    6 axis delta 3D printer
    32
    4.2k
    • fmaundefined
      fma
      The more I work on my 2 axis tilting bed mecanism, the more I'm wondering if the best choice to build a 5 axis 3D printer is not the delta kinematic...
      David, I know you are very busy, right know, but is a 6 axis delta kinematic something you could implement? I don't know how much work it represents.
      I would also like to have your opinion, guys, for the mechanic of such machine: should it be a simple up-side-down stewart platform using ball screws, like this design: https://www.youtube.com/watch?v=qGyiXFGvkqE
      Or a more conventionnal delta design, with linear towers?
      Frédéric
        The kinematics should be possible to implement. Segmentation will be required. Inverse kinematics are straightforward enough but quite complex with several trig functions involved. So definitely use a board with built-in floating point hardware - not the Maestro.
        RRF also uses the forward kinematics, which are a lot more complicated. Initially we may be able to get away without them.
        A more general issue with Stewart platforms is that it is difficult to get sufficient movement in all the required directions if you use linear actuators. The only case of using a Stewart platform in a 3D printer that I have come across used an effector suspended from cables running around drums - like a 6-axis Hangprinter.
        Edit: I forgot about this video https://www.youtube.com/watch?v=qGyiXFGvkqE#t=23.
        botundefined 1 Reply Last reply Reply Quote 0
        • fmaundefined
          fma
          Thanks for your answer.
          So it is better to build a linear delta structure with 6 towers?
          How would you put the towers? Should they all be implemented at regular space (every 60°), as well as the joints on the effector? I have the feeling that this design won't allow to rotate around the Z axis, but as we don't really need it...
          Frédéric
          • JoergS5undefined
            JoergS5
            There is a stewart based printer http://www.nugenix.co.in/stewart-force-platform with 300x300x150 mm³ print area. But precision is not very high. The solution to the limited linear motion here is using levering the motions.
            • fmaundefined
              fma
              @dc42, what about a delta with 2 moving plateforms using the same rails for the 2 sets of arms?
              The upper plateform/arms would be a classic delta, for XYZ translation, and the lower plateform/arms would be the bed, for A/B rotation (and an additional Z translation, as there is 3 dof), resulting in a 5 axis kinematic.
              Is such configuration easier to implement?
              What about build errors compensation? Is it something hard to do?
              Thanks,
              Frédéric
              tmackayundefined 1 Reply Last reply Reply Quote 0
              • botundefined
                bot @dc42
                @dc42 said in 6 axis delta 3D printer:
                [...] definitely use a board with built-in floating point hardware [...]
                Sorry to derail this thread slightly. This line caught my attention due to the fact that I recently realized that the Duet 3 has hardware floating point to double precision.
                What exactly does this mean? 😊
                I get what floating point is. I get what double floats are. I get the implications of a dedicated hardware component handling these.
                But is this automatic? Does the hardware floating point capability of one Duet board vs another automatically improve performance of dealing with floats? Or, does this functionality need to be manually addressed in the RRF code?
                Does the Duet 3 perform better when calculating double precisions floats vs the Duet 2? Does the Duet 2 Maestro suffer performance loss in comparison, when dealing with floating point math? (When using RRF as-is.)
                *not actually a robot
                  dc42 administrators @bot
                  @bot said in 6 axis delta 3D printer:
                  It's automatic, after setting up the compiler settings and startup code to use the built-in floating point hardware (which we do).
                  Yes, however RRF for Duet 2 hardly ever uses double precision floats, because single precision is sufficient.
                  Yes. So the Maestro is less suitable for controlling SCARA and Polar printers in particular.
                  botundefined 1 Reply Last reply Reply Quote 1
                  • botundefined
                    bot @dc42
                    Thank you very much. I'm diving into learning about embedded C programming right now, with no disillusions that I will be making any viable contributions, but just to understand better how things work. Your answer helps a lot!
                    • fmaundefined
                      fma
                      As I'm more and more interested by 5 axis 3D printing, I finally decided to build a 6 axis delta 3D printer. Here is my first draft:
                      I don't want to spend too much money, but I the same time want to build something decent. So, I think to use cheap linear rails, but use 2 of them to minimize backlash. In this design, the rails are on the same plane, but another solution is to place them at 90° on the profile (this will require 1 profile by axis, which is maybe a better ide for rigidity).
                      I initially though to use ball screws, but these things are not cheap, and bulky, so I will use belts at first.
                      The printer will be enclosed to be use as a heated chamber (which will also increase rigidity), and I want to use a direct drive extruder, so I need a good rigidity for the arms and the effector. I don't plan to print fast, but I want a good quality.
                      I have a few questions:
                      • what distance should I use between arms? The higher the better?
                      • what relative length between arms and columns distance should I use? Is it good to have long arms, which remains more vertical, or shorter ones, which go from vertical to nearly horizontal?
                      • do you know ball joints with large usable angle? Or should I use another design?
                      Any advice for this project is welcome. I already read the wiki about 6 axis delta calibration, which gives several advices about important dimensions which can't be fixed by auto calibration.
                      Thanks.
                      PS: I know that there are no 5 axis slicer yet, but I myself wrote some code to print portions of sphere. And by cloning axis, this printer can run as a normal 3 axis delta without any code modifications.
                      Frédéric
                      dc42undefined tklnundefined 2 Replies Last reply Reply Quote 0
                        dc42 administrators @fma
                        @fma said in 6 axis delta 3D printer:
                        I have had a good experience with the Robotdigg linear rails on my delta, so I would go for a single rail instead of two.
                        Yes.
                        The rule of thumb is that the arms should always make an angle of 20deg or more to the horizontal. This typically makes them about 60deg to the horizontal when the effector is centred.
                        Having used two types of ball joint and been unhappy with them, I recommend the magnetic joints by Haydn Huntley.
                        • RRF does not include kinematics for a 6-axis delta. They would need to be added.
                        • To make use of the additional degrees of freedom of a 6-axis delta, you would need a special slicer.
                        fmaundefined 1 Reply Last reply Reply Quote 0
                        • fmaundefined
                          fma @dc42
                          Which ones do you recommend? They have several references, and not much informations about relative quality...
                          Ok.
                          Do you think they are strong enough to hold an extruder, like Hemera?
                          I hoped you could help me on that part 😉 Earlier in this thread, you mentionned the fact that forward kinematic is not mandatory...
                          Yep, as said, I will first use my own Python code to print portions of sphere (I already made some tests, but without head tilting).
                          Thanks!
                          Frédéric
                            I used the 440C ones.
                            Perhaps not; but I wouldn't consider the Hemera suitable for direct mounting on the effector because it is so heavy.
                            • wescundefined
                              wesc
                              I'm using a hemera on my d300 (with linear rails). it works fine and gets great prints.
                              https://www.thingiverse.com/thing:4027625
                              I'm using tricklaser arms which don't pop off like magball arms do. I'd be very hesitant to use magballs and a direct drive extruder.
                              CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
                              • Haydnundefined
                                Haydn
                                I'm working on designing an effector using a Titan Aero or Hemera with MagBalls. The six MagBalls each have 1.5kg of attraction, so with six of them there should be more than 9kg.
                                The trick is to have the extruder motor/body above the effector, and the nozzle stick down through it. This way if the nozzle bumps into something, it will have less leverage to knock the effector free. Minimize the vertical distance between the plane of the MagBalls and the tip of the nozzle.
                                Ultibots used to have an effector with the extruder hanging below it, and the hotend below that. It had problems because the nozzle was a long distance below the MagBalls.
                                • Haydnundefined
                                  Haydn
                                  One relatively simple algorithm for slicing with a printer using a Stewart platform would be to use a "normal" slicer for everything, except to post-process the output. The algorithm would alter the slicing for the outside layers of the object. If the Stewart platform could tilt the effector by X degrees, then the algorithm would look for places where the outside layer was tilted by less than X degrees, and print that tilted, with the nozzle perpendicular to the surface at that location, thus helping minimize ridged/stepped layers.
                                  • Haydnundefined
                                    Haydn
                                    A possible design for using direct belt-driven carriages for a Stewart platform would be to rotate the 20x40mm vertical extrusions by 90 degrees. Then for each tower, place one motor at the top and the other at the bottom. Place both limit switches at the top. One motor would be on one side, and could drive a carriage using three wheels, which would be carefully designed not to interfere with the other mirror image carriage on the other side of the vertical extrusion. If 20x40mm vertical extrusions make the spacing too tight, then you could use 40x80mm C-Beam extrusions from OpenBeams.
                                    Simple, inexpensive, and quiet.
                                    • fmaundefined
                                      fma
                                      Thanks for all these ideas, Haydn!
                                      About the extruder, I'm already using a custom one, build around a Nema14 scavenged from a geared motor: the output gear perfectly match a BMG gear (clone), giving a 5:1 ratio. And I'm using a FNU as hot-end, which has a long tube, so it is very easy to have the extruder above the effector (I did not plan to do otherwise).
                                      One big issue, though, is the extreme positions of the arms when tilting the effector, bumping in the motor... I think a solution would be to switch to a geared DC motor, as Stratasys use on there printers...
                                      Frédéric
                                      • fmaundefined
                                        fma @fma
                                        Another crazy solution would be to use a very short Bowden extruder, with the motor mounted on another effector, driven by 3 additionnal motors.
                                        The Delta version of @deckingman monstruosity 😉
                                        Frédéric
                                        deckingmanundefined Nxt-1undefined 2 Replies Last reply Reply Quote 0
                                        • deckingmanundefined
                                          deckingman @fma
                                          Let me see you come up with a better way of feeding a 6 input mixing hot end with 6 extruders using 150mm Bowden tubes and which can print at up to 300mm/sec. Then you'll have the right to call my design a monstrosity.
                                          • Nxt-1undefined
                                            Nxt-1 @fma
                                            I have actually been thinking about doing this for over a year, but I am not willing to upgrade electronics and there are not enough drives on a regular Duet 2 for this crazyness. Also, to give as much clearance as possible between the two sets of arms, I would rotate the 2nd delta setup so the towers sit directly between the 1st setup. This would mean though that you can't really remove large prints from the bed as one of the towers would always block it.
                                            Alternatively, a delta with a ball jointed 4th axis like I have been doing for a while, might be good enough. I am nearing the end of designing something very similar but with two 4th axis rails, joining at (x0, y0) for extra rigidity.
                                            Duet3D and delta printer enthousiast. Buildlog
                                            Looking for Duet3D configuration support, check out Nxt-3D
