    Hello, am new here but not a newbie as such.
    8.8k
      @FuseDeep said in Hello, am new here but not a newbie as such.:
      The adhoc macro I created, will that run automatically? Or do I need to put it somewhere special?
      It won't run automatically. The documentation for M589 states that it will not run from config.g. So we must call it separately.
      The macro you created will live in the macros folder.
      To call the macro, you use M98. https://duet3d.dozuki.com/Wiki/Gcode#Section_M98_Call_Macro_Subprogram
      At the end of config.g you can add M98 P"AdHocWIFI" (assuming that's what you named it) to call the adhoc network macro. That should work I think, but I haven't tested it myself.
      I mentioned using G4 S# commands earlier, these are pause commands to wait a set amount of time. The wifi module needs some time to process the commands it is sent. The module needs to be in the idle mode before it can be configured and it can take a few seconds for it to switch to idle.
      • FuseDeepundefined
        FuseDeep
        Awesome thanks.
        Lot's more reading up to do.
        I have my Z stepper connections labelled A+- and B+- , can I equate this to A- = A1 and A+ = A2 and similar for B?
        Phaedruxundefined Danalundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @FuseDeep
          I'm sorry, but I don't follow.
          FuseDeepundefined 1 Reply Last reply Reply Quote 0
          • FuseDeepundefined
            FuseDeep @Phaedrux
            @Phaedrux
            My previous Z plug is labelled A+- and B+- for the stepper coil sets.
            The DUET 2 board uses 2B2A1A1B
            Is 2A1A equal to A+ and A- and similarly for B; 2B1B equal to B+ and B- for the sake of wiring the new plugs?
            SORTED IT!
            • FuseDeepundefined
              FuseDeep
              End stops seem to be working.
              Odd though, can only move x and y by same amount then it stops moving.
              WIFI adhoc from duet2 disappears after ten minutes, even though blue led still on. irritating (this might have been me pressing main stop on screen).
              Also, it has stopped asking me to restart board after a config update.
              Without a full move endstop, what stops the axis moving and crashing, even with the travel length set. it does not seem to be stopping...
              Plus constant wifi idle window is making screen unusable...wifi is a massive pain. How on earth do i stop it telling me it is in idle ALL of the time?
              Currently tool 0 missing! (my extruder) , need to check if i removed the tool...
              Help! please. Back in the morning GMT 0900 ish
              (other than that, all moving and end stopping so not a bad first few hours) plus, love the simple crimps and tool. work a treat. Where can I buy multiple packs of the plugs/pins etc to make changes /mistakes etc?
              R
              • Danalundefined
                Danal @FuseDeep
                Awesome thanks.
                Yes.
                • FuseDeepundefined
                  FuseDeep @Danal
                  @Danal
                  Question:
                  If I am building the congif file via the web interface and then upload it, then edit it on the board direct...next time i do a web interface edit and upload, the other changes will be lost, no?
                  • FuseDeepundefined
                    FuseDeep
                    WIFI AdHoc set up:
                    Every time the adhoc shuts down, I have to go back to YAT and retrigger with a M552 S2 command.
                    There must be a way of setting this up proper, as a default?
                    I have added M98 p"AdHocWIFI" to last page web interface custom settings. but it does not seem to work. It should trigger my macro?
                    Also, am constantly getting a filename too long error now. seems to be a bug?
                    Help please. R
                    • deckingmanundefined
                      deckingman @FuseDeep
                      @Danal
                      Question:
                      No - (as long as you press the button that says "save"). The changes get made to the config file on the SD card.
                      Edit. You can't edit the configuration file "on the board direct".
                      • FuseDeepundefined
                        FuseDeep @deckingman
                        @deckingman Thanks. stumped by my extruder not showing up at all om DWC!
                          Probably time you posted your config.g file, otherwise we can only make guesses.
                          • FuseDeepundefined
                            FuseDeep
                            Completely agree:
                            Using one laptop on the FuseDeep wifi and one connected to tinternet is cramping my style:
                            Will need to do the following, add another identical (2nd Y axis) stepper from a "spare"stepper driver and have it run in reverse. Would drove 04/E1 do it?
                            Currently no extruder showing at all, just shaded out extrude/retract in DWC page. Odd, seems to be set up OK. obviously not!
                            Need to have adhoc FuseDeep wifi come on automaticaly wiohtout needing USB and YAT command!
                            BTW, having 10 second updates has literally saved me an hour today already. Marlin used to tak 4 to 5 mins each time!
                            Other thing, iirc I had to up the hysteresis setting in Marlin to stop the extruder lag killing the print (or something like that), how would I do that in DWC - Do I edit a separate config type file?
                            config.g as below:
                            ; generated by RepRapFirmware Configuration Tool v2.1.4 on Mon Dec 30 2019 11:04:01 GMT+0000 (Greenwich Mean Time)
                            M550 P"FuseDeep" ; set printer name
                            M552 S1 ; enable network
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M569 P0 S0 ; physical drive 0 goes backwards
                            M92 X80.00 Y80.00 Z4266.67 E406.47 ; set steps per mm
                            M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z180.00 E2700.00 ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z2.00 E250.00 ; set accelerations (mm/s^2)
                            M906 X1350 Y1600 Z1600 E1350 I30 ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M208 X620 Y550 Z1440 S0 ; set axis maxima
                            M574 X1 Y1 Z1 S1 ; set active high endstops
                            M558 P0 H5 F120 T3000 ; disable Z probe but set dive height, probe speed and travel speed
                            M557 X15:215 Y15:195 S20 ; define mesh grid
                            M140 H-1 ; disable heated bed
                            M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                            M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            ; Custom settings
                            M98 P"AdHocWIFI"
                            • FuseDeepundefined
                              FuseDeep
                              So to add a second drive to the Y axis would this work?
                              M569 P4 S0 ; physical drive 4 goes forwards (that's extruder 01 drive/4)
                              M584 X0 Y1 Y4 Z2 E3 ; set drive mapping (is that correct please?)
                              Am fairly optimistic the might work...I assume I edit the installed config file and hit save. This then gets saved/updated into the DWC?
                              SUCCESS! Used the colon separator. it works!
                              • FuseDeepundefined
                                FuseDeep
                                Problem:
                                When I update the config file via DWC direct, it asks me to restart the board to implement.
                                Once the board restarts, the wifi is lost and I have to goto YAT nd find a spare com port to connect and trigger AdHoc wifi command. Also, YAT keeps complaining of no spare com ports.
                                This is a pain, obviously!
                                PS> still can't see extruder...lol Saying no tool selected. hmm.
                                R
                                • FuseDeepundefined
                                  FuseDeep
                                  Problem with saving config changes:
                                  I edited the config file via the actual board wifi. Got the second stepper working on Ygreat. saved it obviously.
                                  However, when I (again) tried to check the extruder as tool 1 (still not working) it updated the board via upload and checking the onboard congif file, my original Y stepper additions are lost.
                                  Bit painful, how do you edit the config file and add uploads, or don't you?
                                  How then do you back up the config file onto a laptop? A copy and paste I suppose?
                                  Frustrating. R
                                  • FuseDeepundefined
                                    FuseDeep
                                    EXTRUDER:
                                    Heater works great and so does stat.
                                    However the tool 0 does not extrude during printing, even though it will extrude when not printing. will do a google...says not hot enough. nut is at 220 degrees
                                    FIXED!
                                    • FuseDeepundefined
                                      FuseDeep
                                      OK
                                      All good and 2 minor issues:
                                      Keep getting the filename too long error but it seems to be working regardless. Be nice to lose this error flag.
                                      Adhoc wifi; need to get macro working so do not need to USB/YAT to turn that on! Bit pointless otherwise.
                                      Any suggestions appreciated.
                                      Hmm, one more thing, a test print cam out brilliant...except approx 35% too big all round! No idea why...
                                      R
                                        @FuseDeep I'm having a job keeping up with what you have as a problem and what you don't. A couple of things that might clear up soem confusion that you seem to be having. Firstly, the extrude and retract buttons are greyed out by default to prevent you from cramming filament into an unheated hot end. To extrude, you first need to select a tool, then you need to heat it. Or for testing without any filament loaded, you can use M302 to allow cold extrudes. Secondly, there is only one main configuration file - config.g and that resides in the .sys directory of the SD card. When you edit the configuration using the web interface, you actually edit that file. That config.g file is only read once when the machine is first turned on. Or when you make changes via the web interface and hit save - then you might or might not get a prompt to reset the board (which means run config.g again) depending on which version of firmware you are using. So to be sure, you can send M98 P"config.g" which will run the file again, or you can cycle the power which will run config.g when the machine restarts. Thirdly, you have to have a tool selected before you can extrude. If your slicer doesn't put a Tn command in, then put one at the end of your config.g. Hope that clears a few things up for you. If your test print came out the wrong size, that might indicate that you steps per mm are not correct for the size of pulleys that you are using. Can't help with your WiFi issues - I used wired Ethernet.
                                        • FuseDeepundefined
                                          @deckingman Thanks, I appreciate I had a load of questions, a few of which I sorted myself and edited the OP. So some learning happening.
                                          Yes, hear you about the temp needing to be on for the extruder to show, discovered that and sorted the wrong thermistor use set for the tool. all fixed. Thanks for the comment.
                                          Regarding the dimension change, yes it must be step/mm however they should be set correct for the cogs and belting used...also the print is correct but wrong size and I am running 2 belt profiles so seems to suggest a scaling issue. Will check I did not slice the file wrong! Could be human error, easily.
                                          My main issue is triggering the wifi automtically and not need to trigger it via USB/YAT. pointless having it but needing to USB...
                                          As you say, not your area and not currently mine either.
                                          Am also getting the file name too long error pop up, annoying but it is working in general: Filename too long: cap=120, dir=0:/www/ name=R/A3AKIDkwMm...
                                          Will check the slicing once I have reprinted the filament guides (had some binding on print 001) and run a new test through again.
                                          Appreciate the forum's patience and help...
                                          I am still confused about config file though.
                                          Quite obviously if you set via the web tool and upload, this writes over any changes done on board and saved.
                                          So I can only now edit the onboard file to keep my settings as a new uploaded one will lose settings I cannot change via the online tool.
                                          R
                                          deckingmanundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                            @FuseDeep So one more go at the configuration thing......You can send any gcode command at any time - most of them even when a print is running. These can be anything from motor currents, tool definitions, steps per mm etc. Changes made like this will "stick" as long as power is applied to the board but will be lost when power is lost. To save having to type all these commands in every time we apply power, we use the config.g file. All that happens is that when power is applied, the firmware executes each of the commands in that config.g file in sequence. So if you edit config.g you are just editing that file and any changes you make won't take effect until you run that file as per my earlier post. Does that help to clarify?
