3D GCode Viewer integrated with DWC
@chrishamm OK, will try. Thanks.
After deleting /opt/dsf/conf/config.json it works
Thanks!
This post is deleted! -
@sindarius said in 3D GCode Viewer integrated with DWC:
I’ll need to look i believe the code currently uses the machine position and not the tool position which could be the issue.
@sindarius Did you have a chance to look into this?
I was working on someone else's E3D tool-changer today and experienced the same thing, so I wanted to check in.
DWC & Firmware Version: 3.3
