    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    30.5k
    • MJLewundefined
      MJLew
      Is there a requirement for code headers? I have hand-written gcode files that print but do appear entirely empty in the viewer.
      Sindariusundefined 1 Reply Last reply Reply Quote 0
      • Sindariusundefined
        Sindarius @MJLew
        @MJLew if you want to send it to me I can take a look. I can assure you no headers are necessary. The viewer throws away every line that starts with ;
        MJLewundefined 1 Reply Last reply Reply Quote 0
        • MJLewundefined
          MJLew @Sindarius
          @Sindarius Thanks very much. The attached is a simple cylinder.cylinder 6c.gcode
            Sindarius @MJLew
            @MJLew
            Thank you for sharing the file
            So the problem is your file is using Carriage Return \r on the file and the viewer looks for Line Feed \n to break the lines apart so it is reading the whole file as a single line. What text editor did you use I usually see \r\n or \n it's the first time I've ever noticed just \r
            Once I changed that it worked but it looks like it's not appreciating somthing in the G3 in the rendering. I will have to look into that, my guess is something is wrong with the R calculation.
            I found the issue in the arc code that the renderer uses. Fix should be in for 3.3
            • MJLewundefined
              MJLew @Sindarius
              @Sindarius Thank you Sindarius. The file was made by code I wrote in LiveCode, and, yes, the lines are separated by returns. I can probably use any line delimiter I like, but returns are normal for Mac, I think.
              I look forward to using the fixed viewer, as I am doing a lot of trial and error printing with my custom gcode using G2 and G3 because Simplfy3D won't display it.
              • MJLewundefined
                MJLew @MJLew
                @MJLew Oh, and I should add that the return-delimited file runs with Duet and Smoothieboard, so maybe the viewer should allow return-delimited files too. 🙂
                  Sindarius @MJLew
                  @MJLew I'll take it into consideration. In the meantime I have a temporary solution that may at least get you testing in the near term. I have been working on a voxel version of the visualizer for fun and I already applied the same fixes that will be in 3.3. If you can tolerate some little squares in your testing you can give this a go.
                  https://sindarius.github.io/
                  • MJLewundefined
                    MJLew @Sindarius
                    @Sindarius Works fine for gcode from S3D, but not my return-delimited files come up blank. (The Minecraft style is really cool!)
                      Sindarius @MJLew
                      @MJLew It's going to be the same deal. It is using the same processing so it's not going to accept carriage return.
                      • MartinNYHCundefined
                        MartinNYHC
                        Can Ideamaker label objects? Cannot find something in the settings menu and GcodeViewer doesn't show object labels.
                          dc42 administrators @MartinNYHC
                          @martinnyhc said in 3D GCode Viewer integrated with DWC:
                          Yes, it labels objects, and RRF 3.3RC2 recognises those labels.
                          MartinNYHCundefined 1 Reply Last reply Reply Quote 0
                            MartinNYHC @dc42
                            @dc42 said in 3D GCode Viewer integrated with DWC:
                            Need to double check that. Had a print today where I would like to cancel an object and it was not possible (which means the option "show object labels" was grayed out).
                            • T3P3Tonyundefined
                              T3P3Tony administrators @MartinNYHC
                              @martinnyhc just had a quick check in the latest idea maker. the output I got is labelled as follows:
                              ;PRINTING: test0.stl
                              ;PRINTING_ID: 1
                              ;PRINTING: test2.stl
                              ;PRINTING_ID: 0
                              ;PRINTING: test1.stl
                              ;PRINTING_ID: 2
                              so it is labelling the objects
                              www.duet3d.com
                              • HebigTundefined
                                HebigT
                                What might cause the cursor to be offset from the rendered preview?
                                I'm using a Toolchanger, so each of the tools have offsets with respect to the Z-probe. Perhaps the offset is not being referenced?
                                  Sindarius @HebigT
                                  I’ll need to look i believe the code currently uses the machine position and not the tool position which could be the issue.
                                  HebigTundefined 2 Replies Last reply Reply Quote 0
                                    MartinNYHC @T3P3Tony
                                    @t3p3tony said in 3D GCode Viewer integrated with DWC:
                                    ;PRINTING
                                    G1 F3600 X138.747 Y111.877 E0.7349
                                    ;PRINTING: 3mm_hinge_a_with_logo_x2(1).stl
                                    ;PRINTING_ID: 1
                                    G1 F1500 E-2.0000
                                    but "show object selection" is disabled:
                                    I'm using Ideamaker 4.1.1.5050 and RRF 3.3-RC2.
                                    • chrishammundefined
                                      chrishamm administrators @MartinNYHC
                                      @martinnyhc If you are using RRF 3.3-RC2 in SBC mode, please try to delete /opt/dsf/conf/config.json once and restart the Pi. I forgot to update the default DCS config in RC2 which contains a change for object detection for IdeaMaker. By deleting that file DCS will use the new defaults automatically.
                                      Duet software engineer
                                      MartinNYHCundefined 2 Replies Last reply Reply Quote 0
                                        MartinNYHC @chrishamm
                                        This post is deleted!
                                          @chrishamm said in 3D GCode Viewer integrated with DWC:
                                          Still not working.
                                            @martinnyhc AFAIR parts of the second object have to be printed before the object selection starts working. If it still doesn't work, make sure you are on DSF 3.3-RC2 and that "PRINTING" is part of the FirmwareComments field in /opt/dsf/conf/config.json. That file should have been regenerated after the reboot.
