    Configuring RepRapFirmware SCARAPrinter
    382
    • Mauxxundefined
      Mauxx
      Hello to all, I tried to make my printer draw a cube, but I find a problem in the central part of the print bed. (See picture alt text
      This happens in any position both 0,0 with Simplify3D the central object is not square while with Repeiter draw a triangle
      What does this problem depend on?
      Thank you in advance
      JoergS5undefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Mauxx
        @Mauxx You had non-squares two days ago in https://forum.duet3d.com/topic/12947/configuring-reprapfirmware-scaraprinter/3 also, did the nonsquares have errors in the same direction and what did you change so the situation is better now?
        I suspect something like mistake in gear-calculation for configuration or wrong arm lengths (did you measure from hinge middlepoint to middlepoint and are the hinges at one definite axis each).
        (BTW you created a new thread with same title, maybe an admin can merge)
        Mauxxundefined 1 Reply Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5 @Mauxx
          @Mauxx An additional idea: microstepping means low torque. I don't know how you realized your gear (does it have a hight friction?), but maybe at this position the torque is too low or friction too high for an angle change and the change "drags on" and produces the curve. You could try setting the steppers to full step to test it.
          • Mauxxundefined
            Mauxx
            @JoergS5 thank you for answer me
            I change H in S in homing config
            But the motorstepping should be right
            I have both arm of 200mm and 1/32
            Printer work bad only in centre of area, seem that Distal joint doesn't move when draw central cube
            • Mauxxundefined
              Mauxx @JoergS5
              @JoergS5 Tomorrow i'll try your advice
              Thank you!!!
              • Mauxxundefined
                Mauxx @JoergS5
                @JoergS5 nonsquare object work nice
                JoergS5undefined 1 Reply Last reply Reply Quote 0
                • JoergS5undefined
                  JoergS5 @Mauxx
                  @Mauxx I don't understand "nonsquare object work nice", do you mean it is ok in the middle?
                  What do you mean by Distal joint doesn't move: is the force of the stepper too low or is it a software problem? Could you make an image of the arms, hinges and gears?
                  • Mauxxundefined
                    Mauxx
                    @dc42 could be a kinematic problem?
                    • JoergS5undefined
                      JoergS5 @Mauxx
                      @Mauxx I think the algorithms in the firmware are correct, they are simple trigonometric functions. No place for errors IMHO. I expect wrong measurement in arm length, angle or similar (maybe a hinge with play). So I could have an idea if I see your printer arms, hinges, gears.
                      • oliofundefined
                        oliof
                        Are those G0 or G1 moves? IIRC, some point-to-point gcode is not interpreted as a straight line in SCARA mode.
                        • Mauxxundefined
                          Mauxx
                          G1 moves
                          But in the picture i put 3 cube in print with Simplify3D and the only one not square is in the axis
                          • Mauxxundefined
                            Mauxx
                            Tomorrow i'll make some video, so you understand better
