Advice to fix BLtouch drift?
  • Running this test:
    ; Probe testing single point.
    G30 P0 X150 Y150 Z-99999 F120
    G30 P1 X150 Y150 Z-99999 F120
    G30 P2 X150 Y150 Z-99999 F120
    G30 P3 X150 Y150 Z-99999 F120
    G30 P4 X150 Y150 Z-99999 F120
    G30 P5 X150 Y150 Z-99999 F120
    G30 P6 X150 Y150 Z-99999 F120
    G30 P7 X150 Y150 Z-99999 F120
    G30 P8 X150 Y150 Z-99999 F120
    G30 P9 X150 Y150 Z-99999 F120
    G30 P10 X150 Y150 Z-99999 F120
    G30 P11 X150 Y150 Z-99999 F120
    G30 P12 X150 Y150 Z-99999 F120
    G30 P13 X150 Y150 Z-99999 F120
    G30 P14 X150 Y150 Z-99999 F120
    G30 P15 X150 Y150 Z-99999 F120
    G30 P16 X150 Y150 Z-99999 F120
    G30 P17 X150 Y150 Z-99999 F120
    G30 P18 X150 Y150 Z-99999 F120
    G30 P19 X150 Y150 Z-99999 F120
    G30 P20 X150 Y150 Z-99999 F120
    G30 P21 X150 Y150 Z-99999 F120
    G30 P22 X150 Y150 Z-99999 F120
    G30 P23 X150 Y150 Z-99999 F120
    G30 P24 X150 Y150 Z-99999 F120
    G30 P25 X150 Y150 Z-99999 F120
    G30 P26 X150 Y150 Z-99999 F120
    G30 P27 X150 Y150 Z-99999 F120
    G30 P28 X150 Y150 Z-99999 F120
    G30 P29 X150 Y150 Z-99999 F120
    G30 P30 X150 Y150 Z-99999 F120
    G30 P31 X150 Y150 Z-99999 F120 S-1
    And getting this:
    PM M98 P"0:/macros/test-z-probe"
    G32 bed probe heights: -0.032 -0.045 -0.045 -0.060 -0.067 -0.065 -0.075 -0.080 -0.090 -0.095 -0.092 -0.110 -0.117 -0.110 -0.120 -0.135 -0.137 -0.150 -0.145 -0.157 -0.168 -0.165 -0.175 -0.185 -0.185 -0.185 -0.205 -0.195 -0.202 -0.215 -0.230 -0.240, mean -0.
    seems to just increase
    BLtouch v2.2 (antclabs)
    config.g
    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 R0.2 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P25 X-24 Y-19 Z4.70 ; Set Z probe trigger value, offset and trigger height
    M557 X20:250 Y20:250 S75:75 ; Define mesh grid
    HyperCube COREXY 300x300
  • This is on firmware 2.05 btw
  • Moderator
    Try adding this to your M558 command A10 R0.75 S0.003 B1
    That will have a slightly longer pause between travel moves and probing dives. It will force a tighter tolerance between consecutive probe results. And it will turn off the heaters during probe dives. You may notice that it will probe each point a minimum of 2 times and a maximum of 10.
  • I’ll give that a shot. Someone mentioned there may have been a bug in 2.03 and to downgrade e to 2.02 and if that fixes it then 2.05 may still have that bug. I’ll confirm and experiment more tonight when I get back home to printer
    As the trigger height keeps falling, that may mean that the Z axis is overshooting when the probe triggers because it can't stop fast enough. What is your Z steps/mm? Does a lower probing speed fix it?
  • Here is my gcode for stepping, steps per mm and speeds. I can try a lower probing speed - off to experiment
    M92 X160 Y160 Z400 E837 ; Set steps per mm - set to 837
    M566 X600.00 Y600.00 Z250 E2600 ; Set maximum instantaneous speed changes (mm/min) (jerk)
    M203 X12000.00 Y12000.00 Z250.00 E3600 ; Set maximum speeds (mm/min)
    M201 X600 Y600 Z80 E3000.00 ; Set accelerations (mm/s^2)
    M906 X1200.00 Y1200.00 Z900.00 E900 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    .9 degree steppers on X/Y
    1.8 on Z (dual z)
  • Moderator
    Your settings look very reasonable for the Z axis and probe.
  • So I enabled the multiple checks per point if the variation is greater than .03 and one time it never finished checking the level. I haven’t had too much time to test more but I made sure the bltouch was secure, straight and moved it up a tad higher so there was more room in case it was too close to bed but still seeing the same symptoms.
    Slowed z way down too to make sure bed wasn’t moving quicker than the bltouch could reset and also set a delay between each probe
    I’ll run another 30 test and report back
  • Moderator
    @supernovae perhaps time to clean the pin.
  • Do you actually mean 0.03 or did you mean to say 0.003?
    I had to set my BLTouch to 0.005 to get the probing to finish (up from 0.003) but then it worked fine. 0.03 (rather than 0.003) is pretty bad ....
  • yeah, .003 - sorry, I was typing on my phone (i dunno how people do that all the time.. give me a keyboard!! lol)
    i'll try cleaning the pin. I just switched to PEI build on my glass and stopped using glu-stick - maybe there is some residue on pin.
  • Moderator
    @supernovae said in Advice to fix BLtouch drift?:
    I find wisps of filament start to gather on the pin sometimes.
  • This is what i get now that I try and have it set to A5
    G28 Z
    Warning: Z probe readings not consistent
  • @Phaedrux said in Advice to fix BLtouch drift?:
    is there a way to safely remove & clean pin or just have it deployed and gently clean it deployed?
  • First lets look at the realistic results that the printer is able to produce
    Your z axis has a resolution of 250 steps per 1mm that equates to a resolution of .0025mm now also remember that this is in micro steps which is not really all that accurate chances are the best resolution that you could achieve would be .003mm. BL touch also has a best case repeatability of .01 and actually if you read their documentation it mentions .05 mm. If you are getting better than this it is a bonus. If you are getting resolution better than this think of it as a bonus.
  • Moderator
    There is a set screw at the top of the probe. You remove that and the pin will come out the top. The set screw is also how the trigger distance for the electromagnet is set.
  • @percar said in Advice to fix BLtouch drift?:
    I'd be OK getting a reading that was +/- within some margin of error range, but the fact my variance keeps drifting further and further suggests something else. I'd expect my G32 bed probe heights to report more random distributions within the margin of error rather than going from 0.032 to .240 probing the same spot
  • The really odd thing is, if i turn off, and not change anything and power back on, the first read is the same - every time... working on cleaning the bltouch tip to make sure its not friction causing height change
  • Found out my problem. I noticed one side of my printer was always sagging towards end of print, ran motor unlock and i could rotate left z and feel steps, but right z just spun - i guess my right z motor had failed.
    Replaced my right z motor, and now bltouch is happy and i don't have to run g29 between each print... kind of surprised i got the quality i did with that motor having been bad or faulty for so long...
    but, i'm back in business... no more crazy drift, nice level bed and great prints again. took the time to move to reprap3 firmware and enjoy it too!
