    Issues setting up duet wifi with dual x axis motors and endstops
    59
    3.3k
    • wingtipundefined
      wingtip @droftarts
      @droftarts
      Thank you so much for your input. A few of those issues have already been addressed but I will post an updated config file later this evening. I will also certainly address some of the other issues you mentioned.
      Most of the script was auto generated but I did insert/edit some changes from the video I linked earlier that showed their code for a dual x setup.
      The next issue is figuring out why the x2 motor endstop isn’t working. Which is technically u4 endstop
      Highly modified FT5 R1, ATX supply, mosfet w/silicone heat pad, bmg ext, TMC2600 drivers, and my custom quad z mod with 4 lead screws and custom cut new upper panels and bed, and using the dual z endstop mod. New project is 800x500x500z printer.
        droftarts administrators
        @wingtip said in Issues setting up duet wifi with dual x axis motors and endstops:
        The U endstop should be connected to the E1 endstop connection, like the U motor is connected to the E1 motor driver. If you have a known-working endstop, swap it over, and test by pressing each one and see if it's registering in DWC (Machine-Specific tab, Endstops).
        I think the U axis has to be defined by M584 in config.g, and the U axis be visible in DWC, for the endstop to be seen, and it might even be that you need to split the axis (ie M584 X0 U4) for each X axis endstop to register. Otherwise it will only be seen in the homing script, where again, you have to split out the axes. I haven't tested this as I don't have a machine set up with an axis made up of two motors with endstops for each; I have a IR probe on the Z axis of my Cartesian machine.
        • wingtipundefined
          wingtip
          Thank you all for the help so far... currently the motors are moving again. here is my current config file. the current issue is with an endstop. I temporarily have everything unhidden so i can check the endstop status in machine properties and make movements to the x or U (my x2 motor).
          If i do an x move say +10, BOTH POSTS MOVE. Ok no biggie at least they're in sync...
          but if i do a U movement only the x2 moves. Ok no biggie that one will be hid later.
          if i hit home x, both motors start moving together and heading towards home as they should. However, if i manually hit the x1 endstop with my finger the x1 motor stops and the U/x2 motor keeps coming as it should.. but when i trigger the endstop for that one the motor keeps coming until i have to E stop or power off before it tries to smash another endstop.
          Ive confirmed in the machine status window the endstop works and will trigger but no matter which way i configure the endstop high or low etc it just ignores it so it has to be something elsewhere in the config...
          So for reference:
          x1 motor plugged into the x channel aka drive 0, this endstop plugged into the x slot
          x2 motor plugged into the E1 channel aka drive 4, which is remapped as U4, this endstop is plugged into the E1 endstop channel.
          config.g
            I can’t open your config.g to check (typing on iPhone), but It’s probably not the endstop, it’s your homing script that’s the problem. The whole point of making the U axis is so that when you home the X axis, you home X and U at the same time, but independently.
            First, check that the U endstop is triggering. Press the endstop switch and check it’s state changes in DWC, Machine Specifics tab, Endstops.
            Then, edit Homex.g with something like:
            G91 ; relative moves
            M584 X0 U4 P4; splits X axis into individual motors, visible U
            G1 H1 X-500 U-500 F6000 ; home fast
            G1 X5 U5 F5000 ; move off Endstops
            G1 H1 X-10 U-10 F600 ; home slow
            M584 X0:4 P3 ; combine X motors
            G92 X0 ; tell firmware where we are
            G90 ; absolute moves
            You’ll have to copy this into homeall.g too. Hope that makes it clear.
            wingtipundefined 1 Reply Last reply Reply Quote 0
            • wingtipundefined
              wingtip @droftarts
              @droftarts
              when i edited to what you suggested with the H1 variable neither endstop worked..so i switched back to my original S1 and the x endstop works again but the x2 is still not recognising the x2 endstop (plugged into the E1, aka drive 4 slot) , and yes the endstop triggers in the machine properties as i said before...
              im going to bed now but im going to post my gcode again as text since you were unable to open the text file. My current files are as follows:
              CONFIG G
              ; generated by RepRapFirmware Configuration Tool v2.1.1 on Sun Nov 03 2019 09:32:23 GMT-0500
              (Eastern Standard Time)
              M550 P"The Big One" ; set printer name
              M587 S"davet" P"helicopter"
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              ; Motor remapping for dual x, hidden?
              M584 X0:4 Y1 Z2 E3 U4 ; drivers 0&4 for x, drivers 1 for y, drivers 2 for z, drivers 3 for Extruder,
              G21 ; work in millimeters
              M208 X0 Y0 Z0 U0 S1 ; set axis minimum
              M208 X800 Y500 Z400 U800 S0 ; set axis maximum
              M574 X1 S0 ; position low, active low
              M574 E1 S0 ; position low, active low
              M574 Y1 S0 ; set active high endstops
              M574 U1 S0 ; set active blah blah
              M574 Z1 S2 ; set endstops controlled by probe
              M569 P0 S0 ; physical x drive 0 goes reversed
              M569 P1 S1 ; physical y drive 1 goes forwards
              M569 P2 S1 ; physical z drive 2 goes forwards
              M569 P3 S1 ; physical extruder drive 3 goes forwards
              M569 P4 S0 ; physical X2 drive 4 goes reversed
              M350 X16 Y16 Z16 U16 E16 I1 ; configure microstepping with interpolation
              M92 X400.00 Y80.00 Z400.00 U400.00 E415.00 ; set steps per mm
              M566 X600.00 Y600.00 Z12.00 U600.00 E120.00 ; set maximum instantaneous speed changes aka jerk speed(mm/min)
              M203 X7200.00 Y7200.00 Z180.00 U7200.00 E1500.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 U500.00 E10000.00 ; set accelerations (mm/s^2)
              M906 X1000.00 Y1000.00 Z1400.00 U1000.00 E1200.00 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
              M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 X15:215 Y15:195 S20 ; define mesh grid
              M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
              M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is
              turned off
              M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is
              turned on
              G10 P0 X0 Y0 Z0 U0 ; set tool 0 axis offsets
              HOME X
              ; homex.g
              ; called to home the X axis
              ; generated by RepRapFirmware Configuration Tool v2.1.1 on Sun Nov 03 2019 09:32:23 GMT-0500 (Eastern Standard Time)
              G91 ; relative positioning
              G1 S2 Z5 F6000 ; lift Z relative to current position
              M584 X0 U4 P4 ; Split x into 2
              G1 S1 X-805 U-805 F900 ; move quickly to X axis endstop and stop there (first pass) S1 checks for endstop hit
              ; go back a few mm
              G91
              G1 S2 X5 U5 F1800 ; go back a few mm
              G1 S1 X-10 U-10 F360 ; move slowly to X axis endstop once more (second pass) S1 checks for endstop hit
              M584 X0:4 P3 ; Join U to X again
              G90
              G92 X0
              G1 S2 Z-5 F2000 ; lower Z again
              G90 ; absolute positioning
              HOMEALL
              ; homeall.g
              ; called to home all axes
              G1 S1 X-805 Y-505 U-805 F900 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 S2 X5 Y5 U5 F1800 ; go back a few mm
              G1 S1 X-10 Y-10 U-10 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G1 S2 X15 Y15 F6000 ; go to first bed probe point and home Z
              G1 S2 Z5 F100 ; lift Z relative to current position
                droftarts administrators @wingtip
                @wingtip What firmware version are you on? Send M115 and post the reply. The only reason H1 doesn't work and S1 does would be if you are using firmware version 2.01 or earlier; from 2.02 they have the same function. See HERE. Which may also explain why the splitting of the axes and homing the two motors at the same time isn't working (though I thought this has been supported for a long time).
                I also notice in Endstops section M574 E1 S0 ; position low, active low. Remove or comment this out. 'E' in M574 was only support in firmware 1.16 and earlier. See HERE. I'm not sure of the effect of this line, but may be being applied to the Extruder endstops and causing issues with U.
                Apart from the above, I can't see any reason why the homing isn't working. Though you do need an G92 X0 after you re-join the axes in your homeall.g.
                Also, as I said before, in Network section, remove M587 S"davet" P"helicopter" from your config.g. It will slowly kill the flash memory on the WiFi module.
                • wingtipundefined
                  wingtip @droftarts
                  @droftarts
                  I do believe it’s 2.01 but will let you know when I get home.
                  As for the network setting I’ll worry about that after I at least get the x axis working. Once it’s working as it should I’ll mount the cross beams and start engineering the carriage (y axis).
                  Thank you all for your patience in this.
                    Please update to the latest stable release.
                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                    • wingtipundefined
                      wingtip
                      left work early due to the christmas party 😁
                      confirmed:
                      Firmware Version: 2.01(RTOS) (2018-07-26b2)
                      WiFi Server Version: 1.21
                      Web Interface Version: 1.21.2-dc42
                      will try to update now and get back with you.
                      • wingtipundefined
                        wingtip
                        Ok... im getting frustrated here but i think we're close. So right now here are my versions now.
                        Firmware Version: 2.04 (2019-11-01b1)
                        WiFi Server Version: 1.23
                        I also removed the Endstop line for E as mentioned. I verified the x2 endstop is in fact working and triggering when viewing the machine properties window. but im still not able to stop the x2 motor/aka U drive thats plugged into the E1 port with the enstop thats plugged into the E1 enstop port.
                        the green circle shows the x1 motor/vertical post. the motor is currently at mid travel OFF the endstop and is displaying the correct status. This motor also stops correctly when it does get to the endstop
                        the red circle shows the x2 motor/vertical post that is plugged into the E1 motor port which is remapped to U4. The endstop is plugged into the E1 port. the motor is currently at mid travel OFF the endstop and is displaying the wrong status but does trigger when manually activated. the problem is it still does not STOP the x2 motor/vertical post aka U4. the motor still just ignores this endstop
                        the blue circle has me really confused... why is my E0, aka extruder showing a min of 0 and a max of 800 while the E1, aka the x2 motor only shows n/a despite clearly being defined in the config to be min 0 and max 800???????? uggggg im brain fried
                          Update your DWC version, you’re using a very old one, may not be compatible, and give wrong info. It may assume an order for the motors that is incorrect. Use the latest version (2.04 or 1.22.6) from the firmware release DuetWebControl-SD-2.04.zip file or https://github.com/chrishamm/DuetWebControl/releases
                          This won’t affect the homing behaviour, but should give you the correct info!
                          It shouldn’t make any difference, but can you try changing the order of your M584 command? To M584 X0:4 Y1 Z2 U4 E3
                          Have you tried homing the U axis on its own? Try typing into console:
                          M584 X0 U4 P4
                          G91
                          G1 H1 U-800 F3000
                          G90
                          • wingtipundefined
                            wingtip
                            well according the link you first gave me it said the zip file i downloaded should update everything but i will go looking for the webcontrol update real quick. However when i was testing the movements and endstops that was using the paneldue.
                            • wingtipundefined
                              wingtip
                              i just tried the commands you suggested and still the same thing, the u starts to head to home and endstop is ignored the state says its triggered when its not suppose to be, then when i manually trigger it , it says triggered=no So you can see it working its just backwards . but its setup just the same as the x1 as both motors rotate in the same direction etc so the direction is correct and endstop settings should be the same since the x1 works perfect. Right?
                              the updated webcontrol is certainly different.. i dont like how it lessened the travel buttons from the +100 to now max travel button is +50.
                                Phaedrux Moderator @wingtip
                                You can right click on the buttons and redefine them.
                                • wingtipundefined
                                  wingtip @Phaedrux
                                  @Phaedrux Nice! told you guys im new to reprap and duets but im loving it so far despite the issues im having lol
                                    Is your PanelDue firmware up to date too? https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                                    Is the wiring, or the endstop, different on the U axis to the X axis? Because that sounds like it’s inverted, which it isn’t in config.g
                                    In the Fans section of your config.g, the comments of the two M106 commands seemed to had a return put in, so the words “turned off” and “turned on” appear to be on new lines. Lines must start with a Gcode or a comment mark (semi colon). I doubt this will change anything, but good to tidy it up!
                                    I am running out of ideas as to why this isn’t working. My only other suggestion would be to swap the U axis with the extruder, so move the U motor to E0, and the U endstop to E0 Endstop pins, and test if it works there.
                                    • wingtipundefined
                                      wingtip @droftarts
                                      @droftarts
                                      the paneldue is 1.21.4
                                      • wingtipundefined
                                        wingtip
                                        well im done... trying to update this panel due as suggested and its been a headache and now im to mad to continue for tonight... first off the enclosure i printed from thingiverse wasnt designed with updating firmware in mind and would be to much work to disassemble.... the designer left plenty of room for the other connectors but no way to get a micro usb plug to the board.. i had to sand down my plug to skin and bones to fit in the tiny slot he left for access... then when i followed the instructions on the web link provided after downloading bossa, my panel due now only displays a black screen and its not recognising it in windows so i cant get the port to use bossa to re upload the firmware....
                                        ill see you guys in the morning
                                          dc42 administrators @wingtip
                                          To see the U axis endstop properly, you need to make the U axis visible temporarily, by sending M584 P4.
                                          • wingtipundefined
                                            wingtip
                                            good morning gents..... so after a nights rest and calming down i found another cable this morning and tried it and bam, it recognised it and gave me the port i needed and now have my panel due working again and updated to now 1.23.2.
                                            so i went to try to home again and same issues... so in the new web control when editing it has a g code reference where before i was using some random web page... when using the reference from the webcontrol it seems to have some more updated info and i noticed this section and thought id give it a try
                                            M574 - RepRapFirmware 3
                                            Parameters
                                            Xnnn Position of X endstop: 0 = none, 1 = low end, 2 = high end.
                                            Ynnn Position of Y endstop: 0 = none, 1 = low end, 2 = high end.
                                            Znnn Position of Z endstop: 0 = none, 1 = low end, 2 = high end.
                                            P"pin_name" Defines the pin name(s) that the endstop(s) for the specified axis are connected to. Needed when S=0 or S=1.
                                            Snnn Endstop type: 0 = active low endstop input, 1 = active high endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
                                            Order dependency
                                            This command must be later in config.g than the M584 command that creates additional axes, or axes that have multiple motors and endstops.
                                            Usage
                                            The M574 command has been updated to allow for more flexibility. This includes supporting axes defined with multiple motors and multiple endstops (one per motor), use of non-default endstop inputs, and re-assigning endstop inputs.
                                            Notes
                                            Use a separate M574 command for each axis.
                                            New parameter P gives the pin name(s) for the endstop(s) for the specified axis. If the number of pins matches the number of motors assigned to that axis, motors will be stopped individually when their endstop switches trigger.
                                            New endstop type S4 means use motor stall detection (like S3) but if there are multiple motors, stop each one individually as it stalls. S3 means use motor stall detection but as in RRF 2: stop all relevant motors when the first one stalls.
                                            Example
                                            Old RRF_2.x code:
                                            M574 X1 Y1 Z1 U2 S1 ; active high endstop switches, XYZ at min, U at max
                                            New RRF_3 code:
                                            M574 X1 S1 P"xstop" ; X min active high endstop switch
                                            M574 Y1 S1 P"ystop" ; Y min active high endstop switch
                                            M574 Z1 S1 P"zstop" ; Z min active high endstop switch
                                            M574 U2 S1 P"e0stop" ; U max active high endstop switch
                                            To use two Z motors using independent homing switches, declare two Z motors in M584, then declare two pins for Z endstops in a single M574 command. Example
                                            M584 X0 Y1 Z2:3 E4
                                            M574 Z1 S1 P"io2.in+io3.in" ; Z axis with two motors, individual min endstops, active high
                                            The order of endstop switch pin names in M574 must match the order of Z motor driver numbers in M584. When homing Z, RRF_3 homes the motors of the axis at the same time, independently to their defined endstops.
                                            so i briefly experimented with this in hopes this would solve my issues but still nothing. And im still noticing the 2nd endstop is still triggered on the wrong end no matter which way you configure it... i think i need to follow the advice to swap to a different port instead of E1/drive 4 but im off to work now and i will do some more suffering after work lol....
