    Creatr Leapfrog – Converted to DuetWifi
    My Duet controlled machine
    1.3k
    • gianakopundefined
      gianakop
      Hi All,
      I‘m Nikos from Greece and in this thread, I’ll try to convert an old Creatr Leapfrog 3d Printer to a super printing machine using DUET electronics.
      This printer was the very first Creatr model, with a single extruder and an Arduino Controller Board Ramp connected with 4 external Microstep Driver CW230 motor drivers.
      I want to keep only the chassis (with very little changes), the motors, and the power supply, and I’ll change all the cables, the electronics parts, and the extruder. (Some of the old electronics are burned and the printer was out of functions for many years)
      This will be a long time project because I don’t have all the necessary parts that I need.
      Any suggestion and advice is welcome. The board I’m going to use is the Duet 2 Wifi in conjunction wit a PanelDue v2 with a 7" screen
      Here is the situation of the printer now:
      The existing electronic part is also a mess:
      Please Keep tunned to see the progress of this project and help in order to create a guide for all the other people like me that have an old Creatr Leapfrog
      https://www.youtube.com/user/NGYT40
      gianakopundefined 1 Reply Last reply Reply Quote 0
      • gianakopundefined
        gianakop @gianakop
        @gianakop
        Let’s see what kind of electronics I have to deal with DUET Wi-Fi board....
        The motors:
        The printer has 5 stepper motors:
        X-axis: (1pcs) Smart Automation PN.SM42HT47-1684A
        Y-axis 😞 2pcs) Smart Automation PN.SM42HT47-1684A
        E-extruder: (1pcs) Smart Automation PN.SM42HT47-1684A
        All these 4 motors are the same: SM42HT47-1684 nema 17 bipolar stepping motor 1.68A 4 leads 5kg.cm holding torque)
        And here is the motor and the datasheet:
        The Z-axis motor, is a much bigger stepper motor:
        Z-axis: (1pcs) Smart Automation PN.SM57T56-2804A-6mm
        I haven’t the datasheet for that motor, but I think that is very similar to this motor :
        According to the DUET guideline for the motorsI think that I can drive the X, Y and E motors directly with DUET Wi-fi board, but I’m not sure for the Z-motor.
        The options that I have to drive the motors are:
        1. Drive them directly from the Duet wifi board (I’m not sure if I can do that with the Z-motor because it seems that it has 2.8 A current)
        2. Use the Duet Expansion Breakout Board (I don’t know where to find it)
        3. Use the Stepper Motor Driver TB6600 (cheap from e-bay)
        4. Or keep the old external drivers (Microstep Driver CW230)
          I would appreciate any suggestion …..
        T3P3Tonyundefined vangc21undefined 2 Replies Last reply Reply Quote 0
        • T3P3Tonyundefined
          T3P3Tony administrators @gianakop
          @gianakop said in Creatr Leapfrog – Converted to DuetWifi:
          its normally recommended to drive motors at about 80% of their rated current (at rated current they can have 80C temperature rise depending on the motor!)
          So if the motor is rated to 2.8A then you can use a Duet 2 set to 2.2A
          www.duet3d.com
          • gianakopundefined
            gianakop
            Some other parts of the printer that I’m going to keep before the restoration are:
            1. The powersuply, that is a : S-400-24 24V POWER SUPLY
            2. The bed that is the : Heated Print Bed (Leapfrog HS) ( thermo glass bed with dimensions 34.6cm X 45cm and powered with 24V
            3. The Z-probe : A JIMOU sensor 10-30V DC 150 mA https://bit.ly/32yzCS8
            Last but not least I have to mention that Creatr is a Cartesian 3D printer in which the print bed moves only in the Z-axis using one stepper motor, X-axis and Y-axis are moving independently . X-axis uses one stepper motor and Y-axis uses two stepper motors. The extrusion system is direct with extruder and extrusion motor moving together.
            • gianakopundefined
              gianakop @T3P3Tony
              @T3P3Tony said in Creatr Leapfrog – Converted to DuetWifi:
              Thank you @T3P3Tony , That 2.2A setup will be for all the motors? or I can make it only for the Z-motor and for the other X, Y i can use a different curent setup?
              Red Sand Robotundefined 2 Replies Last reply Reply Quote 0
              • Red Sand Robotundefined
                Red Sand Robot @gianakop
                You can individually set the motor current for each driver that a motor is connected to (e.g. your Z-axis stepper would be 2.2A while your X stepper and two Y axis steppers would be some other value).
                almost an engineer
                  @gianakop
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
                  The gcode command you would use in your config.g file would be M906 for setting the motor currents.
                  almost an engineer
                  • vangc21undefined
                    vangc21 @gianakop
                    @gianakop Just wanted to thank you for your contribution! My leapfrog nema 17 motors were missing the model number stickers so I was never able to look up the specs. I'm tearing down my unreliable Creatr and will be using it's parts to upgrade my incoming TronXY x5sa Pro that will arrive in a couple days.
                    Anyways, I registered just to add to your info what I've found about the nema 23 motor.
                    http://www.multiprojekt.ro/produse/motoare-pas-cu-pas/motoare-pas-cu-pas-stepper
                    So my guess would be
                    SM = stepper motor
                    57 = width of motor
                    T = most likely "Torque"
                    56 = length of motor
                    280 = 2.8 a
                    4 = 4 wires
                    A = 1.8 pitch single axis
                    You can also refer to this pdf for future motor references.
                    http://www.multiprojekt.pl/ftp/silniki_krokowe/
                    • gianakopundefined
                      gianakop @Red Sand Robot
                      @Red-Sand-Robot said in Creatr Leapfrog – Converted to DuetWifi:
                      This is Amazing! I think that the Duet board will change completely my old Creatr!
                      • gianakopundefined
                        gianakop @vangc21
                        @vangc21 said in Creatr Leapfrog – Converted to DuetWifi:
                        SM = stepper motor
                        57 = width of motor
                        280 = 2.8 a
                        4 = 4 wires
                        Thank you so much for your reply and for your help!!!
                        However, your decision to use the old Creatr only for spare parts in order to upgrade your TronXY x5sa Pro, makes me feel that I'm trying something that is not worth at all. Anyway I also have and another 3d Printer the Ender 3 Pro and in case that Creatr's upgrade fails I'll upgrade my Ender 3 according this tutorial "Ender 3 Pro and Duet Maestro Guide "
                        vangc21undefined 1 Reply Last reply Reply Quote 1
                        • vangc21undefined
                          vangc21 @gianakop
                          @gianakop It depends on what other printers you have on hand. In my case, I bought the creatr for $150 off someone on Craigslist. I tried to get it to a good working state but was never able to get decent prints off it. So, I parted it for parts to upgrade my Tronxy X5sa Pro.
                          The glass plate worked perfectly for the x5sa pro. I'll probably use the 40x40 aluminum extrusion to strengthen the frame of the x5sa. First, I have to measure and cut it to fit the x5sa.
                          • Perttiundefined
                            Pertti
                            Hi gianakop ,
                            we share the same problem.
                            I received my Leapfrog from my employer who was more than happy when somebody carried it out of the office.
                            I had problems with y stepper noise, but now all steppers are quiet, thanks to advise from this forum.
                            I also improved the filament cooling by aluminum fairings. I changed the z probe to ordinary microswitch because of my limited skills in electronics. Maybe You have tried the original one?
                            Now I´m working with the second extruder and dual extruding and thermistors.
                            Pertti
                            “A winner is just a loser who tried one more time.”
                            George M. Moore, Jr.
