    Building a DIY public domain low cost stepper motor analyzer
    51
    3.9k
    • JoergS5undefined
      JoergS5 @zapta
      @zapta your project is very interesting. Can you tell me please whether you were able to analyse currents with microstepping and to which detail?
      Thank you for pointing me to the ACS70331. I have a couple of ACS712, but they are much too slow.
      I would like to analyze the correlation between step commands to the TMC, the created currents from TCM to stepper and the resulting movement of the stepper.
      zaptaundefined 1 Reply Last reply Reply Quote 0
      • zaptaundefined
        zapta @JoergS5
        Hi @JoergS5, think it shouldn't be too difficult to decode x16 microsteping. When going through a full step, the current in the two coils behave like the graph below. X16 can be achieved by breaking the cycle to x4, x2 and x2:
        x4 - detection of a quadrant (90deg) is already already done and needed to determine the direction.
        X2 - each quadrant can be divided int two (45deg each) by comparing the absolute value of the two channels.
        X2 - each sub quadrant can be divided by 2 using the ratio of the high coil current to the low coil current.
        I think this is straight forward and doable, given the two currents, and can also be come manually using the two current readings.
        BTW, I send the new PCB layout to manufacturing. Should arrive in a few weeks. It's a small 40x50mm board.
        All the source files are on github and should work though I plan to do some cleanup.
        https://github.com/zapta/misc/tree/master/stepper_analyzer
        Schema is in the link below. As you can see there is no much there:
        https://github.com/zapta/misc/blob/master/stepper_analyzer/kicad/main/stepper_analyzer.pdf
        JoergS5undefined fcwiltundefined 2 Replies Last reply Reply Quote 1
        • JoergS5undefined
          JoergS5 @zapta
          @zapta Thanks for your information and the source location. Lucky me I bought a Nextion 3.5 last year, because I liked the idea that the display offers GUI logic, so I can start with your source.
          It will take some time until I can start with the project, but I can keep you informed what I develop.
          • fcwiltundefined
            fcwilt @zapta
            @zapta said in Building a DIY public domain low cost stepper motor analyzer:
            I don't see how to download all of the files related to this project.
            Does each file have to be downloaded separately?
            • A Former User?
              A Former User @fcwilt
              @fcwilt easy way is to clone or download the whole https://github.com/zapta/misc repository.
              Alternatively you can turn to google to try and download just a sub directory from github
              • fcwiltundefined
                fcwilt @A Former User
                @bearer said in Building a DIY public domain low cost stepper motor analyzer:
                Well that is certainly not the way I thought it would be done but if it works...
                Thanks.
                A Former User? 1 Reply Last reply Reply Quote 1
                • A Former User?
                  @fcwilt said in Building a DIY public domain low cost stepper motor analyzer:
                  if it works...
                  it does. but packing several projects into a single repo doesn't lend itself well to sharing or collaboration - but it is easy for a single user.
                  anyways https://stackoverflow.com/questions/7106012/download-a-single-folder-or-directory-from-a-github-repo and other search results does provide options but to me its always seemed like more hassle than just getting the whole thing and discarding what I don't need/want.
                  zaptaundefined 1 Reply Last reply Reply Quote 2
                  • zaptaundefined
                    zapta @A Former User
                    Sorry about that. This is my catch all 'misc' repository. I plan to clean up the stepper analyzer in the next week or two so will also move to an independent repository.
                    Meanwhile, if you encounter any problem, let me know here. I will monitor this thread more closely.
                    Flushing the firmware has two parts, flashing the Nextion 3.5" using a micro SD card or the nextion designer with a serial port, and flashing the Teensy 4 which I currently do with the Arduino IDE (need to install the Teensy 4 extensions) but am looking for a simpler way (any suggestions?)
                    • A Former User?
                      A Former User @zapta
                      platformio? (for the teensy at least)
                      • zaptaundefined
                        I copied the stepper analyzer files to a dedicated repository https://github.com/zapta/stepper_analyzer (will delete files from the old repository later).
                        It also includes a release directory with binaries for the teensy and the nextion 3.5". The teensy firmware can be flashed with a teensy loader (https://www.pjrc.com/teensy/loader.html) and the nextion using its sd card.
                        It's still rough and I plan to clean it up in the next week or two. Please let me know how it works for you.
                        • A Former User?
                          A Former User
                          Thats awesome, its on my list to try and build one! Thanks for putting this out there man!
                          • zaptaundefined
                            The new PCBs arrive and I like how small and simple they are:
                            I also added a retraction analysis screen. It is cumulative such that retract 10 steps extruder 3 steps, retract 5 steps will show retraction of 12 steps.
                            The graph moves in real time so the camera didn't capture it well. The little noise at the bottom of the graph are tiny retractions due to pressure advance (0.08).
                            I plan to commit the changes to github later today.
                            • fcwiltundefined
                              fcwilt
                              Have you considered building a small batch of complete units and selling them to us poor souls who would love to get our hands on one?
                              zaptaundefined 1 Reply Last reply Reply Quote 1
                              • A Former User?
                                A Former User
                                I'd could be down for crowd sourcing myself one if such a thing were to be a thing.
                                • zaptaundefined
                                  zapta @fcwilt
                                  @fcwilt, I would love to do that because I think the makers' 3D printer market needs a tool like this but I can't do it myself. My hope is that someone can pick it up and provide to the community, this exact design or a lower cost version of it (with a stand alone MCU and a dumb LCD). The license is very liberal, non need to attribute, no need to share code changes, commercial OK, etc.
                                  I just created a documentation page in github. It explains the various functions, how to flash the firmware and a BOM.
                                  arhiundefined 1 Reply Last reply Reply Quote 1
                                  • A Former User?
                                    A Former User
                                    I'd be happy to build and test (some) additional boards when I make mine, but despite the BOM being about $50-60 (10 seconds guesstimate) statistically it'd be close to double that after shipping, taxes and fees + another $7 to ship it out again. There is no real need for me to source the teensy and screen which brings the rest down to $10-20 (before shipping, taxes and fees). So my location is probably a bit cost prohibitive even when not making a profit.
                                    @zapta is the SD card required for the nextion to run, or just the programming? I'm still waiting for that aliexpress order ... 176 days is the 2020 shipping highscore:/
                                    fcwiltundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      @bearer
                                      If you've got a PayPal account I'd buy a unit from you.
                                      A Former User? zaptaundefined 3 Replies Last reply Reply Quote 0
                                      • A Former User?
                                        @fcwilt i do. i've posted an informal doodle https://doodle.com/poll/hhw2iyirf8fctmn4 where interest could be gauged, but admittedly very skeptical as global shipping is very unreliable these days.
                                        • arhiundefined
                                          arhi @zapta
                                          @zapta wanna pick your brain a bit .. why did you go with analog output current sensing and not with one with integrated ADC with spi output? Something like LMP92064 for e.g. comes to mind?
                                          I am now deciding between LMP92064 and ACS70331 + AD7705 and it looks like ACS70331 + AD7705 will go in final product 'cause I need the resolution but since you are using the ADC on the teensy I guess LMP92064 would be easier solution ?! Or you went by the price (LMP92064 is ~3x more expensive locally, I guess it's same everywhere)
                                          • zaptaundefined
                                            Just for programming and should be removed for the Nextion to function. I just updated the documentation to clarify it.
