    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    30.5k
    • Exerqtorundefined
      Exerqtor @Sindarius
      @Sindarius said in 3D GCode Viewer integrated with DWC:
      @Exerqtor I'd have to play with it because the hit testing may ignore the transparent area and honestly I tend to think people wouldn't leave it on after cancelling objects because it is so easy to misclick and potentially cancel something you didn't mean to (even with the dialog).
      Yeah that's a valid point πŸ˜…
      Sindariusundefined 1 Reply Last reply Reply Quote 0
      • Sindariusundefined
        Sindarius @Exerqtor
        @Exerqtor I do like the solid edges idea tho so I’ll probably do that
          Sindarius
          Starting to put some work into CNC gcode files.
          Tried my solid rendering to see how a 3d carve would look.
          Edit : A couple extra pics
            Sindarius
            Just pushed out a new release with support for G2/G3.
            https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.11.0
            • bastienundefined
              bastien
              sorry for my stupid question, how install your viewer, besose i send your dwc in my duet and a not viewer menu
                jay_s_uk
                @Sindarius
                You may want to edit your first post and remove the link the original DWC builds, replacing it with a link to the new github repo releases page
                  Sindarius @jay_s_uk
                  @jay_s_uk that’s probably a good idea since that dates to Sept 2019 😱
                  Edit : Updated. It may be time time to start a new thread...
                    Sindarius @bastien
                    @bastien which version of dwc are you running?? The latest version of my viewer is now a plugin that runs on dwc 3.2-beta 4.
                    • bastienundefined
                      bastien
                      i just install 3.2, i viewer in sub menu in files but no in main menu
                      bastienundefined 1 Reply Last reply Reply Quote 0
                      • bastienundefined
                        bastien @bastien
                        @bastien said in 3D GCode Viewer integrated with DWC:
                        it's ok, i re install plug in and start in new plug in menu 😊 😊
                        • DIY-O-Sphereundefined
                          DIY-O-Sphere
                          @Sindarius
                          Are there known issues with the latest version on a maestro?
                          Cant't get it working anymore. (RRF 3.2_b4 +0.11.1)
                          The previous versions of fw and plugin worked. (guess RRF 3.2_b2 +0.6.5)
                          (UTC+1)
                            Sindarius @DIY-O-Sphere
                            @DIY-O-Sphere I pulled down and installed the 3.2-beta4 that is on GitHub, I normally run my own build, and was able to install my plugin without any problems. Make sure you are pulling the latest version of my plugin from the github releases page https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases. I don't believe the firmware version itself should have any play since the plugin is a javascript solution that runs in DWC itself.
                            Just double check the following to make sure you are on the latest
                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                              DIY-O-Sphere @Sindarius
                              @Sindarius
                              After de-energising and powering up everything is working now....
                              A simple sw-reset after the update was not enough.....
                              (UTC+1)
                              • PCRundefined
                                PCR
                                @Sindarius
                                File processed with arcwelder
                                01_SP2_Unterschale_DQ2_PET_0.3mm_1h39m.gcode.txt
                                • PCRundefined
                                  PCR
                                    Sindarius @PCR
                                    @PCR I’ll take a look at the file. Those are some impressive arcs πŸ˜„
                                    • PCRundefined
                                      PCR
                                      no rush πŸ˜‰ was more like a little note
                                        Sindarius @PCR
                                        @PCR This probably looks better.
                                          Sindarius
                                          G3 fix is in RC2
                                          https://github.com/Duet3D/DuetWebControl/releases/tag/3.2.0-rc2
                                          • A Former User?
                                            A Former User @Sindarius
                                            @Sindarius
                                            A small thing that I catched:
                                            On all 3-d-software I am aware of, if a cartesian-csys-system is used -> x-y-z are coloured in r-g-b,
                                            e.g. "sol...orks" here:
                                            e.g. "rh...-3d":
                                            e.g. "sim....y-3D":
                                            e.g. or the height-map within "DWC":
                                            but here it is r-b-g:
                                            Before I forget: Thanks for you cool work!
                                            πŸ˜‰
                                            Sindariusundefined 1 Reply Last reply Reply Quote 1
