    Independent Z with Independent Sensors U steps/mm wrong
    740
    • LeonMFundefined
      LeonMF
      A whole bunch of months ago, I retrofitted my Promega to have dual Z lead screws with independent sensors for homing. Then I had so many issues with the Maestro board skipping steps, the extruder system behaving badly, and a work trip that kept me busy for several months.
      I'm back to it now, I've redesigned the X carriage, swapped in a Duet WiFi that I had lying around while waiting for the Duet 3 and I've got everything pretty much back to working but the Z homing is behaving weird.
      I set the U axis at the same steps/mm as Z but in the commented out line the U axis gets 837.20steps/mm and E0 gets 420. When use the second option where I try to set U to 400 after the fact, I get U and E as 420.
      [0_1567892760893_MonkeyMega-Config-2019-09-07.zip](Uploading 100%)
      I'm on firmware 2.03 and, at this point, I'm at a complete loss as to what to do. I can try putting some overrides in the homez file but I'd rather find out if I'm doing something wrong first!
      Current: Railcore II ZLT w/Duet 3 and Hemera hot end.
      Retired: Robo3D R1,BI V2.5 Delta updated to BerryBot magnets, bespoke carriages and Duet Ethernet, M3D Promega;
      LeonMFundefined 1 Reply Last reply Reply Quote 0
      • LeonMFundefined
        LeonMF @LeonMF
        Here is a dropbox link to my config:
        https://www.dropbox.com/s/a6954n6rumxr327/MonkeyMega-Config-2019-09-07.zip?dl=0
          I think you may need to define U in your M584 command? And I'm not sure but I think it should be P4 instead of P3.
          I don't personally use multiple independent motors for Z, so I could be wrong.
          I'm sure you've seen this, but maybe a good idea to go over it once more and try to follow the examples.
          https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          LeonMFundefined 1 Reply Last reply Reply Quote 1
          • fcwiltundefined
            fcwilt
            That article that Phaedrux referenced makes no mention of creating other axes.
            So I think there may be something amiss in your configuration.
              Just to make it clearer what is happening when homing Z
              ; homez.g
              ; called to home the Z axis
              ; ============= PRE-HOMING =====================
              ; Ignore Machine boundaries
              M564 H0 S0
              ; Turn off bed leveling during homing
              G29 S2 ; Does the same as M561!
              G29 S2 ; Do it twice because once just isn't enough
              ; Switch to Origin Tool
              T0
              ; Relative positioning
              G91
              ; Provide Z height clearance
              G1 Z10 F250 S1
              ; =========== Reconfigure axes =========
              M584 Z2 U4 P4 ; Split Z into 2 (Z+U)
              ; =========== set U axis current ======
              ;M906 U1200 I60; Set motor currents (mA) and idle current percentage
              ; ============ HOME Z ==============
              ; Rapid Z+U until limit switch triggers
              G0 Z450 U450 F1500 S1
              ; Back off to release limit switch
              G1 Z-5 U-5 F120 S2
              ; Slow advance to trigger limit switch
              G0 Z20 U20 F120 S1
              ;Offset U before merge to level platform - again
              ;Offset not needed due to tuned sensor flags.
              ;G1 U-0.5 F1000
              ;Merge U and Z again
              M584 Z2:4 P3
              ;Move back again 5mm in -z direction
              G1 Z-5 F1500 S2
              ;Set actual z-height (might be able to do this in config as part of default height.
              G92 Z322.3 U322.3
              ; ============ Post-Homing ==============
              ; Revert to absolute coordinates
              G90
              ; Re-enable mesh leveling
              G29 S1
              ; Stop movement across limits, enable boundaries, homing requirement
              M564 H1 S1
                The ProMega config setup is a little unorthodox in my opinion. There have been a few other threads trying to sort through it in the recent past.
                Have you seen this? https://promega.printm3d.com/documentation/software-firmware/adjust-homing-macros
                  Check that in config.g you have a M584 command that creates the U axis and also redefines the E drivers, earlier than your M350 and M906 commands. I'm using a smartphone so it's not easy for me to look at the config.g that you uploaded.
                    I think the problem is that the u axis isn't created until the homing files as it's missing from the m584 in the config.g
                      dc42 administrators @Phaedrux
                      @phaedrux said in Independent Z with Independent Sensors U steps/mm wrong:
                      In that case the U motor will still be set up as an extruder, and the microstepping and motor current will be set as for the extruder. So if E microstepping is different from Z microstepping, that would explain the symptom
                      • LeonMFundefined
                        LeonMF @Phaedrux
                        Yes, that's what I based my config on!
                        • LeonMFundefined
                          LeonMF @dc42
                          @dc42 @Phaedrux OK, I can certainly modify my config to create the U axis and then combine them. The posted wiki page doesn't say to do that so I missed the obvious!
                          • LeonMFundefined
                            LeonMF @Phaedrux
                            @phaedrux There's no reason to treat this like a Promega. I've gutted it, changed the Z drive system to dual lead screws, the rails, the carriage, the board, the bed...
                            • LeonMFundefined
                              LeonMF
                              Defining U in config.g before then combining worked for me. Thanks for the help!
                              fcwiltundefined 1 Reply Last reply Reply Quote 1
                              • fcwiltundefined
                                fcwilt @LeonMF
                                @leonmf said in Independent Z with Independent Sensors U steps/mm wrong:
                                What is the reason for end stop switches on both z axes?
                                  Phaedrux Moderator @fcwilt
                                  @fcwilt I believe it's used as an X axis leveling mechanism.
