WiFi Issues - "Network Error" on uploading almost every file
  • My duet was working totally fine up until about a week ago when I have been having sporadic network issues. I am unable to upload almost anything, and it just throws up an error in the console
    "Failed to upload Duet2CombinedFirmware.bin
    Network error"
    I have also tried to upload via FTP and that keeps failing as well. I am not even able to upload the latest firmware package.... is there a way to do it offline?
    I have also just replaced the SD card just incase that was causing an issue:
    SD card in slot 0: capacity 15.55Gb, free space 15.53Gb, speed 20.00MBytes/sec, cluster size 32kb
    SD write speed for 10.0Mbyte file was 4.05Mbytes/sec
    Any help appreciated, I'm totally stumped right now.
    Some diagnostic info:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
    Board ID: 08DDM-9FAM2-LW4S4-6JTDA-3S06Q-KMT7W
    Used output buffers: 3 of 24 (15 max)
    Static ram: 25680
    Dynamic ram: 93044 of which 120 recycled
    Exception stack ram used: 268
    Never used ram: 11960
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3768) IDLE(ready,200)
    Owned mutexes:
    Last reset 00:26:41 ago, cause: power up
    Last software reset at 2019-12-22 20:35, reason: User, spinning module GCodes, available RAM 11960 bytes (slot 1)
    Error status: 0
    Free file entries: 10
    SD card longest block write time: 7.7ms, max retries 0
    MCU temperature: min 27.7, current 35.7, max 36.5
    Supply voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2019-12-22 21:20:06
    Slowest loop: 18.77ms; fastest: 0.06ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 82.09ms; fastest: 0.00ms
    HTTP sessions: 2 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address 2c:3a:e8:0a:f1:22
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 23384
      WiFi IP address 192.168.0.77
      WiFi signal strength -67dBm, reconnections 0, sleep mode modem
  • I suspect your wifi signal is too low. Move the printer closer to your wifi access point or the other way around. You could also install a signal booster of some kind if your wifi network allows for that feature.
    Last but not least, I think I have heard of Duet coming out with a board that uses an external antenna - maybe it can be retrofitted ?
  • The wifi (Unifi AP) is only in the next room over and the duet is the only device which seems to be having issues, so I don't know if that is the issue. My phone also shows the same -60db signal and it works fine. I have a feeling something must be up with the duet.
    Also, interestingly I just tried to revert to DWC1 interface and upload a gcode file, and it DID work. Although only at 150kb/s, but at least it worked without failing.
  • @TheBasedDoge I just now tried flashing Duet2Firmware-2.05.zip via Duet Web Control 1 and it worked on the first time! After trying probably literally 30 times on the new interface.
  • @TheBasedDoge said in WiFi Issues - "Network Error" on uploading almost every file:
    The wifi (Unifi AP)
    I also have a Unifi AP and a slightly better signal strength than yours and I still have an incredibly problematic wifi connection. Sometimes it works, others I need to retry 10 times. Sometimes works the first time and then I have to reboot the board to make it work again.
    Very frustrating. Wondering if it's something with the Unifi.
    PS: I'm on latest stable firmware
  • Interesting. I have tried rebooting the board like 15+ times and it doesn't do anything. Maybe we need to update the firmware on our unifis?
  • @jens55 said in WiFi Issues - "Network Error" on uploading almost every file:
    This is a very easy modification to retrofit. I bought a few 10 packs of the WiFi modules from aliexpress the external antenna makes a big difference. I have Since changed all the modules in the boards I have, I even socketed one to test in an ethernet equipped board, swapped the ethernet module with the antenna equipped module and that worked great too.
  • @CaLviNx said in WiFi Issues - "Network Error" on uploading almost every file:
    There's a big asterix on that "very easy", * provided you're comfortable desoldering large components from the PCB.
  • @Phaedrux
    Compared to a lot of SMC rework I would say that swapping the WiFi module is one of the easier to do.
  • I still have a feeling it has something to do with the new firmware update / new interface or something. Since I found the revert to DWC1 feature I have been able to reliable upload files.... although it's still VERY slow.
    Do you have a link for the wifi module you bought? That is something I could consider trying as well.
    Also, still not able to upload through Cura with the Duet plugin, it goes like 10-20% and then says "Error 99: network error"
  • Do you have the Unifi set to drop slow clients?
    If you watch the unifi dashboard while doing an upload what kind of signal strength are you seeing?
    Have you tried a different channel?
  • Here's the link to the units I am using successfully.
    WiFi Module with antenna
  • Thanks for the link. I might order one of those although I'm still not sure that is my issue since my duet has been working fine for years, in the same spot, up to this point.
    I have still consistently been able to upload files via the old duet web interface EVERY time, while files failing consistently on the new duet web interface. I think something is wrong with the new interface.
    Will also check the settings / stats on my Unify to confirm.
    That definitely sounds like a Dwc2 issue.
    Can you try clearing out the www folder and recopying the files fresh from the latest release?
  • I think it would be well worthwhile to do a quick wifi scan (free software is available) to check out the spectrum around your setup. It would be quite consistent with the symptoms reported that a neighbour has set up a new wifi device on either the same channel or on either side of it. That would account for it sometimes working and many times not despite an acceptable (?) signal level.
    I have seen some pretty odd things happening with wifi - it definitely is not a situation like a cable where you just plug it in and it works.
  • @jens55 the unifi controller can do a scan too.
  • okay I was ready to swap the wifi module but before that I tried to just "extend" the antenna... believe it or not it worked. I hadn't a single disconnect since
    Basically cut the onboard antenna and soldered a new one. The antenna must be of a very specific length (check 2.4 antenna length) but apart from that it's a 5 minutes hack.
    Now, I don't suggest to anyone doing that... but it worked for me.
    The built in antenna is very small, also for best signal strength it should be mounted vertically to match the antenna direction in routers, not horizontally as you have it.
  • @dc42 said in WiFi Issues - "Network Error" on uploading almost every file:
    that is interesting, thanks for the heads-up! The antenna hack fortunately worked very well but good to know for the next duet 🙂 Even though the next duet will be surely with external antenna module.
