "Pattern": ";\\s*(KISSlicer.*)", "Options": 17 }, { "Pattern": ";\\s*Sliced at:\\s*(.\u002B)", "Options": 17 }, { "Pattern": ";\\s*Generated with\\s*(.\u002B)", "Options": 17 } ], "PrintTimeFilters": [ { "Pattern": "estimated printing time = ((?\u003Ch\u003E(\\d\u002B))h\\s*)?((?\u003Cm\u003E(\\d\u002B))m\\s*)?((?\u003Cs\u003E(\\d\u002B))s)?", "Options": 17 }, { "Pattern": ";TIME:(?\u003Cs\u003E(\\d\u002B\\.?\\d*))", "Options": 17 }, { "Pattern": "Build time: ((?\u003Ch\u003E\\d\u002B) hours\\s*)?((?\u003Cm\u003E\\d\u002B) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B) seconds))?", "Options": 17 }, { "Pattern": "Estimated Build Time:\\s\u002B((?\u003Ch\u003E(\\d\u002B\\.?\\d*)) hours\\s*)?((?\u003Cm\u003E(\\d\u002B\\.?\\d*)) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B\\.?\\d*)) seconds)?", "Options": 17 } ], "SimulatedTimeFilters": [ { "Pattern": "; Simulated print time\\D\u002B(?\u003Cs\u003E(\\d\u002B\\.?\\d*))", "Options": 17 } ] }
